UMTv2/UMTPro UltimateMTK2 v1.4 - Xiaomi Preloader Mode
What's New:
Added Xiaomi Preloader Auth
- Supports Firmware Read/Write, FRP, Format, Mi Account etc.
- Should be working on any Xiaomi device which connects in Preloader Mode
- Both MIUI and HyperOS are Supported
- Select XIAOMI AUTH from PL_EXLOIT list, and select DA.
- Single DA may not work on all version due to signing.
Tested Devices:
- Redmi 13C (gale)
- Redmi Note 13 5G (gold)
- Redmi Note 13R Pro (gold)
- POCO X6 Neo 5G (gold)
IMPORTANT:
- You need to use DA from same version/region firmware.
- Due to numerous firmware version and region, adding them all is not suitable.
- If DA1 stage is failed, that means selected DA is not compatible.
- In such case, you must select DA from same version/region firmware.
- This method should work on almost all Xiaomi Devices by using DA from firmware.
Updated Internal DA selection
- This should fix DA selection error for some chipsets
Fixed dm-verity error on Safe Format
Added Safe Format function for Xiaomi
Added Safe Format + FRP for Xiaomi
![umtmtk14.png](http://ultimatemultitool.com/tmp/umtmtk14.png)
What's New:
Tested Devices:
- Redmi 13C (gale)
IMPORTANT:
