UltimateMTK2 v1.2 The Ultimate MediaTek Tool
1710515486546-png.3220
Added Vivo Demo Reset (New)
- Tested on Vivo T2x 5G and Y28 5G
Added Vivo Demo Reset (Old)
- For devices not supported by New Method
Added Samsung Unbrick and TAR Flashing
- Simple and Easy way to Unbrick Samsung Devices
- NO NEED OF UNBRICK FIRMWARE ANYMORE
- Supports Completely Formatted Flash Chips
- Creation GPT on the fly if it is Erased
- No need to use Odin to flash after Unbrick if used BL/AP/CP/CSC
- Flashing any Single TAR is supported if GPT is intact
- Incase of fully formatted flash chip, you must use BL/AP/CP/CSC
- Use of same or higher BIT Firmware is recommended to fully recover device
- Software will automatically use preloader from BL if device is connected in BROM mode
Added Read Dump
- Simple and Easy Tool to make Full Dump
- Backup BOOT1/BOOT2 and USERAREA
- USERAREA dump is completely customizable
- You can choose either FULL or set own Start/Length for USERAREA
- Auto detect if save location has enough free space to save dump
Added Write Dump
- You can write back dump created by Read Dump function
- Just select CFG file and tick parts of dump you want to write
- Writing DUMP from one device to another is not recommended
- Make sure to backup security partitions before writing DUMP from another device
Fixed "Lost in background" issue on Confirmation Dialog at Startup
Improved Format Functions
Improved Write Flash Function
Minor UI Changes
Buy NCK dongle 1 year support here - www.gsmservice.center
#nckdongleupdate
NCK Dongle updates full history - here
