DFT PRO Update v7.0.9 is released
DFT PRO Update v7.0.7 is released
🔸🔸 [Xiaomi Qualcomm] 🔸🔸
🔥 WORLD FIRST 🔥
🔸🔸 Added: IMEI Repair for ALL Qualcomm Devices (Root & Original EFS Required) 🔸🔸
🔸🔸 Improved: General Bug Fixes & System Stability 🔸🔸
🔸🔸 [Xiaomi Mediatek] 🔸🔸
🔥 WORLD FIRST & EXCLUSIVE 🔥
🔸🔸 Added: Patch Cert 2026 - Mediatek Xiaomi IMEI Repair - Supported ALL Models🔸🔸
Tested Models
Xiaomi 17T Pro (warhol) tested - (ENG Firmware Required)
Redmi Note 15 Pro 4G (charoite) tested - (ENG Preloader & Eng Firmware Required)
ℹ️ This method makes it easier to repair devices with locked Bootloaders that have ENG Preloader or ENG firmware installed.
⚠️ Important Warning: If the device receives an update or if the firmware is reinstalled, the patch will be disabled/removed.
ℹ️ Note: After performing the repair process with Patch Cert 2026 while the device is in ENG mode, you must check/select the Patch Cert 2026 option under the Fastboot Flash tab.
🔸🔸 Added: Unlock BL 2026 - Mediatek Xiaomi Bootloader Unlock - Supports Most Models 🔸🔸
⚠️ CRITICAL WARNING
ℹ️ This Bootloader Unlock method is temporary or exploit-based. If you update the device OTA or flash a new firmware, the Bootloader will be LOCKED again.
🔸🔸 Bug Fixes & Improvements 🔸🔸
⚙️ System Improvement: Optimized MediaTek exploit delivery for higher success rate on 2026 security patches.
⚙️ General: Minor bug fixes and internal software optimizations.
Арзон нархда DFT Pro activation сотиб олиш 👉 www.gsmservice.uz
#dftupdate, #noneeddongle
DFT Pro Tool updates full history - mobilforum.uz
