EFT Pro Dongle Update V5.5.3 is released :
[Apple - Purple Mode]
New operations for supported Apple A12 / A13 devices,
powered by the usbliter8 RP2350 Hardware Pwner:
Apple Supported Models:
• iPhone XS
• iPhone XS Max
• iPhone XR
• iPhone 11
• iPhone 11 Pro
• iPhone 11 Pro Max
• iPhone SE (2nd generation)
• iPad Air (3rd generation)
• iPad mini (5th generation)
• iPad (8th generation)
• iPad (9th generation)
• Both operations require an RP2350-based Hardware Pwner flashed with usbliter8 firmware.
• The target device must first be placed into Pwned DFU Mode using the usbliter8 Hardware Pwner before running Boot Diag or Erase.
• Waveshare RP2350 USB-A
• Waveshare RP2350 Zero
• Pimoroni TINY2350
• Raspberry Pi Pico 2
Note: Any compatible RP2350-based board flashed with usbliter8 firmware may also be used.
1. Connect the RP2350 Hardware Pwner to the PC.
2. Put the iPhone / iPad into DFU Mode, then connect it to the RP2350 USB-A port.
3. Disconnect and reconnect the RP2350 board to the PC to start the pwn process.
4. Wait until the device is successfully placed into Pwned DFU Mode.
5. Select Boot Diag → the device boots into Apple Factory Diagnostics Mode.
6. Select Erase → a Factory-Level Wipe is triggered on the next boot.
EFT PRO 1, 3, 6 or 12 months activation сотиб олишwww.gsmservice.uz
EFT Pro updates full history - mobilforum.uz
