AndroidWinTool updates
Official site - here
Version 1.0.0
Qualcomm
EDL Mode:
- QC Sahara V3 Protocol:
- Supported QC Sahara V3 protocol.
- Auto-select Programmer (excluding Sahara V3 support).
- Support for all filesystem types (ext4, erofs).
- QC EDL Universal Flasher:
- Safe speed flashing.
- Full erase functionality.
- EFS protection (IMEI).
- Backup EFS (IMEI).
- Rooting support.
- Reset MI ID/FRP.
- QC EDL Partition Manager:
- Create Rawprogram.
- Dump, write, erase partitions.
- Full firmware backup.
- QC EDL Services:
- Reset FRP.
- Reset EFS.
- Backup and restore EFS.
- Root device.
- OEM unlock.
- Factory reset.
DIAG Mode:
- Diagnostic information support.
- IMEI repair:
- QC method.
- NV method.
- MAC address repair.
- Backup and restore QCN, xQCN.
ADB Mode:
- Universal ADB commands.
- EFS reset (Root/TWRP).
- Backup and restore EFS (Root/TWRP).
- Reset MI ID/FRP (TWRP).
- Root and unroot device (TWRP).
QCN Editor:
- View QCN information.
- Patch NV [SIM1 and SIM2].
- Repair damaged item files.
- IMEI and MAC repair.
### Xiaomi
EDL Mode:
- Xiaomi EDL Flasher (via SigKey).
- Xiaomi Fastboot Flasher:
- Root device.
- Bypass MI ID/FRP.
- Disable Verity/Verification.
- Disable anti-rollback check.
- Disable CRC check.
- Fix GPT (bootloop).
### Root
Magisk 27.0:
- AVB/dm-verity disable.
- Keep force encryption.
- Set recovery mode.
- Patch Vbmeta flags.
- Manual root process.
- Root and unroot device (ADB/TWRP).
- Restore patched image.
- Sign AVB 1.0 image.
### ADB - Fastboot
- Universal ADB and Fastboot commands.
ADB Partition Manager (ADB/TWRP):
- List partitions.
Fastboot Partition Manager:
- List partitions.
- Write, erase partitions.
If any error problem happens please send mail to support@androidwintool.com ⁠
## Version 1.0.1
- Fixed various bugs and improved overall stability.
## Version 1.0.2
Version 1.0.6 Update
•⁠ ⁠⁠Added completely free iOS MDM BYPASS without Jailbreak!
•⁠ ⁠⁠Fixed various bugs and improved overall stability.
Please note that, every user must register again to use software.
Version 1.0.7 Update
- Added more than 200 Xiaomi models for remove root auto & make root auto ( with server )
AndroidWinTool ( AWT ) Version 1.0.8 Update 🔥
Key feature is now we are support iCloud FMI OFF with backup method.
- iOS FMI OFF Method for menu active devices added.
- Adb Partition Write Fix.
- Fastboot Partition List Fix.
- ⁠⁠Fixed various bugs and improved overall stability. ⁠
AndroidWinTool ( AWT ) Version 1.1.0 Update 🔥
- Login error on some computes has been fixed.
AndroidWinTool ( AWT ) Version 1.1.1 Update 🔥
- Fix Boot Patcher (Root) Magisk 27.0
AndroidWinTool ( AWT ) Version 1.1.2 Update 🔥
AndroidWinTool ( AWT ) Version 1.1.3 Update 🔥
- Login Stuck Fix.
- Added every user 7 day extra for this login problems.
AndroidWinTool 1.1.4 Out!
- Free Xiaomi All Model FRP ( Google Account ) Remove
- Free Xiaomi All Model Fastboot to EDL
- Added Xiaomi Mediatek V5 - V6 Firmware Flash - BETA.
- Added Xiaomi Adb Auto Update (OTA) Disable.
- Added Xiaomi Adb Mi Account Disable.
- Added Xiaomi Redmi 8a Pro (Olivewood) Network Repair.
AndroidWinTool 1.1.5 Out!
- Added Xiaomi Critical_Info Read on Mediatek and Qualcomm.
* Mediatek devices requires enginering ( factory ) rom for writing or reading critical.
AndroidWinTool 1, 3 , 12 months activation сотиб олиш - 👉 www.gsmservice.uz
#androidwintoolupdate , #awtmainfaq , #noneeddongle
AndroidWinTool 1.1.7 Out!
- Added support for ENG Preloader Critical_Info Read & Write
- ⁠⁠Fixed Read,Write Critical_Info (Meta Mode,ETS Mode,Diag Mode).
AndroidWinTool 1.1.8 Out!
- Improved support for Qualcomm Critical_Info Read & Write
AndroidWinTool 1.1.9 Out!
- Improved support for Redmi 14C series on ETS, Preloader mode.
- Added auto disconnect and disconnect checkbox for critical_info read write operations.
AndroidWinTool 1.2.0 Out!
- Added Samsung FRP remove with IMEI or SN services. Credit based operation, consume credits on each operation.
- Fixed Xuanyuan model fastboot eng rom flash, now support multiple hwid based images flash.
AndroidWinTool 1.2.3 Out!
- Redmi Note 14 Pro+ ( amethyst ) eng rom flash from EDL mode fixed, now support different locations for images. This operation requires authorization blob which is not provided by AndroidWinTool.
- Solution for Xiaomi 15 ( dada ) destroyed after flashing engineering rom is added.
- Qualcomm EDL Userdata empty area flashing fixed.
AndroidWinTool 1.2.5 Out! - FREE Unlimited CPID
- Xiaomi, Redmi, Poco IMEI REPAIR by Official Server ( CPID ) has been added for free. 0 CREDIT! This method support all Mediatek, Qualcomm CPU's but some devices may require engineering firmware.
- Xiaomi, Redmi, Poco FRP and Fastboot to EDL servers has been improved, we hope future more stable times.
- Login improved for all type of computers. If any issue happens we will be here for almost every minute
#androidwintoolupdate , #noneeddongle
AndroidWinTool 1.2.6 Out! - Improved Fastboot Flashing
- Xiaomi Fastboot flashing improved for Xiaomi 14T ( degas ), Xiaomi 14T Pro ( rothko ) and improved for all other mediatek models.
AndroidWinTool 1.2.7 Out! - Dual SIM Xiaomi CPID Added
- Added dual sim custom support for Xiaomi IMEI CPID. This operation requires 30* credits.
*Credit pricing can be change anytime before each operation AndroidWinTool will show to user credit consumption for each operation.
AndroidWinTool 1.3.4 Out! - FREE Infinix, iTel, Tecno FRP Special Method!
- Added free special mediatek cpu FRP Reset method for Infinix, iTel and Tecno.
Why it's special ?
Tested on latest software versions of Infinix Smart 9 and Infinix Note 50 Pro both done without any error.
AndroidWinTool 1.3.5 Out! - NvRam & NvData Editor !
- Added nvdata, nvram editor for 4G MTK devices. This feature automatically detect the file and repair IMEI data inside the file gives the user clear output.
*This method may not work on some devices because of extra security.
AndroidWinTool 1.3.6 Out! - Android App Manager !
- Added ADB App Manager.
AndroidWinTool 1.3.7 Out! - NvRam Editor for MediaTek 5G Xiaomi
- Added WORLD FIRST IMEI REPAIR method for all Xiaomi Mediatek 5G CPU models. Requires NvRam file and BETA.
This method is first in the world. It may support or not support some models as BETA function. We are here to update and improve stability you can contact us from Official Whatsapp for any issue or unsupported model
AndroidWinTool Price Change for Xiaomi CPID
- Xiaomi SIM1 Random, SIM2 custom CPID if device connected 0 credit.
- Xiaomi Advanced CPID now 1 credits.
- SIM1 Custom, SIM2 custom IMEI now 17 credits.
AndroidWinTool 1.3.9 Out! - World First Redmi A5 ( serenity ) IMEI REPAIR by Server - 0 CREDIT
- Added WORLD FIRST IMEI REPAIR method for Xiaomi Redmi A5 ( serenity ) this method works with server may close in future. This method also supports update, firmware re-install / flash, factory reset!
This procedure requires engineering ( factory ) firmware.
AndroidWinTool 1.4.1 Out! - World First Redmi A3x ( klein ) IMEI REPAIR by Server - 0 CREDIT
-⁠ Added Xiaomi Redmi A3x (klein) IMEI REPAIR by Server ( World First ) requires server for repair no take credit SIM2 only. Device must be installed engineering ( factory ) firmware. After flash stock rom, update or factory reset IMEI no lose.
- iOS FMI OFF Method for menu active devices updated.
AndroidWinTool 1.4.2 Out! - Infinix, iTel, Tecno Anti-Crack Fix - 10 CREDIT
- Update Infinix Anti-Crack operation.
This operation now requires credits due to changes outside our control.
We apologize for the inconvenience and thank you for your support.
It may become free again in the future.
This is limited time only for solve request shortly back normal as free.
AndroidWinTool 1, 3 , 12 months activation сотиб олиш 👉 www.gsmservice.uz
AndroidWinTool 1.5.1 Out! Improvements & Bugs Fixed
•⁠ ⁠Improved Xiaomi CPID operations.
•⁠ ⁠Added uninstall application on screen for Android devices which has virus.
•⁠ ⁠Added loaders for Samsung devices on EDL mode.
A025V BIT-7
A057G BIT-7
A057M BIT-9
A235F BIT-A
A235N BIT-9
A236B BIT-A
A236M BIT-A
A236U BIT-A
A528N BIT-7
A705U BIT-3
F721B BIT-A
F721N BIT-7
F7310 BIT-7
F936B BIT-A
F936N BIT-6
G736B BIT-A
G780G BIT-F
G781B BIT-G
G781N BIT-B
G781U BIT-L
G781V BIT-J
G781W BIT-J
G887N BIT-2
M236L BIT-A
M526B BIT-7
M526BR BIT-7
N981N BIT-8
N981U BIT-C
N9860 BIT-D
N986N BIT-8
N986U BIT-C
S901E BIT-C
S901N BIT-7
S9080 BIT-9
T597P BIT-5
T820 BIT-3
X706B BIT-9
X816B BIT-5
Download with Mediafire
AndroidWinTool 1.5.5 Out! Improvements & Bugs Fixed
•⁠ Added Mediatek Flash Mode Critical File read / write.
•⁠ Added Xiaomi Mediatek IMEI REPAIR by CPID on flash mode. Requires eng preloader works with server.
•⁠ Improved CPID, fixed errors.
AndroidWinTool 1.7.4 Out! - Xiaomi MTK No Auth No ENG Direct CPID 0 Credit*
- Added CPID without auth (no eng preloader, no eng rom) Xiaomi Mediatek Models.
- Added Reboot to META from MTK USB Port for Xiaomi Models.
*Xiaomi Mediatek CPU devices ( most of them ) currently not require auth flash or eng rom for CPID. Just need to connect device MTK USB Port and wait for our software to process.
Best Regards
Buy AndroidWinTool 1, 3 , 12 months activation 👉 www.gsmservice.center
AndroidWinTool 1.7.8 Out! - MediaTek Anti Crack & CPID Improved ( NEED REINSTALL APP )
- Added Infinix,Itel FRP reset.
- Meta Mode tool close problem is fixed.
- Updated Infinix,Itel Anti-Crack for support more MediaTek devices.
- Updated support for Xiaomi Mediatek devices META Mode CPID now support NVData corrupted devices.
- Updated support for critical data writing on Xiaomi Mediatek devices.
- Fixed various bugs and improved overall stability. ⁠
Please uninstall ( remove ) application fully reboot pc and use latest exe.
