UFI Software updates:
NewsMaker
Staff member
Official site - here
Credit consumption - here
Official Support - here
Need box
UFI Software version 1.5.0.2008
UFS ToolBox release preview:
The UFS ToolBox requires a UFI UFS-PROG device and will later be available as an upgrade kit for current users
UFS-PROG hardware must be paired with UFI-BOX, so you still need UFI-BOX to work with the software
General changes:
ADD: Support for Android 10 with dynamic partitions so the system information for Android 10 should be read correctly now
eMMC ToolBox changes:
ADD: RPMB provision information on identify
BUGFIX: Minor bugfixes and improvements
Android ToolBox changes:
ADD: Bypass security for MediaTek devices
Supported chipset:
MT6785, MT6765, MT6761, MT6763, MT6768, MT6771, MT6779, MT6755, MT6750, MT6757, MT6758, MT6735, MT6737, MT6739, MT6797, MT6799
MT8163, MT8173, MT8695
MT6877, MT6833, MT6893, MT6853, MT6885, MT6873
This function should work for all brands including Xiaomi, Oppo, Vivo, Meizu devices
Some of these chipsets has been tested and some not, please report if you experience any issues with a specific chipset
This function works standalone and FREE but will only work if you have at least 1 UFI credit in your account
BUGFIX: Improved flashing routine
!!! WARNING: Do not rename "BRAND" and "MODEL" list to be different as at support site, certain features might not working properly !!!
NOTE:
Bootloader Authorization service is limited as "Bootloader Authorization" which is required for Identify, Flashing, Read, Write, Erase and Special Task menu
If Bootloader Authorization request fails, you may retry 2 more times at no cost
For any issue and refund claim because of software bugs, you may write an email to support[at]ufibox.com, please include your detailed logs
By credits from gsmservice.center
NewsMaker
Staff member
UFI Software version 1.6.0.2202
6th Anniversary Update
NewsMaker
Staff member
UFI UFS Socket . Soon!
UFI - UFS ToolBox
Features:
Works as an add-on interface paired with UFI-BOX
USB 3.1 Gen1 SuperSpeed(5 Gpbs)
Supported protocol upto UFS 2.2
Supported upto PWM Gear 4 and High-Speed Gear 3 x 1Lane
High-Speed data access upto 120 MBps read and 80 MBps write
Access (R/W) to UFS registers (flags, attributes, descriptors) including provisioning
Access (R/W) to UFS Luns and Rpmb partition
Come with user-friendly software for a better understanding of UFS technology
Packed with special features used to repair smart-phones
Package includes:
1 x UFS ToolBox
1 x UFS 2in1 Socket Adapter ( BGA254, BGA153)
1 x UFS ISP
1 x USB Data Cable
UFI UFS TOOL KIT INSTALL INSTRUCTION
NewsMaker
Staff member
UFI Software version 1.6.0.2333
UFI UFS ToolBox for UFI-UFS Prog release Update
General changes:
BUGFIX: Revised Dark Mode UI support
ADD: Special Task in Programming Tab
- Update eMMC5x Firmware
Firmware update method for all eMMC 5.x
- Secure Wipe(TRIM, Sanitize)
- [moviNAND] eMMC Full Reset (Reset RPMB, ECC error, Factory Reset)
- [moviNAND] Force boot mode (erase firmware)
ADD: BOOT_SIZE entry on EMMC PARTITIONING tab (For Micron eMMC)
BUGFIX: Revised eMMC Fw routine
UFS ToolBox changes:
Requires UFI UFS-PROG with firmware version 01.34
Basic features:
To work with UFS ToolBox, UFI Box is required for security
UFS ToolBox license for UFI Box need to be activated once
Activation process requires UFI UFS-PROG to be connected together with UFI Box
Support LS(PWM Gear 1-4) and HS Gear 1-3B
Currently support up-to UFS2.2
Direct(ISP) method work in PWM Gear 1-4
Support for UFS CONFIGURATION (Provisioning)
Basic Wipe, Erase, Read and Write LUN and user partition
ADD: UFS ToolBox activation routine
ADD: UFI UFS-PROG Firmware update routine
ADD: Special Task (Partially implemented)
ADD: Raw LUN and User partition function implemented in PROGRAMMING tab
ADD: FACTORY IMAGE functions revised to work with UFS device
ADD: Recent model selection
ADD: Model list sort improved
BUGFIX: Improved bypass security routine for MediaTek
NOTE: This UFI- UFS-Prog need to be connected/Plug with the UFI BOX in order to work!!!
NewsMaker
Staff member
UFI Software version 1.7.0.2661
Requires UFIBOX with firmware version 1.15
ADD: RPMB read/write/provisioning support
Requires UFI UFS-PROG with firmware version 1.37
ADD: Special Task implemented
BUGFIX: Fixed known Read/Write/Erase bugs
ADD: [MediaTek] Introduced Custom (DA) loader
Custom loader will enables the following features:
- RPMB read/write support
- Lock/Unlock Bootloader and so on
ADD: Bypass Security and Custom loader option
Order here -www.Gsmservice.center
#ufiupdate
NewsMaker
Staff member
UFI Software version 1.7.0.2662
Code:
Code:
ADD: Introduced Custom (DA) loader
ADD: Setting for [MediaTek] Use libusb0 filter driver instead
of UsbDk by Default UsbDk will be used for Bypass Security.
#ufiupdate
Gsmservice Support
Staff member
Premium
UFI Software version 1.8.0.3246
General changes:
Improved support system
ADD: Support for EROFS
ADD: Unlock Config Descriptor Lock
Spesified for Samsung, SK hynix, Micron, WD, Kioxia UFS
ADD: [MediaTek] Enables custom loader routine for
- eMMC Full Reset(Reset ECC error, RPMB counter)
ADD: [MediaTek] Preloader mode support for the following brand:
Oppo
Vivo
Infinix
Itel
Techno
Буюртма бериш - www.Gsmservice.uz
#ufiupdate
Gsmservice Support
Staff member
Premium
The following are some of the feature highlights in the UFI Software update:
- **Unlock Config Descriptor Lock** on Tab UFS Configuration in UFI UFS ToolBox.
This feature is useful for unlocking the config lock(OTP descriptor Lock) of the UFS chip,
so now you can change the LUN configuration according to your needs.
- **Preloader mode support** for Transsion Devices(Infinix, Itel, Tecno), Oppo, Vivo and some Samsung.
- Integrated custom loader and custom dll library, so now you don't need to have stock firmware (scatter+preloader files)
to perform Identify Devices and other special functions on the Mediatek tab.
- Enables custom loader routine to perform special task feature, such as:
Especially for Samsung eMMC(moviNAND) to Clean RPMB(eMMC Full Reset) under testing, Read FFU & Repair CID,
Repartitioning SKHynix eMMC to repair Exeeded maximum device life time
- *Unlock Config Descriptor Lock* also available in UFI Android ToolBox via Special Task,
so now you can unlock descriptor lock config on the fly without chip off methode.
For detailed changes to the UFI software update, please open changes.txt in the UFI setup folder.
B.R
UFI BOX Team
Stay tuned, be patient, wish us the best, more to come.......
Gsmservice Support
Staff member
Premium
UFI Software version 1.8.0.3296
General changes:
Improved support and download system
ADD: improved eMMC ffu routine
ADD: [MediaTek] Preloader mode support with custom loader for:
Oppo, Vivo, Samsung, Infinix, Itel, Techno
ADD: [MediaTek] Imei repair in Flash(Brom) mode
UFI Box сотиб олиш - www.Gsmservice.uz
#ufiupdate
