UMTv2 / UMT Pro UltimateMTK2 v0.6 The Ultimate MediaTek Tool
Added Infinix 2023 Security in Preloader Mode (Service Tab)
- Support MT6739/6X and 6833/77/93 etc.
- Enable BROM (Preloader Mode)
- Reset FRP (Preloader)
- Format FS (Preloader)
- Enable BROM will backup Preloader and Enable BROM to use other functions in BROM mode
- Use Disable BROM to return to normal condition
Added Partition Manager
- Tick "Print GPT in Log" to print partiton information in log for debug purpose
- Click on Boot to boot and list all partitions
- You can use "Read Scatter" to read firmware with selected partitions to write back later
- You click on "..." button to load any file to any partition and write using "Write RAW"
- "Erase" button will let you format selected partitions (all if you really need)
Added Customization Option in Scatter Flash
- You can select differnt files for a partiotion instead of default loaded in scatter
Updated Overall Flashing Function
Updated Preloader and EMI Data Parser
Updated Xiaomi Cert Patch Function
- Fixed issue on some modems with different patch addresses
- Improved overall modem patching and writing
Updated Patch Cert for Redmi 12C
Fixed Issue in booting completely formatted devices
Some other miscellaneous improvements
