UMTv2/UMTPro UltimateSams v1.0 - Samsung Exynos Enable ADB from DL Mode
UltimateSams v1.0
The Ultimate Samsung Tool
Whats New:
Added Exynos Enable ADB in Download Mode
- Connect device in Download Mode
- Use Enable ADB (Exynos), select your SoC
Supported SoCs:
- Exynos850
- Exynos1280
- Exynos1380
- Exynos1480
- Exynos1580
- Exynos2100
- Exynos2200
- Exynos2400
- Exynos2500
- Exynos7884
- Exynos7885
Notes:
- You may need to Factory Reset if Enable ADB does not work
- Not all devices are tested, Exynos850 is tested to work
- If you SoC is not listed, you can select any from list
- Once ADB is Enabled, use Reset FRP (Exynos) to Reset FRP Lock
- If it fails, you can still try third-party tool to Enable ADB
Added Set Download Mode Option
- You can use this function to Enter Download mode from Normal Mode
UltimateSams v1.0
Whats New:
Supported SoCs:
- Exynos850
- Exynos1280
- Exynos1380
- Exynos1480
- Exynos1580
- Exynos2100
- Exynos2200
- Exynos2400
- Exynos2500
- Exynos7884
- Exynos7885
Notes:
