Samsung MDM Bypass:
All Patches
ADB Mode
Cost per device 13 credits
Unlocking the MDM is not a permanent solution, after the device is factory data reset or firmware rewrite it is locked again!
Bypass MDM will not withdraw credits, if the device has already been unlocked through FDTool Pro, it works for devices with the same SN/IMEI and FDTool username.
FRP lock must be disabled!
On some of our test devices, we detected an occasional reboot occurring.
Samsung default screen lock cannot be added (if you add the lock when restarting the device, it goes into infinite loop)
It is not necessary to have an active FDTool Pro license to perform the bypass, it must only have available credits.
FDTool Pro V1.1.2.0 Update
Order here - www.Gsmservice.center
#fdtool , #noneeddongle
