UMTv2 / UMT Pro UltimateMTK2 v0.9 The Ultimate MediaTek Tool
Added Preloader Exploit (Beta)
- Vivo MT6789 (Helio G99)
- Tecno MT6983 (Dimensity 9000+)
Added Xiaomi Security Repair (New Method)
- Repair make using this method is permanent
- Bootloader must be unlocked
- You can hardreset your device without any issue after repair
- This method needs NVRAM to be intact, if not, you can write NVRAM backup from same model
- This method works only till MIUI 11 (as per our tests)
- If device hangs after repair, you can format or reset it
Added Oppo Security Repair (New Method)
- We recommend using this method
Added Samsung Security Repair
- No need bootloader unlock
- Repair made using this method is permanent
- Should work on all Samsung 4G devices
Added Generic Security Repair
- No need bootloader unlock.
- Repair made using this method is permanent.
- Should work on all Generic 4G devices including Infinix/Tecno etc.
Added Infinix MDM Reset Function
- Account/ID/MDM related functions are moved in a single group.
Added User Agreement at startup
- You must agree to be able to use IMEI/Security related functions
Updated Samsung KG Remove Function
Updated Helio Protocol to eliminate GET_PACKET_LENGTH error
Improved overall Read/Write speed
Fixed Calculation Error while unlocking Bootloader
Fixed rare RPMB Read/Write Error
Fixed DA Error in Infinix 2023 function
- However, we recommend using PL Exploit instead of this
Fixed issue where CUST_PL was selected but DA was not selected by user.
Fixed issue on model selection
Added Update Information in log window on startup
- You can test PRELOADER EXPLOIT on any device with DA from Vendor even if that DA does not allow Write or Erase.
Buy UMT (Box/Dongle) 1 Year Activation here - www.gsmservice.center
