Octoplus / Octopus Box Samsung updates:
Octoplus Samsung Software v4.2.5 Release Notes:
🐙 Added Factory Reset FRP via Online Service.
🐙 Added an additional method to Unlock MDM via ADB (works for devices where #0# menu is present). You will have the choice to use the QR code or ADB.
The ADB method should be used in case you have problems with the QR code, for example, if the device does not scan the QR code, Knox 1, etc.
Octoplus Samsung Software v.4.2.6 is out!
🐙 Added support for Samsung devices with new security (2023-05-01 and above) for Unlock MDM (Apr. 2023) operation!
Note:
For Unlock MDM to work on devices with high security (2023-05-01 and above), the software disables the built-in lockscreen.
If you set up a password, pattern or PIN, the phone will NOT ask for it (it will only ask 1 time after the restart).
Banking or applications that require a password or biometrics WILL work.
You can use any third-party application to emulate lockscreen.
🐙 Improved MDM unlock operation (Apr. 2023).
For devices with security below 2023-05-01, a new unlocking method will be used.
All disadvantages of the old method have been removed:
- After the operation device will be fully functional. Smart Switch, Samsung Dex works
- You CAN perform a factory reset. The phone will NOT be re-locked
- The message “This device belongs to your organization” has been removed
- Problem with not receiving calls and notifications while screen is off, has been removed
- You CAN flash the device via download mode. We can't guarantee that the device will not be re-locked after flashing to newer firmware. It's at your own risk.
Notes:
- For safety, we disable OTA updates on the device, but you can update device using a download mode.
- Some devices do not support new method, so for them you need to use the old method.
🐙 Added the option to select the unlock method for Unlock MDM (Apr.2023) operation.
🐙 Some other improvements were introduced.
Buy Octoplus Samsung activation here - www.Gsmservice.center
#octoplussamsungupdate
Octoplus Samsung Software v4.2.6 Release Notes:
🐙 Added Reset FRP via Download Mode for:
- SM-A013F, SM-A013G, SM-A013M
- SM-A022F, SM-A022G, SM-A022M
- SM-A037F, SM-A037G, SM-A037M, SM-A037U, SM-A037U1, SM-A037W
- SM-A042F, SM-A045F, SM-A045M
- SM-A107F, SM-A107M
- SM-A125F, SM-A125M, SM-A125N, SM-A125U, SM-A125U1, SM-A125W
- SM-A136B, SM-A136U, SM-A136U1, SM-A136W, SM-A136F, SM-A136M
- SM-A215U, SM-A215U1, SM-A215W
- SM-A225F, SM-A225M, SM-A226B, SM-A226BR, SM-A226L
- SM-A315F, SM-A315G, SM-A315N
- SM-A325F, SM-A325M, SM-A325N
- SM-A326B, SM-A326BR, SM-A326K, SM-A326U, SM-A326U1, SM-A326W
- SM-A415F
- SM-C710F, SM-C7100
- SM-E225F
- SM-E426B, SM-E426S
- SM-G532F, SM-G532FD, SM-G532G, SM-G532M, SM-G532MT
- SM-G615F, SM-G615FU
- SM-M013F
- SM-M015F, SM-M015G
- SM-M017F
- SM-M022F, SM-M022FV
- SM-M022G, SM-M022M
- SM-M025F
- SM-M225FV
- SM-M325F, SM-M325FV
- SM-M326B, SM-M536B
- SM-M536S
- SM-T225
- SM-T225C, SM-T225M, SM-T225N
- SM-T227, SM-T227U
- SM-A042M
- SM-A145P
- SM-A146P
- SM-A146U
- SM-A245F, SM-A245M
- SM-A346B
- SM-A346E
- SM-A346M
- SM-T220
🐙 Improved Unlock MDM (April 2023) operation!
🐙 Added support for Android 11 if Method #2 is used. So, currently Unlock MDM (April 2023) supported for Android 11-14.
🐙 Added auto-reading of IMEI and SN. (If the software fails to do this, you will still need to enter it manually)
🐙 Improved MdmGuard stability, fixed minor bugs.
🐙 Improved Restore device operation for MTK devices.
🐙 Removed old Unlock MDM (Feb. 2022) operation.
🐙 Removed Perform OTA Update (MDM) operation.
🐙 Fixed some software crashes.
🐙 Improved Read codes operation (2023) for Qualcomm devices.
Note!
Most devices can be serviced till 31.05.2023 patch security level.
Also, you may face problem (Not found), it means that the device is locked by 16-digit codes.
Octoplus Samsung Software v4.2.8 Release Notes:
🐙 Added Reset FRP (EDL) operation for the following Samsung devices based on Qualcomm CPU via EDL Mode:
- Samsung Galaxy A05s (SM-A057F)
- Samsung Galaxy A23 (SM-A235F)
- Samsung Galaxy A23 5G (SM-A236U)
- Samsung Galaxy A42 5G (SM-A426U)
- Samsung Galaxy A52 (SM-A525F)
- Samsung Galaxy A52 5G (SM-A526U)
- Samsung Galaxy A70 2019 (SM-A705F)
- Samsung Galaxy A70 2019 (SM-A705MN)
- Samsung Galaxy A71 (SM-A715F)
- Samsung Galaxy A71 5G (SM-A716U)
- Samsung Galaxy A72 (SM-A725F)
- Samsung Galaxy A73 5G (SM-A736B)
- Samsung Galaxy Note 10 (SM-N970U)
- Samsung Galaxy Note 10 Plus (SM-N975U)
- Samsung Galaxy Note 10 Plus 5G (SM-N976V)
- Samsung Galaxy Note 20 5G (SM-N981U)
- Samsung Galaxy Note 20 Ultra 5G (SM-N986U)
- Samsung Galaxy S10 (SM-G973U)
- Samsung Galaxy S10 Plus (SM-G975U)
- Samsung Galaxy S10e (SM-G970U)
- Samsung Galaxy S20 5G (SM-G981U)
- Samsung Galaxy S20 FE 5G (SM-G781B)
- Samsung Galaxy S20 FE 5G (SM-G781U)
- Samsung Galaxy S20 FE 5G (SM-G781V)
- Samsung Galaxy S20 Plus 5G (SM-G986U)
- Samsung Galaxy S20 Ultra 5G (SM-G988U)
- Samsung Galaxy S21 5G (SM-G991U)
- Samsung Galaxy S21 FE (SM-G990B)
- Samsung Galaxy S21 FE (SM-G990U)
- Samsung Galaxy S21 Plus 5G (SM-G996U)
- Samsung Galaxy S21 Ultra 5G (SM-G998U)
- Samsung Galaxy S22 5G (SM-S901E)
- Samsung Galaxy S22 5G (SM-S901U)
- Samsung Galaxy S22 Plus 5G (SM-S906E)
- Samsung Galaxy S22 Plus 5G (SM-S906U)
- Samsung Galaxy S22 Ultra 5G (SM-S908E)
- Samsung Galaxy S22 Ultra 5G (SM-S908U)
- Samsung Galaxy S23 5G (SM-S911B)
- Samsung Galaxy S23 5G (SM-S911U)
- Samsung Galaxy S23 FE (SM-S711U)
- Samsung Galaxy S23 Plus 5G (SM-S916B)
- Samsung Galaxy S23 Plus 5G (SM-S916U)
- Samsung Galaxy S23 Ultra 5G (SM-S918B)
- Samsung Galaxy Tab A7 (SM-T500)
- Samsung Galaxy Tab A9 (SM-X210)
- Samsung Galaxy Tab A9 Plus (SM-X216B)
- Samsung Galaxy Tab S8 Ultra (SM-X900)
- Samsung Galaxy Z Flip 3 5G (SM-F711U)
- Samsung Galaxy Z Flip 4 (SM-F721U)
- Samsung Galaxy Z Flip 5 (SM-F731B)
- Samsung Galaxy Z Flip 5 (SM-F731U)
- Samsung Galaxy Z Fold 2 5G (SM-F916U)
- Samsung Galaxy Z Fold 3 5G (SM-F926B)
- Samsung Galaxy Z Fold 3 5G (SM-F926U)
- Samsung Galaxy Z Fold 4 (SM-F936B)
- Samsung Galaxy Z Fold 4 (SM-F936U)
- Samsung Galaxy Z Fold 5 (SM-F946B)
- Samsung Galaxy Z Fold 5 (SM-F946U)
Note:
You can do reset FRP (EDL) on other Samsung devices if you have a suitable loader, by selecting the General_Qualcomm model.
🐙 Added new Reset FRP (USA Carrier) operation for Samsung USA carrier devices. Tested on following the devices:
- Samsung Galaxy A03s (SM-A037U)
- Samsung Galaxy A13 (SM-A135U)
- Samsung Galaxy A14 5G (SM-A146U)
- Samsung Galaxy A50 (SM-A505U)
- Samsung Galaxy A51 (SM-A515U)
- Samsung Galaxy S21+ Plus (SM-G996U)
- Samsung Galaxy S21 FE 5G (SM-G990U)
- Samsung Galaxy S20 FE 5G(SM-G781V)
- Samsung Galaxy S20+ 5G (SM-G986U)
- Samsung Galaxy S23 (SM-S911U)
- Samsung Galaxy S23+ (SM-S916U)
- Samsung Galaxy S23 Ultra (SM-S918U)
- Samsung Galaxy Note20 5G (SM-N981U)
- Samsung Galaxy Z Fold 3 (SM-F926U)
- Samsung Galaxy Z Fold5 (SM-F946U)
- Samsung Galaxy Z Flip5 (SM-F731U)
Note:
- If your model is not on the list, you can try to perform the operation by selecting the desired General model.
🐙 Added Open Browser Link (MTP) Operation (Available only for general models).
This operation is useful if you need to get to the browser on the start page (if you have FRP, etc.).
This can also be useful for Qualcomm devices if you do not want to use the test point to switch the device to EDL mode, or the device does not switch to EDL mode in the usual way.
🐙 Improved Unlock MDM (Apr.2023) operation.
🐙 Fixed a rare problem with auto-reading of device identifiers.
🐙 Some other minor improvements were introduced.
Note: Devices with security level from 2023-12-01 and higher are not supported for MDM bypass at the moment!
Octoplus Samsung Software v4.2.9 Release Notes:
Added "Remove Lost Mode" operation for Samsung phones based on Qualcomm CPU via EDL Mode (Qualcomm 9008 Mode).
Note:
After the operation the phone will be in Download Mode, you need to re-flash the device with full stock firmware, otherwise the device will stay in Download Mode.
Added Reset FRP (EDL) operation for the following Samsung devices based on Qualcomm CPU via EDL Mode (Qualcomm 9008 Mode):
- Samsung Galaxy S21 5G (SM-G991U) (BIT A)
- Samsung Galaxy S21 5G (SM-G991W) (BIT A)
- Samsung Galaxy S21 Plus 5G (SM-G996U) (BIT A)
- Samsung Galaxy S21 Plus 5G (SM-G996W) (BIT A)
- Samsung Galaxy S21 Ultra 5G (SM-G998U) (BIT A)
- Samsung Galaxy S21 Ultra 5G (SM-G998W) (BIT A)
- Samsung Galaxy S22 (SM-S9010) (BIT 4)
- Samsung Galaxy S22 5G (SM-S901U) (BIT 4)
- Samsung Galaxy S22 5G (SM-S901W) (BIT 4)
- Samsung Galaxy S22 Plus 5G (SM-S906U) (BIT 4)
- Samsung Galaxy S22 Plus 5G (SM-S906W) (BIT 4)
- Samsung Galaxy S22 Ultra 5G (SM-S908U) (BIT 4)
- Samsung Galaxy S22 Ultra 5G (SM-S908W) (BIT 4)
- Samsung Galaxy S23 5G (SM-S911W) (BIT 2)
- Samsung Galaxy S23 FE (SM-S711U) (BIT 2)
- Samsung Galaxy S23 FE (SM-S711W) (BIT 2)
- Samsung Galaxy S23 Plus 5G (SM-S916N) (BIT 2)
- Samsung Galaxy S23 Plus 5G (SM-S916W) (BIT 2)
- Samsung Galaxy S23 Ultra 5G (SM-S918N) (BIT 2)
- Samsung Galaxy S23 Ultra 5G (SM-S918W) (BIT 2)
- Samsung Galaxy S24 (SM-S921U) (BIT 1)
- Samsung Galaxy S24 (SM-S921W) (BIT 1)
- Samsung Galaxy S24 Plus (SM-S926U) (BIT 1)
- Samsung Galaxy S24 Plus (SM-S926W) (BIT 1)
- Samsung Galaxy S24 Ultra (SM-S928B) (BIT 1)
- Samsung Galaxy S24 Ultra (SM-S928U) (BIT 1)
- Samsung Galaxy S24 Ultra (SM-S928W) (BIT 1)
- Samsung Galaxy A05s (SM-A057F) (BIT 2)
- Samsung Galaxy A23 5G (SM-A236W) (BIT 4)
- Samsung Galaxy A42 5G (SM-A426W) (BIT 7)
- Samsung Galaxy A52 5G (SM-A526B) (BIT 6)
- Samsung Galaxy A52 5G (SM-A526U) (BIT A)
- Samsung Galaxy A52 5G (SM-A526W) (BIT A)
- Samsung Galaxy A52s 5G (SM-A528B) (Bit 6)
- Samsung Galaxy A6 Plus (SM-A605F) (Bit 4)
- Samsung Galaxy A6 Plus (SM-A605G) (Bit 4)
- Samsung Galaxy A70 (SM-A705Y) (BIT 3)
- Samsung Galaxy A71 5G (SM-A716W) (BIT 9)
- Samsung Galaxy A73 5G (SM-A736B) (BIT 6)
- Samsung Galaxy A8 Star (SM-G885F) (Bit 2)
- Samsung Galaxy A80 (SM-A805) (Bit 4)
- Samsung Galaxy A8s (SM-G8870) (Bit 1)
- Samsung Galaxy A9 (SM-A920F) (Bit 1)
- Samsung Galaxy A90 (SM-A905F) (Bit 4)
- Samsung Galaxy C7 (SM-C7000) (Bit 2)
- Samsung Galaxy J2 (SM-J250F) (Bit 2)
- Samsung Galaxy J2 (SM-J250M) (Bit 5)
- Samsung Galaxy J4 Core (SM-J410F) (Bit 2)
- Samsung Galaxy J4 Core (SM-J410G) (Bit 1)
- Samsung Galaxy J4 Plus (SM-J415F) (Bit 4)
- Samsung Galaxy J4 Plus (SM-J415G) (Bit 2)
- Samsung Galaxy J6 Plus (SM-J610F) (Bit 3)
- Samsung Galaxy J6 Plus (SM-J610G) (Bit 2)
- Samsung Galaxy J8 (SM-J810F) (Bit 4)
- Samsung Galaxy J8 (SM-J810G) (Bit 2)
- Samsung Galaxy J8 (SM-J810M) (Bit 2)
- Samsung Galaxy J8 (SM-J810Y) (Bit 3)
- Samsung Galaxy M14 4G (SM-M145F) (Bit 2)
- Samsung Galaxy M55 (SM-M556B) (Bit 1)
- Samsung Galaxy Note 10 (SM-N9700) (Bit 2)
- Samsung Galaxy Note 10 (SM-N970U) (BIT 8)
- Samsung Galaxy Note 10 Plus (SM-N975U) (BIT 8)
- Samsung Galaxy Note 10 Plus (SM-N975W) (BIT 8)
- Samsung Galaxy Note 20 5G (SM-N981U) (BIT 6)
- Samsung Galaxy Note 20 5G (SM-N981W) (BIT 6)
- Samsung Galaxy Note 20 Ultra 5G (SM-N986U) (BIT 6)
- Samsung Galaxy Note 20 Ultra 5G (SM-N986W) (BIT 6)
- Samsung Galaxy Note 8 (SM-N9500) (Bit 5)
- Samsung Galaxy Note 9 (SM-N9600) (Bit 4)
- Samsung Galaxy S10 (SM-G9730) (Bit 2)
- Samsung Galaxy S10 (SM-G973U) (BIT 9)
- Samsung Galaxy S10 (SM-G973W) (BIT 9)
- Samsung Galaxy S10 Plus (SM-G9750) (Bit 4)
- Samsung Galaxy S10 Plus (SM-G975U) (BIT 9)
- Samsung Galaxy S10 Plus (SM-G975W) (BIT 9)
- Samsung Galaxy S10e (SM-G9700) (Bit 2)
- Samsung Galaxy S10e (SM-G970U) (BIT 9)
- Samsung Galaxy S10e (SM-G970W) (BIT 9)
- Samsung Galaxy S20 (SM-G981U) (BIT (BIT 8)
- Samsung Galaxy S20 (SM-G981W) (BIT (BIT 8)
- Samsung Galaxy S20 FE 5G (SM-G781U) (BIT E)
- Samsung Galaxy S20 FE 5G (SM-G781V) (BIT (BIT 8)
- Samsung Galaxy S20 FE 5G (SM-G781W) (BIT E)
- Samsung Galaxy S20 Plus 5G (SM-G986N) (Bit 1)
- Samsung Galaxy S20 Plus 5G (SM-G986U) (BIT (BIT 8)
- Samsung Galaxy S20 Plus 5G (SM-G986W) (BIT (BIT 8)
- Samsung Galaxy S20 Ultra 5G (SM-G9880) (Bit 1)
- Samsung Galaxy S20 Ultra 5G (SM-G988N) (Bit 1)
- Samsung Galaxy S20 Ultra 5G (SM-G988U) (BIT (BIT 8)
- Samsung Galaxy S20 Ultra 5G (SM-G988W) (BIT (BIT 8)
- Samsung Galaxy S8 (SC-02J) (Bit 1)
- Samsung Galaxy S8 (SM-G9500) (Bit 4)
- Samsung Galaxy S8 Plus (SC-03J) (Bit 1)
- Samsung Galaxy S8 Plus (SM-G9550) (Bit 4)
- Samsung Galaxy S9 (SM-G9600) (Bit 5)
- Samsung Galaxy S9 Plus (SM-G9650) (Bit 5)
- Samsung Galaxy Tab A 10.5 (T595) (Bit 4)
- Samsung Galaxy Tab S5e (SM-T725) (Bit 1)
- Samsung Galaxy Z Flip 3 5G (SM-F711W) (BIT 5)
- Samsung Galaxy Z Flip 4 (SM-F721B) (BIT 5)
- Samsung Galaxy Z Flip 4 (SM-F721U) (BIT 4)
- Samsung Galaxy Z Flip 4 (SM-F721W) (BIT 4)
- Samsung Galaxy Z Flip 5 (SM-F731W) (BIT 1)
- Samsung Galaxy Z Fold 2 5G (SM-F916W) (BIT 2)
- Samsung Galaxy Z Fold 3 5G (SM-F926B) (BIT 5)
- Samsung Galaxy Z Fold 3 5G (SM-F926N) (BIT 2)
- Samsung Galaxy Z Fold 3 5G (SM-F926U) (BIT 5)
- Samsung Galaxy Z Fold 3 5G (SM-F926W) (BIT 5)
- Samsung Galaxy Z Fold 4 (SM-F936N) (BIT 2)
- Samsung Galaxy Z Fold 4 (SM-F936U) (BIT 4)
- Samsung Galaxy Z Fold 4 (SM-F936W) (BIT 4)
- Samsung Galaxy Z Fold 5 (SM-F946W) (BIT 1)
Buy Octoplus Samsung activation - www.Gsmservice.center
Octoplus Samsung Software v4.3.0 Release Notes:
Added EDL loaders for the following Samsung models based on Qualcomm CPU:
- Samsung Galaxy A23 5G (SM-A236U, SM-A236W) (Bit 5)
- Samsung Galaxy A52 5G (SM-A526U, SM-A526W) (Bit C)
- Samsung Galaxy F55 (SM-E556B) (Bit 1)
- Samsung Galaxy S20 (SM-G981V) (Bit 8 )
- Samsung Galaxy S20 FE 5G (SM-G781B) (Bit 9)
- Samsung Galaxy S20 FE 5G (SM-G781V) (Bit C)
- Samsung Galaxy Z Fold 4 (SM-F936B) (Bit 5)
Octoplus Samsung Tool updates full history - here
Octoplus Samsung Software v4.3.2 Release Notes:
🐙 Improved support for security patches up to 2024-10-01 for such operations as:
- Read Codes (Feb. 2023)
- Unlock via server (Sprint)
- Unlock (Tmobile)
- Unlock (ATT)
- Read Codes (2023) (for Qualcomm)
If you have any problems during the operation, please perform a factory reset and try again.
🐙Added / Updated EDL loaders for the following Samsung devices based on Qualcomm CPU:
- Samsung Galaxy A01 (SM-A015V)
- Samsung Galaxy A01 (SM-S111DL) (Bit E)
- Samsung Galaxy A02s (SM-A025G) (Bit 7)
- Samsung Galaxy A02s (SM-A025M) (Bit 8)
- Samsung Galaxy A02s (SM-A025U) (Bit 5)
- Samsung Galaxy A02s (SM-S124DL) (Bit 8)
- Samsung Galaxy A3 Core (SM-E025F) (Bit 7)
- Samsung Galaxy A05s (SM-A057F) (Bit 4)
- Samsung Galaxy A05s (SM-A057G) (Bit 3) (Bit 4)
- Samsung Galaxy A05s (SM-A057M) (Bit 2) (Bit 5)
- Samsung Galaxy A11 (SM-A115A, SM-A115AZ)
- Samsung Galaxy A20s (SM-A207F) (Bit 5)
- Samsung Galaxy A20s (SM-A207M) (Bit 4)
- Samsung Galaxy A23 (SM-A235F) (Bit 5)
- Samsung Galaxy A23 (SM-A235M) (Bit 4)
- Samsung Galaxy A23 (SM-A235N) (Bit 5)
- Samsung Galaxy A23 (SM-A236E) (Bit 5)
- Samsung Galaxy A23 (SM-A236U, SM-A236W) (Bit 5)
- Samsung Galaxy A23 5G (SM-S236DL) (Bit 9)
- Samsung Galaxy A42 (SM-A426U) (Bit 8) (Bit 9)
- Samsung Galaxy A42 (SM-A426W) (Bit 8)
- Samsung Galaxy A52 (SM-A525F) (Bit 6)
- Samsung Galaxy A52 (SM-A525M) (Bit 6)
- Samsung Galaxy A52 (SM-A526B) (Bit 6)
- Samsung Galaxy A52 (SM-A526U, SM-A526W) (Bit C)
- Samsung Galaxy A52s (SM-A528B) (Bit 6) (Bit 9)
- Samsung Galaxy A60 (SM-A6060) (Bit 3)
- Samsung Galaxy A70 (SM-A705F) (Bit 5)
- Samsung Galaxy A70 (SM-A705MN) (Bit 5)
- Samsung Galaxy A70 (SM-A705Y) (Bit 3)
- Samsung Galaxy A71 (SM-A715F) (Bit 3) (Bit 8)
- Samsung Galaxy A71 (SM-A716U, SM-A716W) (Bit 8)
- Samsung Galaxy A72 (SM-A725F) (Bit 6)
- Samsung Galaxy A73 (SM-A736B) (Bit 6)
- Samsung Galaxy A9 (SM-A920F) (Bit 1) (Bit 7)
- Samsung Galaxy Z Flip3 (SM-F711B) (Bit 7)
- Samsung Galaxy Z Flip3 (SM-F711U, SM-F711W) (Bit 6)
- Samsung Galaxy Z Flip4 (SM-F721B) (Bit 5)
- Samsung Galaxy Z Flip4 (SM-F721U, SM-F721W) (Bit 6)
- Samsung Galaxy Z Flip 5 (SM-F731B) (Bit 3)
- Samsung Galaxy Z Flip 5 (SM-F731U, SM-F731W) (Bit 4)
- Samsung Galaxy Z Flip 5 (SM-F731N) (Bit 1) (Bit 3)
- Samsung Galaxy Z Flip 5 (SM-F741N) (Bit 1)
- Samsung Galaxy Z Fold 5 (SM-F741B) (Bit 1)
- Samsung Galaxy Z Fold 5 (SM-F741U, SM-F741W) (Bit 1)
- Samsung Galaxy Z Fold 2 (SM-F916U, SM-F916W) (Bit 2)
- Samsung Galaxy Z Fold 3 (SM-F926B) (Bit 5)
- Samsung Galaxy Z Fold 3 (SM-F926N) (Bit 2)
- Samsung Galaxy Z Fold 3 (SM-F926U, SM-F926W) (Bit 5)
- Samsung Galaxy Z Fold 4 (SM-F936B) (Bit 7) (Bit 8)
- Samsung Galaxy Z Fold 4 (SM-F936N) (Bit 2) (Bit 4)
- Samsung Galaxy Z Fold 4 (SM-F936U, SM-F936W) (Bit 4)
- Samsung Galaxy Z Fold 5 (SM-F946B) (Bit 3)
- Samsung Galaxy Z Fold 5 (SM-F946N) (Bit 3)
- Samsung Galaxy Z Fold 5 (SM-F9560) (Bit 1)
- Samsung Galaxy Z Fold 5 (SM-F946U, SM-F946W) (Bit 4)
- Samsung Galaxy Z Fold6 (SM-F956B) (Bit 1)
- Samsung Galaxy Z Fold 6 (SM-F956N) (Bit 1)
- Samsung Galaxy Z Fold6 (SM-F956U) (Bit 1)
- Samsung Galaxy S10 Lite (SM-G770F) (Bit 9)
- Samsung Galaxy S20 FE (SM-G780G) (Bit 8) (Bit C)
- Samsung Galaxy S20 (SM-G781B) (Bit 9)
- Samsung Galaxy S20 (SM-G781U) (Bit H) (Bit I)
- Samsung Galaxy S20 (SM-G781V) (Bit C) (Bit F)
- Samsung Galaxy S20 (SM-G781W) (Bit E)
- Samsung Galaxy S8 (SM-G950U) (Bit 8)
- Samsung Galaxy S9 (SM-G960U) (Bit 9)
- Samsung Galaxy S10e (SM-G970U, SM-G970W) (Bit 9)
- Samsung Galaxy S10 (SM-G973U, SM-G973W) (Bit 9)
- Samsung Galaxy S10 Plus (SM-G975U, SM-G975W) (Bit 9)
- Samsung Galaxy S10 5G (SM-G977U) (Bit 8)
- Samsung Galaxy S20 (SM-G981U, SM-G981W) (Bit 9) (Bit A)
- Samsung Galaxy S20 (SM-G981V) (Bit 8)
- Samsung Galaxy S20 Plus (SM-G986N) (Bit 1)
- Samsung Galaxy S20 Plus (SM-G986U, SM-G986W) (Bit 9) (Bit A)
- Samsung Galaxy S20 Ultra (SM-G9880) (Bit 1)
- Samsung Galaxy S20 Ultra (SM-G988N) (Bit 1)
- Samsung Galaxy S20 Ultra (SM-G988U, SM-G988W) (Bit 8) (Bit A)
- Samsung Galaxy S21 FE (SM-G990B) (Bit 6)
- Samsung Galaxy S21 FE (SM-G990U) (Bit C)
- Samsung Galaxy S21 FE (SM-G990U2) (Bit A)
- Samsung Galaxy S21 (SM-G991U, SM-G991W) (Bit C)
- Samsung Galaxy S21 Plus (SM-G996U, SM-G996W) (Bit C)
- Samsung Galaxy S21 Ultra (SM-G998U, SM-G998W) (Bit C)
- Samsung Galaxy J4 Plus (SM-J410F) (Bit 2)
- Samsung Galaxy J4 Plus (SM-J410G) (Bit 1)
- Samsung Galaxy J4 Core (SM-J415F) (Bit 4)
- Samsung Galaxy J4 Core (SM-J415G) (Bit 2)
- Samsung Galaxy M11 (SM-M115F) (Bit 5)
- Samsung Galaxy M14 (SM-M145F) (Bit 2)
- Samsung Galaxy M23 (SM-M236B) (Bit 6)
- Samsung Galaxy M23 (SM-M236L) (Bit 6)
- Samsung Galaxy M42 (SM-M426B) (Bit 7)
- Samsung Galaxy M55 (SM-M556B) (Bit 1) (Bit 3)
- Samsung Galaxy M55 (SM-M556E) (Bit 3)
- Samsung Galaxy Note8 (SM-N9500) (Bit 5)
- Samsung Galaxy Note9 (SM-N9600) (Bit 4)
- Samsung Galaxy Note10 (SM-N9700) (Bit 2)
- Samsung Galaxy Note10 (SM-N970U) (Bit 8)
- Samsung Galaxy Note10 Plus (SM-N975U, SM-N975W, SM-N976V) (Bit 8)
- Samsung Galaxy Note10+ 5G (SM-N976U) (Bit 6)
- Samsung Galaxy Note20 (SM-N981U, SM-N981W) (Bit 6) (Bit 9)
- Samsung Galaxy Note20 Ultra (SM-N986U, SM-N986W) (Bit 6) (Bit 9)
- Samsung Galaxy S21 FE (SM-S711U, SM-S711W) (Bit 2)
- Samsung Galaxy S22 (SM-S9010) (Bit 4) (Bit 7)
- Samsung Galaxy S22 (SM-S901E) (Bit 8)
- Samsung Galaxy S22 (SM-S901U, SM-S901W) (Bit 4)
- Samsung Galaxy S22 Plus (SM-S906E) (Bit 7) (Bit A)
- Samsung Galaxy S22 Plus (SM-S906U, SM-S906W) (Bit 4) (Bit 6)
- Samsung Galaxy S22 Plus (SM-S9060) (Bit 7)
- Samsung Galaxy S22 Ultra (SM-S908E) (Bit A)
- Samsung Galaxy S22 Ultra (SM-S908N) (Bit 3)
- Samsung Galaxy S22 Ultra (SM-S908U, SM-S908W) (Bit 5)
- Samsung Galaxy S22 Ultra (SM-S9080) (Bit 7)
- Samsung Galaxy S23 (SM-S911B) (Bit 5) (Bit 6)
- Samsung Galaxy S23 (SM-S911U, SM-S911W) (Bit 4)
- Samsung Galaxy S23+ (SM-S9160) (Bit 4)
- Samsung Galaxy S23 Plus (SM-S916B) (Bit 5) (Bit 6)
- Samsung Galaxy S23 Plus (SM-S916N) (Bit 2)
- Samsung Galaxy S23 Plus (SM-S916U, SM-S916W) (Bit 4)
- Samsung Galaxy S23 FE (S771U) (Bit 5)
- Samsung Galaxy S23 Ultra (SM-S9180) (Bit 3)
- Samsung Galaxy S23 Ultra (SM-S918B) (Bit 6)
- Samsung Galaxy S23 Ultra (SM-S918N) (Bit 2)
- Samsung Galaxy S23 Ultra (SM-S918U, SM-S918W) (Bit 2)
- Samsung Galaxy S24 (SM-S921U, SM-S921W) (Bit 3)
- Samsung Galaxy S24 Plus (SM-S926U, SM-S926W) (Bit 3)
- Samsung Galaxy S24 Plus (SM-S9260) (Bit 3)
- Samsung Galaxy S24 Ultra (SM-S928B) (Bit 3)
- Samsung Galaxy S24 Ultra (SM-S928N) (Bit 2) (Bit 3)
- Samsung Galaxy S24 Ultra (SM-S928U, SM-S928W) (Bit 3)
- Samsung Galaxy S24 Ultra (SM-S9280) (Bit 3)
- Samsung Galaxy S8 (SM-SC02J) (Bit 1)
- Samsung Galaxy S8 Plus (SM-SC03J) (Bit 1)
- Samsung Galaxy Tab A7 (SM-T500) (Bit 8)
- Samsung Galaxy Tab A 8.0 (SM-T290) (Bit 5)
- Samsung Galaxy Tab A 10.5 (SM-T595) (Bit 4)
- Samsung Galaxy Tab A8 (SM-X210) (Bit 1)
- Samsung Galaxy Tab A8 (SM-X216B) (Bit 1)
- Samsung Galaxy Tab S8 Ultra (SM-X900) (Bit 5)
- Samsung Galaxy Tab A9+ WiFi (SM-X210) (Bit 3)
- Samsung Galaxy Tab A9+ LTE (SM-X216B) (Bit 3)
🐙 Octoplus Samsung Tool v.5.0.0 is out! Featuring Exynos! 🐙
What`s New
🐙 Important policy changes
🐙 Added support for devices based on the Exynos processor in EUB mode. The following operations are currently available in EUB mode:
- Reset FRP (EUB)
- Remove Lost Mode (EUB)
- Remove Please Call Me (EUB)
🐙 The following models are currently supported:
Processor Exynos 3830 (Exynos 850):
- Samsung Galaxy A04s (SM-A047F)
- Samsung Galaxy A04s (SM-A047M)
- Samsung Galaxy A12 (SM-A127F, SM-A127M)
- Samsung Galaxy A13 (SM-A135F, SM-A135M, SM-A135N, SM-A135U, SM-A135U1)
- Samsung Galaxy A14 (SM-A145F, SM-A145M)
- Samsung Galaxy A21s (SM-A217F, SM-A217M, SM-A217N)
- Samsung Galaxy F13 (SM-E135F)
- Samsung Galaxy F12 (SM-F127G)
- Samsung Galaxy XCover 5 (SM-G525F, SM-G525N)
- Samsung Galaxy M12 (SM-M127F, SM-M127G, SM-M127N)
- Samsung Galaxy M13 (SM-M135F, SM-M135FU)
Processor Exynos 7920 (Exynos 980):
- Samsung Galaxy A51 5G (SM-A5160, SM-A516B, SM-A516N, SM-A516U, SM-A516U1)
- Samsung Galaxy A71 5G (SM-A7160, SM-A716B, SM-A716S)
Processor Exynos 9830 (Exynos 990):
- Samsung Galaxy S20 FE (SM-G780F)
- Samsung Galaxy S20 (SM-G980F)
- Samsung Galaxy S20 5G (SM-G981B)
- Samsung Galaxy S20+ (SM-G985F)
- Samsung Galaxy S20+ 5G (SM-G986B)
- Samsung Galaxy S20 Ultra 5G (SM-G988B)
- Samsung Galaxy Note 20 (SM-N980F)
- Samsung Galaxy Note 20 5G (SM-N981B)
- Samsung Galaxy Note 20 Ultra (SM-N985F)
- Samsung Galaxy Note 20 Ultra 5G (SM-N986B)
Processor Exynos 881 (Exynos 1280):
- Samsung Galaxy A25 5G (SM-A256B, SM-A256E, SM-A256U, SM-A256U1)
- Samsung Galaxy A33 5G (SM-A3360, SM-A336B, SM-A336E, SM-A336M)
- Samsung Galaxy A53 5G (SM-A5360, SM-A536B, SM-A536E, SM-A536N, SM-A536U, SM-A536U1, SM-A536V, SM-A536W)
- Samsung Galaxy F34 5G (SM-E346B)
- Samsung Galaxy M33 5G (SM-M336B, SM-M336BU, SM-M336K)
- Samsung Galaxy M34 5G (SM-M346B, SM-M346B1)
- Samsung Galaxy A53 5G (SM-S536DL)
Processor Exynos 8535 (Exynos 1330):
- Samsung Galaxy A14 5G (SM-A146B, SM-A146M)
- Samsung Galaxy F14 5G (SM-E146B)
- Samsung Galaxy M14 5G (SM-M146B)
Processor Exynos 8835 (Exynos 1380):
- Samsung Galaxy A26 5G (SM-A266B)
- Samsung Galaxy A35 5G (SM-A356B, SM-A356E, SM-A356U, SM-A356U1)
- Samsung Galaxy A54 5G (SM-A5460, SM-A546B, SM-A546E, SM-A546S, SM-A546U, SM-A546U1, SM-A546V, SM-A546W)
- Samsung Galaxy F54 5G (SM-E546B)
- Samsung Galaxy M35 5G (SM-M356B)
- Samsung Galaxy M54 5G (SM-M546B)
Processor Exynos 9840 (Exynos 2100):
- Samsung Galaxy S21 FE 5G (SM-G990E)
- Samsung Galaxy S21 5G (SM-G991B, SM-G991N)
- Samsung Galaxy S21 Plus 5G (SM-G996B, SM-G996N)
- Samsung Galaxy S21 Ultra 5G (SM-G998B, SM-G998N)
Note: Only devices with security below 2025-04-01 are supported.
- Samsung Galaxy A06 5G (SM-A066B) (Bit 1)
- Samsung Galaxy A06 5G (SM-A066E) (Bit 2)
- Samsung Galaxy A06 5G (SM-A066M) (Bit 2)
- Samsung Galaxy A15 (SM-A155F) (Bit 5)
- Samsung Galaxy A15 (SM-A155M) (Bit 5)
- Samsung Galaxy A15 5G (SM-A1560) (Bit 5)
- Samsung Galaxy A15 5G (SM-A156B) (Bit 5)
- Samsung Galaxy A15 5G (SM-A156E) (Bit 5)
- Samsung Galaxy A15 5G (SM-A156L) (Bit 5)
- Samsung Galaxy A15 5G (SM-A156M) (Bit 5)
- Samsung Galaxy A15 5G (SM-A156N) (Bit 2)
- Samsung Galaxy A15 5G (SM-A156U) (Bit 5)
- Samsung Galaxy A15 5G (SM-A156U1) (Bit 5)
- Samsung Galaxy A15 5G (SM-A156W) (Bit 5)
- Samsung Galaxy A15 5G (SM-S156V) (Bit 6)
- Samsung Galaxy A16 (SM-A165F) (Bit 2)
- Samsung Galaxy A16 (SM-A165M) (Bit 3)
- Samsung Galaxy A16 (SM-A165N) (Bit 2)
- Samsung Galaxy A16 (SM-S167VL) (Bit 8)
- Samsung Galaxy A16 5G (SM-A166P) (Bit 3)
- Samsung Galaxy A24 4G 2023 (SM-245F) (Bit 6)
- Samsung Galaxy A24 4G 2023 (SM-A245M) (Bit 9)
- Samsung Galaxy A24 5G (SM-A245N) (Bit 6)
- Samsung Galaxy A25 5G (SC-53F) (Bit 1)
- Samsung Galaxy A25 5G (SCG33) (Bit 1)
- Samsung Galaxy A25 5G (SM-A253Q) (Bit 1)
- Samsung Galaxy A25 5G (SM-A253Z) (Bit 1)
- Samsung Galaxy A34 (SM-A346B) (Bit 9)
- Samsung Galaxy F06 5G (SM-E066B) (Bit 1)
- Samsung Galaxy F15 5G (SM-E156B) (Bit 5)
- Samsung Galaxy F16 5G (SM-E166P) (Bit 2)
- Samsung Galaxy M06 5G (SM-M066B) (Bit 1)
- Samsung Galaxy M15 5G (SM-M156S) (Bit 4)
- Samsung Galaxy M16 5G (SM-M166P) (Bit 1)
- Samsung Galaxy Tab A9 (SM-X115N) (Bit 4)
- Samsung Galaxy Tab A9 (SM-X117) (Bit 4)
- Samsung Galaxy Tab A9 LTE (SM-X115) (Bit 3)
- Samsung Galaxy Tab A9 Wi-Fi (SM-X110) (Bit 4)
- Samsung Galaxy Tab S10 Plus (SM-X820F) (Bit 2)
- Samsung Galaxy Tab S10 Plus 5G (SM-X826) (Bit 2)
- Samsung Galaxy Tab S10 Plus 5G (SM-X826B) (Bit 2)
- Samsung Galaxy Tab S10 Plus 5G (SM-X826N) (Bit 2)
- Samsung Galaxy Tab S10 Ultra 5G (SM-X926B) (Bit 2)
- Samsung Galaxy Tab S10 Ultra Wi-Fi (SM-X920F) (Bit 2)
- Samsung Galaxy Xcover 7 (SM-G556B) (Bit 5)
🐙 Added Repair From Scatter firmware for all supported MTK devices.
- Samsung Galaxy A03 (SM-A035M)
- Samsung Galaxy A03 (SM-A035F)
- Samsung Galaxy A03 (SM-A035G)
- Samsung Galaxy A03 Core (SM-A032M)
- Samsung Galaxy Tab A8 (SM-X200)
- Samsung Galaxy A31 (SM-A315N)
- Samsung Galaxy A32 (SM-A325N)
- Samsung Galaxy Tab A7 Lite (SM-T225N)
- Samsung Galaxy A12 (SM-A125N)
- Samsung Galaxy A80 2019 (SM-A805N)
- Samsung Galaxy Tab S10 Ultra 5G (SM-X926N)
- Samsung Galaxy A42 5G (SM-A426N)
- Samsung Galaxy A52s 5G (SM-A528N)
- Samsung Galaxy A90 5G (SM-A908N)
- Samsung Galaxy Fold 5G (SM-F907N)
- Samsung Galaxy Note 20 5G (SM-N981N)
- Samsung Galaxy Note 20 Ultra 5G (SM-N986N)
- Samsung Galaxy S20 5G (SM-G981N)
- Samsung Galaxy S20+ 5G (SM-G986N)
- Samsung Galaxy S20 Lite 5G (SM-G781N)
- Samsung Galaxy S22 5G (SM-S901N)
- Samsung Galaxy S22 Plus 5G (SM-S906N)
- Samsung Galaxy S22 Ultra 5G (SM-S908N)
- Samsung Galaxy S23 5G (SM-S911N)
- Samsung Galaxy Tab A7 10.4 (SM-T505N)
- Samsung Galaxy Tab A9+ 5G (SM-X216N)
- Samsung Galaxy Z Flip 3 5G (SM-F711N)
- Samsung Galaxy Z Flip 4 5G (SM-F721N)
- Samsung Galaxy Z Flip 5 5G (SM-F731N)
- Samsung Galaxy Z Flip 5G (SM-F707N)
- Samsung Galaxy Z Flip 6 5G (SM-F741N)
- Samsung Galaxy Z Fold 2 5G (SM-F916N)
- Samsung Galaxy Z Fold 4 5G (SM-F936N)
- Samsung Galaxy Z Fold 5 5G (SM-F946N)
- Samsung Galaxy Z Fold 6 5G (SM-F956N)
- Samsung Galaxy A21s (SM-A217N)
- Samsung Galaxy A51 5G (SM-A516N)
- Samsung Galaxy XCover 5 (SM-G525N)
- Samsung Galaxy S21 5G (SM-G991N)
- Samsung Galaxy S21 Plus 5G (SM-G996N)
- Samsung Galaxy S21 Ultra 5G (SM-G998N)
- Samsung Galaxy M12 (SM-M127N)
- Samsung Galaxy A53 5G (SM-A536N)
- Samsung Galaxy A13 (SM-A135N)
- Samsung Galaxy A02s (SM-A025V) (Bit 7)
- Samsung A05s (SM-A057G) (Bit 7)
- Samsung A05s (SM-A057M) (Bit 9)
- Samsung Galaxy A23 (SM-A235F) (Bit A)
- Samsung Galaxy A23 (SM-A235N) (Bit 9)
- Samsung Galaxy A23 5G (SM-A236B) (Bit A)
- Samsung A23 5G (SM-A236M) (Bit A)
- Samsung A23 5G (SM-A236U) (Bit A)
- Samsung Galaxy A52s 5G (SM-A528N) (Bit 7)
- Samsung Galaxy Z Flip 4 (SM-F721B) (Bit A)
- Samsung Galaxy Z Flip 4 (SM-F721N) (Bit 7)
- Samsung Galaxy Z Fold 3 5G (SM-F926B) (Bit C)
- Samsung S20 FE (SM-G780G) (Bit F)
- Samsung S20 FE 5G (SM-G781N) (Bit 8)
- Samsung S20 FE 5G (SM-G781U) (Bit L)
- Samsung S20 FE 5G (SM-G781V) (Bit J)
- Samsung S20 FE 5G (SM-G781W) (Bit J)
- Samsung Galaxy A8s (SM-G8870) (Bit 7)
- Samsung Galaxy S10 (SM-G9730) (Bit 8)
- Samsung Galaxy Note 10 Plus (SM-N9750) (Bit 6)
- Samsung Galaxy S21 FE (SM-G990B2) (Bit C)
- Samsung Galaxy S21 5G (SM-G991U) (Bit F)
- Samsung Galaxy S21 Plus 5G (SM-G996U) (Bit G)
- Samsung Galaxy S21 Ultra 5G (SM-G998U) (Bit F)
- Samsung Galaxy M23 5G (SM-M236L) (Bit A)
- Samsung Galaxy M52 5G (SM-M526B) (Bit 7)
- Samsung Galaxy M52 5G (SM-M526BR) (Bit 7)
- Samsung Galaxy M55 (SM-M556E) (Bit 4)
- Samsung Note 20 5G (SM-N981N) (Bit 8)
- Samsung Note 20 5G (SM-N981U) (Bit C)
- Samsung Galaxy Note 20 Ultra 5G (SM-N9860) (Bit D)
- Samsung Note 20 Ultra 5G (SM-N986N) (Bit 8)
- Samsung Note 20 Ultra 5G (SM-N986U) (Bit C)
- Samsung Galaxy M23 5G (SM-S236DL) (Bit C)
- Samsung S22 5G (SM-S901E) (Bit C)
- Samsung Galaxy S22 5G (SM-S901N) (Bit 7)
- Samsung Galaxy S22 Plus 5G (SM-S906N) (Bit 7)
- Samsung Galaxy S22 Ultra (SM-S9080) (Bit 9)
- Samsung Galaxy S22 Ultra 5G (SM-S908N) (Bit 7)
- Samsung Galaxy Tab A7 (SM-T505) (Bit 8)
- Samsung Galaxy XCover 6 Pro (SM-G736B) (Bit A)
- Samsung Galaxy Z Fold 4 (SM-F936B) (Bit A)
- Samsung Galaxy A02s 2021 (SM-A025AZ) (Bit 7)
- Samsung Galaxy A70 2019 (SM-A705U) (Bit 3)
- Samsung Galaxy Z Flip 5 (SM-F7310) (Bit 7)
- Samsung Galaxy Z Fold 2 5G (SM-F916U1) (Bit 7)
- Samsung Galaxy S8 Light (SM-G8750) (Bit 5)
- Samsung A9 Pro (SM-G887N) (Bit 2)
- Samsung Galaxy S10 Plus (SM-G9750) (Bit 8)
- Samsung Galaxy Note 20 5G (SM-N9810) (Bit C)
- Samsung Galaxy S24 (SM-S9210) (Bit 4)
- Samsung Galaxy S22 (SC-G13) (Bit 1)
- Samsung Galaxy Tab Active Pro (SM-T540) (Bit 4)
- Samsung Tab A 10.5 (SM-T597P) (Bit 5)
- Samsung Galaxy Tab S6 10.5 (SM-T867U) (Bit A)
- Samsung Tab S8 (SM-X706B) (Bit 9)
- Samsung Tab S9 Plus (SM-X816B) (Bit 5)
- Samsung Galaxy Tab S8 Ultra 5G (SM-X906C) (Bit 9)
🐙 Octoplus Samsung Tool v.5.0.2 is out! Featuring Exynos! 🐙
Octoplus Samsung Software v5.0.2 Release Notes:
Based on user feedback, our team has introduced the new feature "Partition Manager", designed to empower advanced users with enhanced efficiency and a professional-grade experience.
It supports essential read, write, and erase functions, enabling seamless memory operations across platforms such as Exynos, Qualcomm, and MTK.
🐙 Added loaders for the following Samsung devices based on Qualcomm CPU via EDL Mode:
- Samsung Galaxy Z Flip 4 5G (SM-F7210) (Bit 8)
- Samsung Galaxy Z Flip 6 5G (SM-F7410) (Bit 2)
- Samsung Galaxy Z Fold 4 5G (SM-F9360) (Bit 8)
- Samsung Galaxy S20 FE 5G (SM-G781B) (Bit E)
- Samsung Galaxy Xcover 6 Pro 5G (SM-G736W) (Bit 8)
- Samsung Galaxy Z Fold 5 5G (SM-W9024) (Bit 7)
- Samsung Galaxy Tab A9+ 5G (SM-X216R) (Bit 1)
- Samsung Galaxy Tab S9 Ultra 5G (SM-X916B) (Bit 5)
- Samsung Galaxy Tab S9 Ultra 5G (SM-X916C) (Bit 5)
- Samsung Galaxy Tab S9 Ultra 5G (SM-X916N) (Bit 5)
- Samsung Galaxy A90 5G (SM-A9080) (Bit 5)
- Samsung Galaxy S23 5G (SC-51D) (Bit 1)
- Samsung Galaxy S24 (SC-51E) (Bit 1)
- Samsung Galaxy Tab Active 4 Pro (SM-T638U) (Bit 8)
🐙 Updated loaders for the following Samsung devices based on Qualcomm CPU via EDL Mode:
- Samsung Galaxy A52 (SM-A525F) (Bit C)
- Samsung Galaxy A52 (SM-A525M) (Bit C)
- Samsung Galaxy A72 (SM-A725M) (Bit 8)
- Samsung Galaxy F23 5G (SM-E236B) (Bit A)
- Samsung Galaxy Z Flip 3 5G (SM-F711U) (Bit D)
- Samsung Galaxy Z Fold 3 5G (SM-F926B) (Bit D)
- Samsung Galaxy Z Fold 3 5G (SM-F926N) (Bit A)
- Samsung Galaxy Z Fold 3 5G (SM-F926U) (Bit C)
- Samsung Galaxy Z Fold 6 5G (SM-F9560) (Bit 2)
- Samsung Galaxy S20 Lite 5G (SM-G781B) (Bit H)
- Samsung Galaxy S20 5G (SM-G981U) (Bit D)
- Samsung Galaxy S20 5G (SM-G981V) (Bit D)
- Samsung Galaxy S20+ 5G (SM-G986U) (Bit D)
- Samsung Galaxy S20 Ultra 5G (SM-G988U) (Bit D)
- Samsung Galaxy S21 FE 5G (SM-G990U2) (Bit F)
- Samsung Galaxy S21 FE 5G (SM-G990U) (Bit I)
- Samsung Galaxy S21 5G (SM-G991U) (Bit G)
- Samsung Galaxy S21 Ultra 5G (SM-G998U) (Bit G)
- Samsung Galaxy M23 5G (SM-M236B) (Bit A)
- Samsung Galaxy Note 20 5G (SM-N9810) (Bit E)
- Samsung Galaxy Note 20 5G (SM-N981U) (Bit D)
- Samsung Galaxy Note 20 Ultra 5G (SM-N986U) (Bit D)
- Samsung Galaxy Tab A9+ WiFi (SM-X210) (Bit 6)
- Samsung Galaxy Tab A9+ 5G (SM-X216B) (Bit 8)
- Samsung Galaxy Tab A9+ 5G (SM-X218U) (Bit 7)
- Samsung Galaxy A23 5G (SM-A236B) (Bit 8)
- Samsung Galaxy A23 5G (SM-A236M) (Bit 8)
- Samsung Galaxy S21 Ultra 5G (SM-G9980) (Bit D)
- Samsung Galaxy Tab S7 FE (SM-T733) (Bit 9)
- Samsung Galaxy Tab S9+ 5G(SM-X818U) (Bit 6)
🐙 General improvements in the Unlock MDM operation (Aug.2025).
🐙 Improvements in other operations:
Added support for latest security on 14 Android in the following operations:
Read Codes (May.2023), Read Codes (Feb.2023), Read Codes (2023), Unlock (Sprint Factory).
Fixed the error with downloading additional files in the Read Codes (Feb.2021) and EToken Bypass operations.
Octoplus FRP Tool activation сотиб олиш - www.gsmservice.uz
#octoplusfrp, #noneeddongle
Octoplus Samsung Tool v5.0.2
Octoplus Box Samsung Tool version v5.0.2 Notes
🐙 Based on user feedback, our team has introduced the new feature "Partition Manager", designed to empower advanced users with enhanced efficiency and a professional-grade experience. It supports essential read, write, and erase functions, enabling seamless memory operations across platforms such as Exynos, Qualcomm, and MTK.
🐙 Added loaders for next Samsung Devices based on Qualcomm CPU via EDL Mode:
• Samsung Galaxy Z Flip 4 5G (SM-F7210) (Bit 8)
• Samsung Galaxy Z Flip 6 5G (SM-F7410) (Bit 2)
• Samsung Galaxy Z Fold 4 5G (SM-F9360) (Bit 8)
• Samsung Galaxy S20 FE 5G (SM-G781B) (Bit E)
• Samsung Galaxy Xcover 6 Pro 5G (SM-G736W) (Bit B)
• Samsung Galaxy Z Fold 5 5G (SM-W9024) (Bit 7)
• Samsung Galaxy Tab A9+ 5G (SM-X216R) (Bit 1)
• Samsung Galaxy Tab S9 Ultra 5G (SM-X916B) (Bit 5)
• Samsung Galaxy Tab S9 Ultra 5G (SM-X916C) (Bit 5)
• Samsung Galaxy Tab S9 Ultra 5G (SM-X916N) (Bit 5)
• Samsung Galaxy A90 5G (SM-A9080) (Bit 5)
• Samsung Galaxy S23 5G (SC-51D) (Bit 1)
• Samsung Galaxy S24 (SC-51E) (Bit 1)
• Samsung Galaxy Tab Active 4 Pro (SM-T638U) (Bit 8)
🐙 Updated loaders for next Samsung Devices based on Qualcomm CPU via EDL Mode:
• Samsung Galaxy Z Flip 4 5G (SM-F7210)(Bit 8)
• Samsung Galaxy A52 (SM-A525F) (Bit C)
• Samsung Galaxy A52 (SM-A525M) (Bit C)
• Samsung Galaxy A72 (SM-A725M) (Bit B)
• Samsung Galaxy F23 5G (SM-E236B) (Bit A)
• Samsung Galaxy Z Flip 3 5G (SM-F711U) (Bit D)
• Samsung Galaxy Z Fold 3 5G (SM-F926B) (Bit D)
• Samsung Galaxy Z Fold 3 5G (SM-F926N) (Bit A)
• Samsung Galaxy Z Fold 3 5G (SM-F926U) (Bit C)
• Samsung Galaxy Z Fold 6 5G (SM-F9560) (Bit 2)
• Samsung Galaxy S20 Lite 5G (SM-G781B) (Bit H)
• Samsung Galaxy S20 5G (SM-G981U) (Bit D)
• Samsung Galaxy S20 5G (SM-G981V) (Bit D)
• Samsung Galaxy S20+ 5G (SM-G986U) (Bit D)
• Samsung Galaxy S20 Ultra 5G (SM-G988U) (Bit D)
• Samsung Galaxy S21 FE 5G (SM-G990U2) (Bit F)
• Samsung Galaxy S21 FE 5G (SM-G990U) (Bit I)
• Samsung Galaxy S21 5G (SM-G991U) (Bit G)
• Samsung Galaxy S21 Ultra 5G (SM-G998U) (Bit G)
• Samsung Galaxy M23 5G (SM-M236B) (Bit A)
• Samsung Galaxy Note 20 5G (SM-N9810) (Bit E)
• Samsung Galaxy Note 20 5G (SM-N981U) (Bit D)
• Samsung Galaxy Note 20 Ultra 5G (SM-N986U) (Bit D)
• Samsung Galaxy Tab A9+ WiFi (SM-X210) (Bit 6)
• Samsung Galaxy Tab A9+ 5G (SM-X216B) (Bit 8)
• Samsung Galaxy Tab A9+ 5G (SM-X218U) (Bit 7)
• Samsung Galaxy A23 5G (SM-A236B) (Bit B)
• Samsung Galaxy A23 5G (SM-A236M) (Bit B)
• Samsung Galaxy S21 Ultra 5G (SM-G9980) (Bit D)
• Samsung Galaxy Tab S7 FE (SM-T733) (Bit 9)
• Samsung Galaxy Tab S9+ 5G(SM-X818U) (Bit 6)
• Added support for latest security on 14 Android in the following operations: Read Codes (May.2023), Read Codes (Feb.2023), Read Codes (2023), Unlock (Sprint Factory).
• Fixed the error with downloading additional files in the Read Codes (Feb.2021) and EToken Bypass operations.
Also, here is video tutorial how to work with Partition Manager is Samsung tool
Partition Manager in Octoplus Samsung Software - Overview (
🐙 Octoplus Samsung Tool v5.0.5
Octoplus Box Samsung Tool version v5.0.5 Notes:
🐙 Added Repair Boot with factory files for devices based on such CPUs as Exynos/MTK/Qualcomm
Note: To perform this operation, open ‘Repair’ tab
🐙 Added loaders for next Samsung Devices based on MTK CPU via Brom mode:
• Samsung Galaxy A06 (SM-A065F)
• Samsung Galaxy A07 (SM-A075F)
• Samsung Galaxy A07 (SM-A075M)
• Samsung Galaxy A05s (SM-A057F) (Bit A)
• Samsung Galaxy A05s (SM-A057M) (Bit A)
• Samsung Galaxy A23 (SM-A235F) (Bit B)
• Samsung Galaxy A23 (SM-A235N) (Bit A)
• Samsung Galaxy A23 5G (SM-A236E) (Bit B)
• Samsung Galaxy A23 5G (SM-A236U) (Bit B)
• Samsung Galaxy A23 5G (SM-A236V) (Bit A)
• Samsung Galaxy Z Flip 3 5G (SM-F7110) (Bit E)
• Samsung Galaxy Z Flip 3 5G (SM-F711B) (Bit F)
• Samsung Galaxy Z Flip 3 5G (SM-F711N) (Bit B)
• Samsung Galaxy Z Flip 3 5G (SM-F711U) (Bit E)
• Samsung Galaxy Z Fold 3 5G (SM-F9260) (Bit D)
• Samsung Galaxy Z Fold 3 5G (SM-F926B) (Bit E)
• Samsung Galaxy Z Fold 3 5G (SM-F926U) (Bit D)
• Samsung Galaxy S20 FE (SM-G780G) (Bit G)
• Samsung Galaxy S20 Lite 5G (SM-G781N) (Bit C)
• Samsung Galaxy S20 Lite 5G (SM-G781U) (Bit M)
• Samsung Galaxy S20 Lite 5G (SM-G781V) (Bit K)
• Samsung Galaxy S21 FE 5G (SM-G9900) (Bit F)
• Samsung Galaxy S21 FE 5G (SM-G990B2) (Bit F)
• Samsung Galaxy S21 FE 5G (SM-G990U2) (Bit G)
• Samsung Galaxy S21 5G (SM-G991U) (Bit H)
• Samsung Galaxy S21 Plus 5G (SM-G996U) (Bit H)
• Samsung Galaxy S21 Ultra 5G (SM-G998U) (Bit H)
• Samsung Galaxy M14 (SM-M145F) (Bit 8)
• Samsung Galaxy M23 5G (SM-M236L) (Bit B)
• Samsung Galaxy Note 20 5G (SM-N981N) (Bit A)
• Samsung Galaxy Note 20 5G (SM-N981U) (Bit E)
• Samsung Galaxy Note 20 5G (SM-N9860) (Bit E)
• Samsung Galaxy Note 20 Ultra 5G (SM-N986N) (Bit A)
• Samsung Galaxy Note 20 Ultra 5G (SM-N986U) (Bit E)
• Samsung Galaxy M23 5G (SM-S236DL) (Bit D)
• Samsung Galaxy A23 5G (SM-S237VL) (Bit C)
• Samsung Galaxy S23 FE 5G (SM-S7110) (Bit 6)
• Samsung Galaxy S24 Ultra (SM-S928Q) (Bit 1)
Dongle or Digital License or Activation are already available for purchase from GsmServer Store. Ask your local dealers!
🦑 Octoplus Samsung 1 Year Digital License
🦑 Octoplus Samsung 6 Month Digital License
🦑 Octoplus Samsung 3 Month Digital License
Octoplus Samsung activation сотиб олиш - www.Gsmservice.uz
Octoplus Samsung Software v5.0.6 Release Notes:
Introducing new Samsung Carrier Relock operation!
This procedure allows you to relock your device on any operator. Available via ADB mode.
After a successful operation, your phone can be used with SIM cards from selected carriers(Max 128)*
Note: This is not unlocking, it is relocking. Your phone will still be locked, but for the operators you have selected.
Next carriers supported to relock:
- AIO, APP, CCT, CHA, DSH, TMB, TMK, USC, VZW, XAU
Supported next models (All security bits supported until today's date):
- Samsung Galaxy Z Fold 6 5G (SM-F956U)
- Samsung Galaxy Z Fold 6 5G (SM-F956U1)
- Samsung Galaxy Z Fold 7 5G (SM-F966U)
- Samsung Galaxy Z Fold 7 5G (SM-F966U1)
- Samsung Galaxy Z Flip 6 5G (SM-F741U)
- Samsung Galaxy Z Flip 6 5G (SM-F741U1)
- Samsung Galaxy Z Flip 7 5G (SM-F766U)
- Samsung Galaxy Z Flip 7 5G (SM-F766U1)
- Samsung Galaxy S24 (SM-S921U1)
- Samsung Galaxy S24 Plus (SM-S926U1)
- Samsung Galaxy S24 Ultra (SM-S928U1)
- Samsung Galaxy S25 (SM-S931U)
- Samsung Galaxy S25 (SM-S931U1)
- Samsung Galaxy S25 Plus (SM-S936U)
- Samsung Galaxy S25 Plus (SM-S936U1)
- Samsung Galaxy S25 Edge (SM-S937U)
- Samsung Galaxy S25 Edge (SM-S937U1)
- Samsung Galaxy S25 Ultra (SM-S938U)
- Samsung Galaxy S25 Ultra (SM-S938U1)
- Samsung Galaxy A26 5G (SM-A266U)
- Samsung Galaxy A26 5G (SM-A266U1)
- Samsung Galaxy A36 5G (SM-A366U)
- Samsung Galaxy A36 5G (SM-A366U1)
The maximum number of operators depends on the device.
Octoplus Samsung Tool v.5.0.7 Reset FRP Android 16
🐙 Introducing new Reset FRP method for devices based on Android 16!
• Samsung Galaxy Tab S9 5G (SM-X716B) (Bit 5)
• Samsung Galaxy Tab S9 WiFi (SM-X810) (Bit 5)
• Samsung Galaxy Tab S8 Ultra (SM-X906B) (Bit 9)
• Samsung Galaxy A23 5G (SM-A2360) (Bit B)
• Samsung Galaxy A90 5G (SM-A908N) (Bit 5)
• Samsung Galaxy C55 5G (SM-C5560) (Bit 4)
• Samsung Galaxy Z Flip (SM-F700N) (Bit 4)
• Samsung Galaxy S8 Active (SM-G892U) (Bit 7)
• Samsung Galaxy S7 (SM-G930A) (Bit A)
• Samsung Galaxy S8+ (SM-G955U) (Bit 8)
• Samsung Galaxy M55 5G (SM-M558B) (Bit 2)
• Samsung Galaxy Note 10+ 5G (SM-N976Q) (Bit 5)
• Samsung Galaxy S6 Lite 10.4 WiFi (2022) (SM-P613) (Bit 8)
• Samsung Galaxy Tab Active Pro 10.1 2019 (SM-T547) (Bit 3)
• Samsung Galaxy Tab A 10.5 2018 Wi-Fi (SM-T590) (Bit 3)
• Samsung Galaxy Tab S7+ (SM-T975) (Bit 7)
• Samsung Galaxy Tab S7+ WiFi (SM-T978U) (Bit 9)
• Samsung Galaxy Tab A 8.0 2018 (SM-T387AA) (Bit 3)
• Samsung Galaxy Tab A7 10.4 (SM-T507) (Bit 7)
• Samsung Galaxy Tab S5e 10.5 2019 (SM-T727V) (Bit 6)
• Samsung Galaxy Tab A9+ WiFi (SM-X210R) (Bit 4)
• Samsung Galaxy A05s (SM-A057G) (Bit 8)
• Samsung Galaxy A05s (SM-A057M) (Bit B)
• Samsung Galaxy A23 (SM-A235M) (Bit C)
• Samsung Galaxy A23 5G (SM-A236E) (Bit C)
• Samsung Galaxy F14 (SM-E145F) (Bit 8)
• Samsung Galaxy F23 5G (SM-E236B) (Bit B)
• Samsung Galaxy Z Flip 6 5G (SM-F741N) (Bit 2)
• Samsung Galaxy Z Fold 5 5G (SM-F946B) (Bit 5)
• Samsung Galaxy Z Fold 5 5G (SM-F946N) (Bit 5)
• Samsung Galaxy Z Fold 6 5G(SM-F956N) (Bit 2)
• Samsung Galaxy Xcover 6 Pro 5G (SM-G736U) (Bit C)
• Samsung Galaxy S20 Lite 5G (SM-G781B) (Bit I)
• Samsung Galaxy S20 Lite 5G (SM-G781W) (Bit K)
• Samsung Galaxy A8 Star (SM-G885F) (Bit 5)
• Samsung Galaxy S8 (SM-G9500) (Bit 6)
• Samsung Galaxy S21 FE 5G (SM-G990U2) (Bit H)
• Samsung Galaxy S21 5G (SM-G9910) (Bit E)
• Samsung Galaxy M23 5G (SM-M236B) (Bit B)
• Samsung Galaxy M44 5G (SM-M446K) (Bit 6)
• Samsung Galaxy Note 8 (SM-N9500) (Bit 7)
• Samsung Galaxy S6 Lite 10.4 WiFi (2022) (SM-P619) (Bit A)
• Samsung Galaxy S22 Plus 5G (SM-S9060) (Bit 9)
• Samsung Galaxy S23 Plus 5G (SM-S916N) (Bit 6)
• Samsung Galaxy Tab A 8.0 2018 (SM-T387V) (Bit 4)
• Samsung Galaxy Tab S7 FE 5G (SM-T736B) (Bit 9)
• Samsung Galaxy Tab S7 FE 5G (SM-T738U) (Bit C)
• Samsung Galaxy Tab A9+ WiFi (SM-X210) (Bit 8)
• Samsung Galaxy A02s (SM-A025U) (Bit 6)
• Samsung Galaxy A02s (SM-A025U1) (Bit 6)
• Samsung Galaxy A05s (SM-A057F) (Bit B)
• Samsung Galaxy A05s (SM-A057G) (Bit 9)
• Samsung Galaxy A05s (SM-A057M) (Bit C)
• Samsung Galaxy A23 5G (SM-A236M) (Bit C)
• Samsung Galaxy A23 5G (SM-A236U) (Bit C)
• Samsung Galaxy A23 5G (SM-A2360) (Bit C)
• Samsung Galaxy S20 Lite 5G (SM-G781U) (Bit N)
• Samsung Galaxy S21 FE 5G (SM-G9900) (Bit G)
• Samsung Galaxy S21 Plus 5G (SM-G9960) (Bit E)
• Samsung Galaxy S21 Ultra 5G (SM-G9980) (Bit E)
• Samsung Galaxy M23 5G(SM-M236BL) (Bit C)
• Samsung Galaxy A02s (SM-S124DL) (Bit C)
• Samsung Galaxy M23 5G (SM-S236DL) (Bit E)
• Samsung Galaxy A23 5G (SM-S237VL) (Bit D)
• Samsung Galaxy Tab A9+ 5G (SM-X216B) (Bit 9)
• Samsung Galaxy Tab A9+ 5G (SM-X218U) (Bit 9)
🐙 Improved Enable ADB operation for devices based on Android 16
🐙 Octoplus Samsung Tool v5.0.7.1
Octoplus Box Samsung Tool version v5.0.7.1 Notes:
🐙 Improved reset FRP for android 16
Dongle (https://gsmserver.com/en/octoplus-samsung-dongle/) or Digital License (https://gsmserver.com/en/octoplus-samsung-1-year-digital-license/) or Activation (https://gsmserver.com/en/octoplus-samsung-activation/) are already available for purchase from GsmServer Store (https://gsmserver.com/en/search/?searchword=Octoplus). Ask your local dealers!
🐙 Octoplus Samsung Tool v.5.0.8.3 (Silent update)
🐙 Octoplus Box Samsung Tool version v.5.0.8.3 (Silent update) Test Notes:
🐙 A new operation, Unlock MDM (Dec. 2025), has been added. It supports Samsung devices running Android 11-16 and any security patch (available today).
🐙After this operation, the device can be reset to factory settings. The device will NOT be re-locked.
🐙OTA updates are also available. However, we do not recommend updating the device after this operation, as we cannot guarantee that the device will not be re-locked with new firmware.
Notes:
🐙 We are aware that not all devices work reliably with this method, and there are cases of re-locking within 3-7 days. If you don't want to risk it, use the Unlock MDM (Completed) method. Without factory reset, but stable.
🐙 This operation works with the previous Unlock MDM (Aug.2025). If you’ve already completed that operation, you can run this one (including all attempts) for free.
General changes:
🐙 Previous Unlock MDM (Aug.2025) was renamed to Bypass MDM (Aug.2025) for better understanding.
🐙 Other minor bug fixes and improvements.
Octoplus Samsung Tool v.5.0.8.4 (Silent update)
🐙 Octoplus Box Samsung Tool version v.5.0.8.4 (Silent update) Test Notes:
🐙 Fixed a bug with payload writing in the Carrier Relock operation.
🐙 Added the ability to select an entire country instead of individual operators in the Carrier Relock operation.
🐙 Improved the Cancel button; it will now work significantly faster in certain situations.
🐙 Improved software display on high-resolution screens. (If you still experience issues with overlapping text or poor display, please contact us.)
🐙Updated loaders for next Samsung Devices based on Qualcomm CPU via EDL Mode:
• Samsung Galaxy Z Flip (SM-F7000) (Bit B)
• Samsung Galaxy Z Fold 2 5G (SM-F9160) (Bit 8)
• Samsung Galaxy S20 Lite 5G (SM-G781N) (Bit D)
• Samsung Galaxy S20 Lite 5G (SM-G781V) (Bit L)
• Samsung Galaxy S20 Lite 5G (SM-G781W) (Bit L)
• Samsung Galaxy S21 FE 5G (SM-G990U2) (Bit I)
• Samsung Galaxy M23 5G (SM-M236B) (Bit C)
• Samsung Galaxy Tab Active 4 Pro (SM-T636B) (Bit 9)
• Samsung Galaxy Tab Active 4 Pro (SM-T636U) (Bit 9)
• Samsung Galaxy Tab S7 FE (SM-T735) (Bit 9)
• Samsung Galaxy Z Fold 4 5G (SM-W9023) (Bit 8)
• Samsung Galaxy Tab A9+ 5G (SM-X216C) (Bit 9)
• Samsung Galaxy Tab A9+ 5G (SM-X216N) (Bit 9)
Octoplus Samsung Tool v.5.0.9.2
🐙 Changes in Unlock MDM (Completed):
• Temporarily disabled support for the SM-A175F model.
• Fixed a bug where the Google Play Store was missing on some devices after the operation.
