UMTv2/UMTPro UltimateMTK2 v0.8 - Samsung, Oppo, OnePlus in Preloader Mode
Added New Preloader Exploit Method
- Supported Chipsets:
- INFINIX (MT6739/61/63/65/68/81/85/MT6833/77/93)
- INFINIX MT6765 [1]
- INFINIX MT6768 [1]
- INFINIX MT6768 [2]
- OPPO/REALME/ONEPLUS MT6765
- OPPO/REALME/ONEPLUS MT6768
- OPPO/REALME/ONEPLUS MT6833
- OPPO/REALME/ONEPLUS MT6877
- OPPO/REALME/ONEPLUS MT6893
- SAMS MT6765 [A03S]
- SAMS MT6765 [A04E]
- SAMS MT6765 [A04]
- SAMS MT6833
- VIVO (MT6761/63/65/68/71/81/85/MT6833/53/73/77/85/93)
Tested devices:
- Infinix Smart 7 (X6515)
- OnePlus Nord 2 5G
- OnePlus Nord 2 CE 5G
- Tecno Pop 7 Pro (BF7)
- Vivo V21 5G (PD2083F)
- Vivo V23 5G (PD2167)
- Vivo V23e (PD2159F)
- Vivo Y12s (PD2036F)
- Vivo Y16 (PD2216F)
- Vivo Y17 (PD1901F)
- Vivo Y1s (PD2014F)
- Vivo Y20s (PD2066F)
Supported Functions:
- Firmware Read/Write
- Security Read/Write
- RPMB Read/Write
- Vivo Security Repair
Custom DA (CUST_DA) Option
- You can select own DA if needed to use with PL_EXPLOIT.
- Be informed, that DA must be from same vendor, as Generic DA may not work.
- PL_EXPLOIT will work even if DA from vendor has read only access.
Added Fix Recovery Option
- Use this function to fix phones stuck in recovery mode after Safe Format
Updated Safe Format Method
- There should not be anymore recovery issue.
- If you face issue, just use Fix Recovery option from Format functions
- You can use Format userdata instead on such phones.
Buy UMT (Box/Dongle) 1 Year Activation here - www.gsmservice.center
