๐Ÿš€ F64 Android App: First Stable Release!! + F64 for Windows: File Manager 2.0 update!! Version 1.07.28.2026 ๐Ÿ“…
โ”โ”โ”โ”โ”โ”โ”โ”โ”โ”โ”โ”โ”โ”โ”โ”โ”โ”โ”โ”โ”โ”โ”โ”โ”
07.28.2026 - F64 for Android: First Stable Release
07.28.2026 - F64 for Windows: File Manager 2.0
F64 for Android V2026.07.28 - Box Firmware Update is REQUIRED
(Connect to the F64 Ultra via BLE 5.0)
1. Supports UFS 4.1, 4.0, 3.1, 3.0, 2.2, 2.1 and 2.0
* FULL Partition Listing via Partition Table Explorer
* Read/Write/Erase partitions
* Reads full JEDECยฎ Information
* Quick Setting of UFS Attributes and Flags
* Android Boot Slot change
* ISP and Chip Off both supported
2. Supports UART for reading Android Boot Logs via RX/TX lines
IMPORTANT: I. eMMC is not yet supported in this version
II. The APP will only work on SoC Firmware 07.25.2026 + ASIC Firmware 07.23.2026
F64 for Windows V2026.07.28 - File Manager 2.0
1. Updated EROFS File Manager
* Added support to Delete File/Folder
* Added support to Inject FLAT_PLAIN, FLAT_INLINE files (should fit original blocks allocated)
* Added support to Extract COMPRESSED files (LZ4, LZMA, DEFLATE, ZSTD)
* Added support to Extract CHUNK_BASED files
* Added support to Inject CHUNK_BASED files (should fit original blocks allocated)
2. Updated EXT4 File Manager
* Added support to Inject files larger than the original file size
as long as the total size can still fit in the blocks allocated
3. Added F2FS Support for File Manager
* Supports File/Folder Find
* Supports File/Folder Rename
* Supports File/Folder Delete
* Supports Plain File Extract
* Supports Plain File Inject (should fit original blocks allocated)
* Supports Compressed File Extract (LZO, LZ4, ZSTD and LZO-RLE)
* Supports Compressed File Inject (should fit original blocks allocated)
* Supports File property changes (UID, GUI, R-W-X)
4. Added FAT32, FAT16 and FAT12 Support for File Manager
* Supports File Extract
* Supports File Inject (should fit original clusters allocated)
5. Added vbmeta flags setting
* Only works for phones with a bootloader that is already unlocked
* Sets AVB_VBMETA_IMAGE_FLAGS_HASHTREE_DISABLED ON/OFF
* Sets AVB_VBMETA_IMAGE_FLAGS_VERIFICATION_DISABLED ON/OFF
* Available in Dev Tools tab of the Software
6. Added option in settings to change the M-PHY differential swing on KIOXIA UFS
(Thank you Diแป‡n Nguyแป…n for testing)
7. Added support for MBR + EBR (chain) partition listing
* Used by some Smart TV (Thank you valeraะนั„ั„ and Aakash Hukpachongbang for TV Dumps)
8. Fixed UART Logging buffer overflow
9. Fixed BackupGPT write overflow when changing Android Boot Slots
10. Fixed WriteBooster Size/Type Generation on newer Snapdragon SoC
11. Added support for Android 17 ABV 1.4.0
12. Added New UART Pinouts by Giovanni Lucas Da Paz (ISP Pinouts\UART\)
Motorola Moto G73 5G XT2237-1 DEVONF Pin Mapping UART.isp
Samsung Galaxy A07 SM-A075M Pin Mapping UART.isp
Realme C30S RMX3690 Pin Mapping UART.isp
Samsung Galaxy A73 5G SM-A736B Pin Mapping UART.isp
Samsung Galaxy M14 SM-M146B - Samsung Galaxy F14 5G SM-E146B Pin Mapping UART.isp
13. Added New/Updated ISP Pinouts by Giovanni Lucas Da Paz
SM4250 EMMC.isp
Samsung Galaxy M55 SM-M556B.isp
Honor X7D LGN-LX2.isp
OPPO A6 Pro 5G CPH2781.isp
Realme C30S RMX3690.isp
REDMI 15C dew.isp
Samsung Galaxy A14 SM-A145P.isp
Samsung Galaxy A73 5G SM-A736B.isp
Flash64 full updates histiory ๐Ÿ‘‰ ัˆัƒ ะตั€ะดะฐ
Flash64 ะฑะพะบัะฝะธ ะฑัƒะณัƒะฝ ัะพั‚ะธะฑ ะพะปะธัˆ - ัˆัƒ ะตั€ะดะฐ
