UMTv2/UMTPro UltimateMTK2 v1.7 - Enable ADB from META and more...
Added Infinix/Tecno/iTel Enable ADB in META mode
- You can use this function to Enable ADB.
- Once ADB is Enabled you can use functions in Infinix/Tecno/iTel Group.
Added Infinix/Tecno/iTel (ADB) Functions:
- Disable Locks (ADB)
- Enable Locks (ADB)
- Reset FRP (ADB)
- You can enable ADB using Enable ADB (Infinix) from META Functions.
Updated Erase Userdata
- Now it should not cause Checksum Error on phone startup.
Added Reset Locks (Vivo) in Format Functions
- You don't need to use Old Module to do that anymore
Some UI Changes
Арзон нархда UMT (Box/Dongle) 1 Year Activation сотиб олиш 👉 www.gsmservice.uz
