UMTv2 / UMTPro UltimateMTK v0.2
Wishing all of you a very
HAPPY NEW YEAR 2023
Whats New:
- This is new module, replacing old MTK module
- No more boot related issue or complications
- Easy to use clean and organized interface
- Completely customizable options to use own DA/PL etc.
- More useful functions are on the way
Added Xiaomi and Oppo IMEI Repair
- Both IMEI is supported
- Please unlock bootloader first
- Incase bootloop after BL unlock, just wipe data from recovery
- Tested SoCs:
- MT6765
- MT6761
- MT6771
- MT6779
- Should work on others also except 5G chipsets
Changed Connection Settings for users familiar with old module
- Unticking Disable Auth will also disable options not supported without exploit
- You must use Disable Auth for secured phones
- Crash Preloader will not work on newer device and you must use Testpoint for them
- Preloader mode will not work for secured devices unless you have secure DA
Added Select Preloader Prompt
- If dump preloader failed, it will prompt you to select preloader
- For phones connected with testpoint, preloader need to be selected by user
Improved DA selection and handling
- Now software will try to pickup first supported DA from DA folder
- It has no effect if user has selected custom DA
Updated Mi Relock Fix
- Now devices with dual slot are supported
- Not all firmware are supported, if it does not work, try downgrade
Resized GUI to fit low resolution screens
Added Context Menu in Logs
Changed Installation Folder
- Now you can use old module in parallel with new module
- Once all functions are moved to new module, old module will be eradicated
#umtpro
