UMTv2/UMTPro UltimateMTK2 v1.5 - Infinix 2024 Preloader Exploit and more..
Added Infinix/Itel/Tecno V4 (2024) Preloader Exploit
- Supported Chipsets:
- MT6761
- MT6765
- MT6768
- MT6833
- MT6891/MT6893
- Read/Write Firmware/Format FS/FRP
Following Models should be working:
- Infinix GT 10 Pro (X6739)
- Infinix Hot 10i (X658B)
- Infinix Hot 20 5G (X666C)
- Infinix Hot 20 Play (X6825)
- Infinix Hot 20i (X665E)
- Infinix Hot 30 (X6831)
- Infinix Hot 30 5G (X6832)
- Infinix Hot 30 Play NFC (X6835B, X6835)
- Infinix Hot 40 (X6836)
- Infinix Note 11 (X662, X662B, X662F)
- Infinix Note 11 Pro (X697)
- Infinix Note 11i (X663, X663B, X663C)
- Infinix Note 11s (X689)
- Infinix Note 11 (X689F)
- Infinix Note 12 (X6817)
- Infinix Note 12 5G (X671)
- Infinix Note 12 Pro 5G (X671B)
- Infinix Note 12i (X6819)
- Infinix Note 30 5G (X6711)
- Infinix Note 30 VIP (X6710)
- Infinix Note 30i (X6716B)
- Infinix Zero 30 (X6731)
- Tecno Camon 12 (CC7)
- Tecno Camon 12 Air (CC6)
- Tecno Camon 12 Pro (CC9)
- Tecno Camon 15 (CD7)
- Tecno Camon 15 Air (CD6)
- Tecno Camon 15 Premier (CD8j)
- Tecno Camon 15 Pro (CD8)
- Tecno Camon 16 (CE7, CE9H)
- Tecno Camon 16 Pro (CE8)
- Tecno Camon 16 SE (CE7J)
- Tecno Camon 17 (CG6, CG6J)
- Tecno Camon 17P (CG7, CG7N)
- Tecno Camon 18 (CH6, CH6N)
- Tecno Camon 18T (CH6T)
- Tecno Camon 19 (CI6, CI6H)
- Tecno Camon 19 Neo (CH6I)
- Tecno Camon 19 Pro 5G CI7n)
- Tecno Camon 20 (CK6)
- Tecno Camon 20 Premier (CK9n)
- Tecno Camon 20 Pro 5G (CK8n)
- Tecno Camon 20s Pro 5G (CK8nB)
- Tecno Camon 11S (CB7)
- Tecno Phantom V Flip (AD11)
- Tecno Pova 2 (LE7)
- Tecno Pova 5 Pro (LH8n)
- Tecno Pova 6 Pro (LI9)
- Tecno Pova Neo 2 (LG6N)
- Tecno Pova Neo 3 (LH6n, LH6)
- Tecno Spark 10 (KI5N)
- Tecno Spark 10 5G (KI8)
- Tecno Spark 10 Pro (KI7)
- Tecno Spark 20 (KJ5)
- Tecno Spark 20C (BG7n)
- Tecno Spark 8 Pro (KG8)
- Tecno Spark Go 2023 (BF7)
- Tecno Spark Power 2 (LC8)
Added Set Active Slot Option
- You can use this function if phone stuck in Fastboot after flash
Fixed "No HWID Found" Issue in DA Selection
Improved Booting Process
Some Minor Improvements
Арзон нархда UMT (Box/Dongle) 1 Year Activation сотиб олиш - www.gsmservice.uz
