DFT PRO Updates:
DFT PRO Update v6.7.5 is released
🔥 Spreadtrum / Unisoc Overhaul
🔸 New Chipsets & Deep Optimization:
+ Major protocol improvements for Spreadtrum devices.
+ New CPUs Added: T760, T820 support included.
🚀 Xiaomi Repair [ADB] Update
🔸 Flexible Connection & Auto Patch:
+ Dual Mode Support: Repair operations are now supported on both ENG ROM and Rooted devices.
+ Auto Opcust Patch: If the device lacks the opcust partition, the software will automatically generate it.
+ Full Support "Patch BL Lock" Added for:
- Redmi 13 (moon) tested
- Redmi Note 14 Pro / POCO X7 (malachite) tested
- Poco X7 pro (rodin)
⚙️ System Improvements
+ General bug fixes and stability improvements.
DFT PRO Update v6.7.6 is released
⚙️ Fix: Resolved the "System Destroyed" error triggered by automatic "countrycode" assignment during Fastboot firmware selection.
+ Patch Bl Lock Flash Mode
🔥 Xiaomi 15T Pro (klimt) (eng preloader required) (tested)
🔥 Xiaomi 15T (goya) (eng preloader required) (tested)
DFT PRO Update v6.7.7 is released
⚙️ Fix: Fixed "Format + Download" firmware installation bug.
Арзон нархда DFT Pro activation сотиб олиш 👉 www.gsmservice.uz
#dftupdate, #noneeddongle
DFT Pro Tool updates full history - here
DFT PRO Update v7.0.0 is released
🔸🔸🔸WORLD FIRST 🔸🔸🔸
🔸🔸Added Repair IMEI (Root Required) 🔸🔸
Xiaomi 17 Ultra (nezha)
Xiaomi 17 Pro Max (popsicle)
Xiaomi 17 Pro (pandora)
Xiaomi 17 (pudding)
Redmi K90 Pro Max / POCO F8 Ultra (myron)
🔸🔸New Addition: SELinux Set Permissive 🔸🔸
Added a new "SELinux Set Permissive" button to the Fastboot tab.
This feature allows you to obtain the necessary system permissions to easily open the Diag (Diagnostic) port.
Important Note: Due to security policies, this feature is only supported on devices with a security patch prior to February 2026.
🔸🔸 New Addition: DFTSU(Hide) Root System 🔸🔸
A new root option, DFTSU(Hide), has been integrated into the software. Create a secure root with DFTSU(Hide); root access is only enabled when you want it to be.
🔸🔸 Xiaomi Qualcomm Loader Added🔸🔸
⚠️ CRITICAL UFS WARNING
Auth Incompatible: Kioxia/Toshiba UFS chips are read-only (No write access).
✅ Safe to Flash: UFS codes starting with SK, KL, or KM.
❌ DO NOT FLASH: UFS codes starting with TH. Flashing will BRICK the device, requiring JTAG repair!
(Always check the chip code via Service Edl "Read Info" before flashing.)
Xiaomi 15 Ultra (xuanyuan)
Xiaomi 15 Pro (haotian)
Xiaomi 15 (dada)
Xiaomi MIX Flip 2 (bixi)
Redmi K80 Pro (miro)
Redmi K90 / POCO F8 Pro (annibale)
Xiaomi Pad 8 Pro (piano)
🔸🔸 Permanent Unlock Bootloader (Permanent) 🔸🔸
- The device's Bootloader is unlocked completely and permanently.
Qualcomm SM8850-AC Snapdragon 8 Elite Gen 5
Xiaomi 17 (pudding)
Qualcomm SM8750-AB Snapdragon 8 Elite
Xiaomi 15 (dada)
Xiaomi Redmi 15 / POCO M7 (creek)
Qualcomm SM8550 Snapdragon 8 Gen 2
Xiaomi 13 Ultra (ishtar)
Xiaomi 13 Pro (nuwa)
Xiaomi 13 (fuxi)
Xiaomi Mix Fold 3 (babylon)
Redmi K70 / POCO F6 Pro (vermeer)
Redmi K60 Pro (socrates)
🔸🔸 Temporary Unlock Bootloader (Temp) 🔸🔸
- The device's Bootloader is unlocked only for a temporary period via a system authorization or exploit.
* Qualcomm SM8735 Snapdragon 8s Gen 4 *
Redmi Turbo 4 Pro (onyx)
Xiaomi CIVI 5 Pro (luming)
* Qualcomm SM8650-AB Snapdragon 8 Gen 3 *
Xiaomi 14 Ultra (aurora)
Xiaomi 14 Pro (shennong)
Xiaomi 14 (houji)
Xiaomi MIX Flip (ruyi)
Xiaomi Mix Fold 4 (goku)
Redmi K70 Pro (manet)
Redmi K80 / POCO F7 Pro (zorn)
* Qualcomm SM8635 Snapdragon 8s Gen 3 *
Xiaomi CIVI 4 (chenfeng)
Redmi Turbo 3 (peridot)
* Qualcomm SM8450-SM8475 Snapdragon 8 Gen 1 *
Xiaomi 12 (cupid)
Xiaomi 12 Pro (zeus)
Redmi K50 Gaming / Poco F4 GT (ingres)
Redmi K50 Ultra (diting)
Xiaomi 12S Pro (unicorn)
* Qualcomm SM7635 Snapdragon 7s Gen 3 *
Redmi Note 14 Pro+ (amethyst)
Redmi Note 15 Pro+ 5G (flourite)
* Qualcomm SM7475-AB Snapdragon 7+ Gen 2 *
Redmi Note 12 Turbo / POCO F5 (marble)
Redmi Note 13 Pro (garnet)
* Qualcomm SM6475-AB Snapdragon 6 Gen 3 *
Redmi Note 15 5G (kunzite)
* Qualcomm SM6225 Snapdragon 685 *
Redmi Note 13 / Redmi Note 13 NFC (sapphire/sapphiren)
Redmi Note 12 4G / Redmi Note 12 4G NFC (tapas/topaz)
* Qualcomm SM4450 Snapdragon 4+ Gen 2 *
Redmi 14R 5G / POCO M7 5G / 14C 5G (flame)
Redmi Note 13R / 13 5G / POCO M6 Plus 5G (breeze)
Redmi Note 12R / 12 5G / POCO M6 Pro 5G (sky)
🔸🔸 Added QCN files for 30+ models (Repair Network) 🔸🔸
🔸Bug Fixes & Improvements:🔸
