UMTv2/UMT Pro UltimateMTK2 v1.3 - MTK V6, Realme 11x, 12x, Oppo Find X6...
Added MTK V6 Protocol Support
- MT6789
- MT6835
- MT6895
- MT6983
- MT6985
- Read/Write Flash
- Reset FRP
- Format Userdata
- Safe Format
Added Oppo/Realme MT6835 Preloader Exploit (Oppo V2)
- Realme 11 5G
- Realme 11x 5G
- Realme 12x 5G
- Realme 12 5G
Added Oppo/Realme MT6985 Preloaer Exploit (Oppo V2)
- Oppo Find N3 Flip
- Oppo Find X6
Added Oppo Dl Fix (Download Error)
- PACM00
- PACT00
- PCAM10
- PCEM00
- PDBM00
- RMX1825
- RMX1945
- RMX2020
- RMX2027
- RMX2185
- RMX3061
- RMX3202
- RMX3230
- RMX3430
Added Support for Scatter in XML Format
Fixed DA Config Error for MT6983
Fixed DA Config Error for MT6789
Fixed Boot Config Issue causing no Exploit to run on some functions
Some Minor Improvements
Арзон нархда UMT (Box/Dongle) 1 Year Activation сотиб олиш - www.gsmservice.uz
