EFT Pro Dongle Update V4.6.8 Build 001 is released :
[APPLE]
Added Remove Icloud Open Menu with UDID (FMI OFF with UDID)Free Exclusive
Very important:
1 - Before connecting the DEVICE WITH ICLOUD to the WIFI network go to the wifi settings and configure Proxy Server: 51.178.81.232 Port:8883 (Please see instructions This IP is variable) press Save, and then connect
2 - Go from safari to "51.178.81.232:8883" (Please see instructions This IP is variable) and press download , then Allow
If IP does not open, please use VPN on iphone and try again
3 - Go to Settings General->Profile and Install the profile you downloaded
4 - Then go Settings->General->About-> scroll down and after go to Certificate Trust Settings and enable DO_NOT_TRUST
5 - Go to iCloud > Turn OFF Game Center->Then Turn ON again (only 1 times)
6-After completing the previous steps, go apple Tap select (Remove Icloud Open Menu with UDID (FMI OFF with UDID)) and click Start again
go to icloud turn on and off game center
If the process is successful, Turn OFF WiFi then check iCloud services before flashing.
Buy EFT PRO 1, 3, 6 or 12 months activation here - www.gsmservice.center
