Infinity Chinese Miracle Updates
Infinity #CM2SP3 v2.21 released, 650+ devices supported
HOW TO USE
- Devices list updated with more devices
- Boot process revises, loaders incompatibility detection improved
- Autosave [~user] profile for selected external PAC loaders
- Protocol selection hints updated
- Baudrate (connection speed) selection for [FDL] mode
- Store partitions layout to backup
- Firmware read option
- Display estimated time to end of firmware read process
- Disk free space verification on read
- Minimize allocated storage space on read and truncate files to actual data size
- Firmware write option by layout.txt and gpt.raw layouts
- Firmware files selection for write with On/Off option for each file
- Separate button for EXTCSD read
- Protocol selection hints and suggestions as per selected device hardware
- Selected SoC name included in operation header text
- Firmware version detection method revised
- Boot pack version check revised
- Boot pack files updated
- Free disk space verification method changed
- gui fixes
- Many internal improvements and fixes
NOTE: Complete Device Database compilation is in progress but it takes time. In case of connection issue with built-in loaders try with PAC file.
Buy CM2 1 or 2 year Support here- www.Gsmservice.center
#cm2update
Infinity #CM2SP3 v2.22 released, bootloader, mdm and more
800+ devices in list
- Devices list updated with more brands and models
- Device database [boot-pack] updated with more parameters
- Bootloader unlock/lock for many devices
- Additional [wipe] option during bootloader lock/unlock process
- MDM fix [Apply] and [Rollback] for many devices
- Firmware version detection issue (crash) fixed
- "Device autosave" method on PAC selection updated
- Minor gui changes
Buy CM2 1 or 2 year Support activation - www.Gsmservice.center
#cm2update
Infinity CM2 Full updates history - here
Infinity #CM2SP3 v2.23 released - [MemoryTool], EXTCSD write and more features
- Devices list updated with more models
- [MemoryTool] initial release with Read/Write/Wipe partitions
- [MDM] Apply/Rollback methods improved
- Built-in boot pack files updated
- EXTCSD parser revised
- [MemoryTool] EXTCSD write option
- Firmware version/strategy parser updated
- Minor gui changes
Infinity #CM2SP3 v2.24 released - [MMC EOL Reset], RPMB read and more features
[FF] mode:
- [MMC EOL Reset] function to attempt to extend faulty EMMC lifetime
- [RPMB] read function
- [Repartition] option during flashing
- [MemoryTool] read partition table
- [MemoryTool] INIT (write) partition table
- Partition table analyzer updated
- backup and firmware read/write process updated
- [Service Report] option
Buy CM2 1 or 2 year Support here - www.Gsmservice.center
#cm2update
Infinity #CM2MT2 v2.53 - many new devices supported and more features
- MT6855 and MT6879 support
- More devices without open/test-point supported
- New DA included in package
- Boot flow and DA selection process updated
- Firmware version detection method updated
- Firmware version detection issue fixed
- [Smart Reset] and [Wipe] methods updated
- tee/google key method revised
- Startup logs analyzer method revised
- Startup logs analyzer directory/file tree structure changed
- [FixDL] operation revised
- [MDM] process revised, more devices for direct process supported
- [MDM] process adjusted for tecno/infinix
- extcsd backup file name format changed
- Memory management revised
- [LeveBoot] option value restore on restart
- "HW Report" output changed
- FRP processing changed
- Minor gui changes
- Many internal changes and optimization applied
Dongle firmware version required: 0159
Infinity #CM2MT2 v2.54
- Boot process revised
- MDM process revised
- Mi Account process revised
- Server access method updated
- Local config files updated to avoid unnecessary server calls
- Firmware Read estimated time to end indication
- GUI changes
- Internal changes and optimization applied
#cm2update
Infinity #CM2SP3 v2.26 released
- Many new models in list
- SC7731e [FF] protocol released for advanced service options
- [RPMB Write] function in addition to previously released [RPMB Read]
- RPMB Smart Write enabled to optimize and make faster RPMB write process
- Filesystem parser (ext4) revised
- RPMB autobackup on Connect
- [Change Active Slot] option for [MemTool]
- [Device-ID] functions revised
- GPT parser revised
[AppTool] feature via [FF] mode
- Print list of available/installed APK
- Disable any (even system) APK pernamemntly
- Disabled APK stay disabled even after Reset or Wipe
- Save list of installed APK to file
- Restore disabled APK back anytime
- Extremely fast processing
NOTE: Bootloader must be unlocked for this operation
What [AppTool] can do:
- OTA On/Off
- MDM/Admin Apps On/Off
- Bloatware/Telemetry/Spy Apps On/Off
- Network/Operator addons On/Off
- And many more features depends on your fantasy
- Config options save/restore on startup
- Minor gui changes
- Internal improvements and fixes
HOW TO USE
#cm2update
Infinity #CM2MT2 v2.56 - [AppTool] feature, [MMC EOL Reset] and more
[AppTool] feature
NOTE: Bootloader must be unlocked for this operation!
- OTA On/Off
- Boot files selection method updated
- DA selection method updated
- [MemTool] gui changes
- [MemTool] functions rebuilded
- PSN Read/Write function released
- [MDM] method updated including infinix/tecno/itel handling
- BT/WiFi MAC addrees read method updated
- SCAT file load method changed, preloader become un-checked by default
- [Format/Reset] methods updated
- [Format/Reset] separate [Accounts] option released
- key.json generation for generic devices
- boot-pack integration method changed
- GUI changes
- Internal changes and optimizations
#cm2update
Infinity #CM2MT2 v2.58 - MDM, PSN, [AppTool], [MemTool], [RawTool], boot-pack on Demand
- Firmware version detection method updated, process goes much faster
- Reboot On|Off option behaviour changed
- SoC/Model/DA Selector revised
- Connection process for completely erased devices changed
- [Identify] process updated for faulty units better detection
- Flasher/SCAT loader menu updated
- [RawTool] rebuilded
- [AppTool] menu updated with Find First/Last/Next/Previous options
- [boot-pack] On Demand Downloader:
Offline boot-pack installation is not required
DA/Auth/Preloader files loaded from server on model selection via [Get boot files]
- [MDM File] option removed as useless
- [MDM] process rebuilded, it works without account/username
- Backup engine and process rebuilded
- PSN REad/Write method updated
- GUI changes
How to Reset MDM
How to get DA without boot-pack installation
How to use [AppTool]
How to make [MMC EOL Reset]
