F64 EROFS + EXT4 Direct File Manager V1.05.07.2026 Update!
Version 1.05.07.2026
βββββββββββββββββββββββββ
1. Added Direct File Manager for EROFS and EXT4 Partitions
* DO NOT USE THIS ON Partitions with Android Verified Boot (AVB) unless
* you know how to disable dm-verity etc...
EROFS and EXT4 Features:
1. Load via Direct Partition Mount or via img/bin files (sparsed files supported)
2. Search function for files and folders
3. Path navigation buttons back, forward and up
4. Drag and Drop Extraction of single files to Desktop or directly to other applications like HxD etc
5. Automatically opens known files via double-click (txt, xml, png etc)
6. Ability to rename files and folders
7. Ability to Replace or Edit files (Size restrictions apply)
8. Drag and Drop Injection of single files to the file system
9. Ability to change File/Folder Properties such as Owner ID, Group ID, Attributes Read/Write/Execute
EXT4 Only Features:
1. Ability to Erase Files and Folders recursively
* For EROFS, renaming a file is the same as deleting it. The OS will no longer find it.
2. Added EROS Unpacker in File Tools
* You can directly unpack sparsed files or plain binary files
3. Added MTK Preloader Information
* SoC Platform
* Compilation Date
* Boot Storage compatibility
4. Added Hua Verified Boot (HVB) (Requested by YunYi)
* Verifies Hashes of Harmony OS Partitions
5. Fixed Mi flash_all.bat file loading (Reported by Diα»n Nguyα» n)
6. Removed Debug Logs (D3 and DE)
7. Added New ISP Pinouts by Giovanni Lucas Da Paz & Fahad GSM
Samsung Galaxy A57 5G SM-A576B.isp
Samsung Galaxy S20 FE SM-G780F.isp
Samsung Galaxy S22 Ultra SM-S908U W - O - D -E.isp
Samsung Galaxy S25 FE SM-S731U - B - BE - N - W.isp
OPPO A54 CPH2239.isp
Samsung Galaxy A24 SM-A245M.isp
VIVO X200 PRO PD2405F .isp
Flash64 Π±ΠΎΠΊΡΠ½ΠΈ Π±ΡΠ³ΡΠ½ ΡΠΎΡΠΈΠ± ΠΎΠ»ΠΈΡ - hereFlash64 full updtaes histioryΡΡ Π΅ΡΠ΄Π° (https://mobilforum.uz/threads/flash64-updates.4669/)
