Infinity Chinese Miracle-2 CM2MT2 v2.33 - New repair and service features
Core
Changed: Protocol updated (RAPHAEL/LEGACY)
Changed: FireFly OverDA has been updated
MemoryTool
Changed: MemoryTool rebuild
Changed: Activated "Restore Backup" with security only mode
Changed: Activated "Open active folder" button
Changed: Activated Init GPT from binary file
Changed: RPMB operations optimized
Changed: RPMB unificated type detection ( "swapable" types even on programmed RPMB )
Flasher
Changed: Protocol updated (RAPHAEL)
Changed: UltraFlash protocol updated
Changed: Renamed "Check HW" to "Check Compatibility"
! Now software check also compatibility between selected firmware and phone firmware sides
! Software will warn about any issues with incompatible combinations, which may lead to device/security damage
! in case of enforced flashing can be used "Restore Backup" to recover security data ( with enabled Security Only" option )
Changed: Backup option during flashing enforced by default
Service
Changed: "Smart Reset" rebuild
Changed: "Smart Reset Extra" rebuild
- Smart Reset Extra updated: Improved Huawei Account reset ( "old types" and "modern types" supported )
- Smart Reset Extra updated: Improved Samsung support : Reset/Change KG
! Required mode can be changed in settings tab!
- Factory Reset : FRP reset only option updated, now brand-indepedent ( If need reset FRP only, without Smart-ones )
- Factory Reset : FullFactory[1] and Factory[2] methods issues can be reset by other methods ( "No recovery command" issue )
- Factory Reset : Optimized latest firmwares-devices settings detection
Changed: Identify operation improved
Changed: Restore Backup option improved : ability to restore "security" only items instead of full range (by enabling "Security Only" checkbox)
Other
Changed: GUI changes : MemoryTool menu, Dialogs, GUI fixes on older OS types
Changed: Many importnatn internal changes, bugfixes and improvements
Changed: RPMB with "type3" supported - unique feature, see the power
#cm2, #infinityupdate
Core
MemoryTool
Flasher
Service
Other
