Gsmservice.uz : News , Новости , Янгиликлар
Gsmservice да Iphone Официал MDM ечиш хизмати кушилди !
Bypass емас ! Сервердан ечилади !
134# Iphone 7 - X MDM Removal by Serial
1049# Iphone XR - 12 Mini MDM Removal by Serial
288# Iphone 12 Pro - 14 Pro MDM Removal by Serial
421# Iphone 14 Pro Max - 15 Pro Max MDM Removal by Serial
With this service, you can remove the MDM (Corporate Lock) from your device with a 100% success rate. Please read the details carefully:
Order by Serial Number: Orders must be placed using the serial number.
MDM Removal: This service removes all corporate locks. It is not an iCloud removal service.
Incorrect Orders: Incorrect orders will not be canceled. Only models listed in the service description and devices with MDM status ON are supported.
Service Time: The service time is usually 24 hours, but please allow up to 48 hours during periods of high demand.
Activation via Wi-Fi: Once your order is complete, simply connect your device to Wi-Fi and activate it. After connecting to Wi-Fi and activating, the MDM Status will change from ON to OFF. It will not show OFF in the status check until it is activated.
Android Multi Tool Added
Lenovo TAB 4 (8) [TB-8504X] Added
Xiaomi Redmi Y3 (onc)
- Xiaomi Redmi 7 (onc)
- Xiaomi Mi 9T Pro (raphael)
- Xiaomi Redmi K20 Pro (raphael)
- Xiaomi Redmi Note 9 Pro (joyeuse)
- Xiaomi Redmi Note 9 Pro Max (excalibur)
- Xiaomi Redmi Note 9S (curtana)
- Xiaomi Redmi Note 10 Lite (curtana)
- Xiaomi Redmi Note 11 (spes)
- Xiaomi Redmi Note 11 NFC (spesn)
- Xiaomi Redmi note 12 4G (tapas)
- Xiaomi Mi 9 (cepheus)
- Xiaomi Mi 9 Explorer (cepheus)
- Xiaomi Poco X3 [ Surya ]
ZTE телефонларни Serial Number оркали текшириш хизмати кушилди
580# ZTE Info by SN
Жавоб намунаси
Model Description: P963F60/ZTE Blade A51 Mobile Phone(KZ/Channel/Pearl Grey/2+64/NFC)
Model Code: ZTE Blade A51
IMEI: 320314830768
IMEI2: 864424050071234
MSN: 320314830768
Material Code: 126593101154
Board Tracking No: 735992700976
Product Line: Oversea Mobile Phone
Production Date: 2021-07-28 19:43:29
Буюртма бериш - www.gsmservice.uz
#gsmservicenews , #zteinfo
SRS Auth Tool Version 3.0 – Stable: 05/05/2024
1. 🔄 AutoDetect and Configure Storage Type support
2. 🚀 AutoConfigure Maximum USB Transfer Speed Buffer support
3. 🛠 AutoLoader programmer for Universal devices support
4. 🎯 AutoShow Select Loader when AutoLoader isn’t available for target devices
5. 📝 AutoGenerate XML Command from GPT table support
6. ➕ Added New Protocol Gen support (AutoLoader doesn’t support this operation)
7. 📂 Added New UFS GPT parser support
8. 🔓 Added New EDL Unlock algorithm support
9. 💾 Added New Storage Info support
10. 🗑 Added New Auto Generate XML Patch Command for erase partition
SRS Auth Tool 3 , 6 or 12 Month Activation сотиб олиш - www.gsmservice.uz
#gsmservicenews , #srsauthtool, #srsauthtoolupdate
🚀 New Update Available: LU-Wifi Windows Tool (Version 2.2)
We are excited to announce the latest update for our LU-Wifi Windows Tool, packed with new features and improvements!
🔧 What's New in Version 2.2:
📱 Added Support for:
iPhone 5s, 6, 6 Plus
iPads running iOS 12.X.X
No signal bypass for the above devices.
🐛 Improvements:
Bug Fixes: Several bugs have been addressed to enhance stability and performance.
🛠 Built-in Jailbreak: Now includes a built-in jailbreak tool, streamlining the bypass process.
✨ Tool Highlights:
Supports bypass without signal for iPhone and iPads running iOS 12 to 17.
Compatible with Apple CPUs ranging from A7 to A11.
Буюртма бериш - албатта - gsmservice.uz
Japan KDDI Sharp SHV48 - Imei оркали Simlock 4 минутда ечилди !
1. 38# Japan AU / KDDI Blacklist Check текширамиз , Clean булса -
2. 548# Japan AU KDDI Generic Clean буюртма берамиз.
3. Unlocked жавоб келагндан сунг - Sim status Update киламиз - Done !
#kddiunlock, #whataboutspeed
Sony Xperia Z5 Simlock Imei оркали ечилди !
1. 133# Blacklist check ( All carriers) текширамиз , Clean булса -
2. 347# Japan NTT Docomo Generic Clean буюртма берамиз.
3. Серверда келган NCK киритамиз - Done !
Буюртма учун - www.gsmservice.uz
#docomounlock , #whataboutspeed
Янги хизматлар кушилди .
1182# iBypass Lpro Premium 5.0 - iphone 5s with Signal
1183# iBypass Lpro Premium 5.0 - iphone 6 with Signal
1184# iBypass Lpro Premium 5.0 - iphone SE, 6s, 6s+ with Signal
1185# iBypass Lpro Premium 5.0 - iphone 7, 7+ with Signal
1186# iBypass Lpro Premium 5.0 - iphone 8, 8+ with Signal
1187# iBypass Lpro Premium 5.0 - iphone X with Signal
1188# iBypass Lpro Premium 5.0 - iPad Air 1, Mini 2 , Mini 3 with Signal
1189# iBypass Lpro Premium 5.0 - iPad Air 2, Mini 4 , 2017, 2018, 2019, iPad Pro 1 10.5, Pro 2 12.9 with Signal
Эслатма :
✅ 5S, 6 - Instant bypass
✅ 6S - X - 12 - 72 соат
Reseller лар - нархни текширинглар - арзонрок топсангиз - @gsmservice_support га расмини юборинг
iBypass Lpro A12+ Сигналсиз Bypass хизматлари кушилди !
Буюртма беришдан аввал - tool га улаб - текширамиз
Supported No Signal курсатса - КЕЙИН буюртма берамиз.
Руйхатдан утиш - Instant.
Bypass килиш вакти - 1 -72 соат .
1193# iBypass Lpro A12+ No Network Bypass XR , XS , XS Max , SE2
1194# iBypass Lpro A12+ No Network Bypass 11 , 12 Mini , SE3
1195# iBypass Lpro A12+ No Network Bypass 11 Pro , 13 Mini
1196# iBypass Lpro A12+ No Network Bypass 11 Pro Max
1197# iBypass Lpro A12+ No Network Bypass 12
1198# iBypass Lpro A12+ No Network Bypass 12 Pro
1199# iBypass Lpro A12+ No Network Bypass 12 Pro Max
1200# iBypass Lpro A12+ No Network Bypass 13 Pro Max
1201# iBypass Lpro A12+ No Network Bypass 13
1202# iBypass Lpro A12+ No Network Bypass 13 Pro
1203# iBypass Lpro A12+ No Network Bypass 14
1204# iBypass Lpro A12+ No Network Bypass 14 Plus
1205# iBypass Lpro A12+ No Network Bypass 14 Pro
1206# iBypass Lpro A12+ No Network Bypass 14 Pro Max
1207# iBypass Lpro A12+ No Network Bypass 15
1208# iBypass Lpro A12+ No Network Bypass 15 Plus
1209# iBypass Lpro A12+ No Network Bypass 15 Pro
1210# iBypass Lpro A12+ No Network Bypass 15 Pro Max
Буюртма бериш - www.Gsmservice.uz
1715247874697-png.3348
Gsmservice да Янги хизматлар кушилди !
947# Realme Region Lock 1xx digit Code China Only
1190# Honor FRP Slow
1191# Realme Region Lock 1xx digit Code Worldwide
1192# Realme Imei Check
Дастур кучириш - шу ерда
Ibypass Lpro A12+ янгиликларни - каналда #ibypasslpoa12update хештэг оркали топишингиз мумкин
Gsmservice да Янги хизмат кушилди .
1211# HXRU Samsung Credit
2024 йил 26 сентябр кунига
Samsung FRP ечиш : 10 Credit
HXRU support - @hxruofficial
Gsmservice да Янги Multibrand tool активацияси кушилди
1212# Moto King Pro Activation 1 Year - 1 PC
Mdm for Motorola Adb MDM multi Brand IT admin Bypass MultiBrand FRP Xiaomi Samsung OPPO Reamle Huawei One Pus Vivo Devices Edl Mode
Official site - шу ерда (https://motokingprotool.com/)
Official telegram channel - шу ерда (https://t.me/unlockedtool)
Official telegram support - @setoxtool
MotoKingPRO 1.1.9
Added MOTO G62 Full MDM
Added MOTO G51 XT2171-1 Full MDM
Added MOTO G51 XT2171-2 Full MDM
Added MOTO G53 Full MDM
Added MOTO G30 Full MDM
Added Wipe Data Fastboot Mode Only MTK
MotoKingPRO 1.2.3
Added FRP Universal and Patch EDL Mode
Added Partition Manager
Added Qualcomm Module
Brands Suported Xiaomi Samsung Oppo Vivo Realme Huawei One Plus
MotoKingPRO 1.2.4
- Minor bug fixes
- Sync server optimization
- Added Moto Edge 40 Neo [XT2307-1]
- King MDM now supports New Security PACKS Financed
MotoKingPRO 1.2.5
- Minor bug fixes
- Fixed G84 [King Services No Found]
- Added King Bypass Security Plugin Tecno/Infinix [MTK/SPD]
- Added Disable Factory Reset
Янги 43 та iPad iRemoval pro 2.4 A12+ bypass хизмати кушилди !
1213# iRemoval Pro 2.4 - iPad Pro 13-inch M4 (A2926/A3007) NO NETWORK
1214# iRemoval Pro 2.4 - iPad ( 10th gen ) A14 (A2757/A2777) NO NETWORK
1215# iRemoval Pro 2.4 - iPad Mini ( 6th gen ) A15 (A2568/A2569) NO NETWORK
1216# iRemoval Pro 2.4 - iPad PRO 11-inch ( 3th gen ) M1 (A2301/A2459/A2460) NO NETWORK
1217# iRemoval Pro 2.4 - iPad PRO 12.9-inch ( 5th gen ) M1 (A2461/A2379/A2462) NO NETWORK
1218# iRemoval Pro 2.4 - iPad AIR ( 5th gen ) M1 (A2589/A2591) NO NETWORK
1219# iRemoval Pro 2.4 - iPad PRO 11-inch ( 4th gen ) M2 (A2435/A2761/A2762) NO NETWORK
1220# iRemoval Pro 2.4 - iPad AIR 13-inch ( M2 ) (A2903/A2904) NO NETWORK
1221# iRemoval Pro 2.4 - iPad PRO 11-inch ( 2024 ) M4 (A2837/A3006) NO NETWORK
1222# iRemoval Pro 2.4 - iPad AIR ( 4th gen ) A14 (A2324/A2072/A2325) NO NETWORK
1223# iRemoval Pro 2.4 - iPad ( 9th gen ) Cellular A13 (A2603/A2604) NO NETWORK
1224# iRemoval Pro 2.4 - iPad Cellular - iPad Pro 4th Gen 12.9-inch A12 (A2069/A2232/A2233) NO NETWORK
1225# iRemoval Pro 2.4 - iPad Pro 2nd Gen 11-inch A12 (A2068/A2230/A2231) NO NETWORK
1226# iRemoval Pro 2.4 - iPad Pro 3rd Gen 12.9-inch A12 (A2014/A1895/A1983) NO NETWORK
1227# iRemoval Pro 2.4 - iPad Pro 1st Gen 11-inch 1TB A12 (A2013/A1934/A1979) NO NETWORK
1228# iRemoval Pro 2.4 - iPad Pro 1st Gen 11-inch A12 (A2013/A1934/A1979) NO NETWORK
1229# iRemoval Pro 2.4 - iPad mini 5th Gen A12 (A2126/A2124/A2125) NO NETWORK
1230# iRemoval Pro 2.4 - iPad Air 3rd Gen A12 (A2153/A2123/A2154) NO NETWORK
1231# iRemoval Pro 2.4 - iPad 8th Gen 10.2-inch A12 (A2428/A2429/A2430) NO NETWORK
1232# iRemoval Pro 2.4 - iPad PRO 11-inch ( 1th gen WIFI )
1233# iRemoval Pro 2.4 - iPad PRO 11-inch 1TB ( 1th gen WIFI )
1233# iRemoval Pro 2.4 - iPad PRO 12.9-inch ( 3th gen WIFI )
1234# iRemoval Pro 2.4 - iPad PRO 12.9-inch ( 3th gen WIFI )
1235# iRemoval Pro 2.4 - iPad PRO 12.9-inch 1TB ( 3th gen WIFI )
1236# iRemoval Pro 2.4 - iPad PRO 11-inch ( 2th gen WIFI )
1237# iRemoval Pro 2.4 - iPad PRO 12.9-inch ( 4th gen WIFI )
1238# iRemoval Pro 2.4 - iPad Mini ( 5th gen WIFI )
1239# iRemoval Pro 2.4 - iPad AIR ( 3th gen WIFI )
1240# iRemoval Pro 2.4 - iPad ( 8th gen WIFI )
1241# iRemoval Pro 2.4 - iPad ( 9th gen WIFI )
1242# iRemoval Pro 2.4 - iPad ( 10th gen WIFI )
1243# iRemoval Pro 2.4 - iPad Mini ( 6th gen WIFI )
1244# iRemoval Pro 2.4 - iPad AIR ( 4th gen WIFI )
1245# iRemoval Pro 2.4 - iPad PRO 11-inch ( 3th gen WIFI )
1246# iRemoval Pro 2.4 - iPad PRO 11-inch 2TB ( 3th gen WIFI )
1247# iRemoval Pro 2.4 - iPad13,8 - iPad PRO 12.9-inch ( 5th gen WIFI )
1248# iRemoval Pro 2.4 - iPad13,9 - iPad PRO 12.9-inch 2TB ( 5th gen WIFI )
1249# iRemoval Pro 2.4 - iPad13,16 - iPad AIR ( 5th gen WIFI )
1250# iRemoval Pro 2.4 - iPad14,3 - iPad PRO 11-inch ( 4th gen WIFI )
1251# iRemoval Pro 2.4 - iPad14,5 - iPad PRO 12.9-inch ( 6th gen WIFI ) M2
1252# iRemoval Pro 2.4 - iPad14,8 - iPad AIR 11-inch ( M2 WIFI )
1253# iRemoval Pro 2.4 - iPad14,10 - iPad AIR 13-inch ( M2 WIFI )
1254# iRemoval Pro 2.4 - iPad16,3 - iPad Pro 11-inch ( M4 WIFI )
1255# iRemoval Pro 2.4 - iPad16,5 - iPad Pro13-inch ( M4 WIFI )
Блокланган M1, M2, M3, M4 проц Macbook дан егасини инфосини олиш хизмати кушилди
1256# LPRO M-Series Info Extractor [ Get owner info from M1, M2, M3, M4 Mac ]
1. Enter Pre-Recovery mode by pressing and holding for 10 seconds power on turned off mac
2. Press and hold for 3 seconds, LEFT CONTROL + LEFT OPTION + LEFT COMMAND + . + RIGHT SHIFT
3. Wait up to 1 min, will display File Manager
4. Save recoverydiagnose_xxxxx.tgz to external drive (pend drive)
5. Open LPRO M-Series Info Extractor and drag and drop .tgz file to the app
6. Place an order with serial number to get the info (name and last name, email, device name, user language)
Gsmservice да янги акция !
Муддати тугаган Griffin эгалари учун Super таклиф !
Gsmservice да Griffin 2 йил активацияси - 758 150 сум
Шошиламиз - акция тез орада тугаши мумкин
1257# Griffin Renew 2 Years [ Expired Accounts Only ] - Super Sale Offer- арзон нархда сотиб олиш -- www.gsmservice.uz
#gsmservicepromo
iphone Актив Менюдан icloud дан чика олмасангиз - кайтаришга шошилманг !
Серверда iPhone Open menu 3 чи хизмат кушилган !
1258# HFZ Active Menu Icloud Remove for iPhone, iPad
Honor FRP хизмат кайта ишлади !
1259# Honor FRP CIS Countries
Кулланади :
- CIS region ( буюртма беришдан аввал - регионни текширинг - 307# , "Valid in Country: AZ,BY,RU,GE,KZ,KG,MN,TJ,TM,UZ,AM " булиши керак)
