Infinity CM2 Manuals, Tips and Tricks
Gsmservice Support
Staff member
Premium
How to reset MDM, payjoy, easybuy etc.
Run Infinity #CM2MT2 or #CM2SP3
Step 1: Select SoC and model name and make [Connect]
Step 2: Click to [Service] tab and Unlock Bootloader
Continue with next steps ONLY if Bootloader unlocked well!
Step 3:
Be sure [Apply] is selected and click to [MDM] button
Step 4: Insert SIM Card, Power device On and Connect to WiFi or to Mobile Network
Now wait some time and be sure that device is not relocked
If you are not lucky and device become relocked after it was connected to Network - use [AppTool] as per steps below.
Gsmservice Support
Staff member
Premium
Use CM2 [AppTool] and find ADMIN APP that makes device locked:
1. Click to [Connect]
2.
Go to [AppTool]
3.
Click to [Load Apps]
4. Find App by it's name, you have to have Fantasy and some free time to check Apps one-by-one
5.[/B] Make App On [v] or Off [ ]
6.
Click to [Apply]
Disconnect device and check it after you disable each App.
Do not disable many Apps at once, you have to be sure what App make device locked.
Gsmservice Support
Staff member
Premium
If you got device damaged after flashing with unknown MDM file and there is No Outgoing Calls or No Incoming Calls make this:
MTK - set new PSN or make steps below:
- Open [MemoryTool]
- Backup proinfo partition
- Erase proinfo partition
SPD/Unisoc - set new PSN or make steps below:
- Open [MemTool]
- Backup miscdata partition
- Erase miscdata partition
- Unlock Bootloader
Gsmservice Support
Staff member
Premium
[AppTool] has the same functionality for CM2SP3 and for CM2MT2
[AppTool] features:
- Print list of available/installed APK
- Disable any (even system) APK pernamemntly
- Disabled APK stay disabled even after Reset or Wipe
- Save list of installed APK to file
- Restore disabled APK back anytime
- Extremely fast processing
What you can do with [AppTool]
- OTA On/Off
- MDM/Admin Apps On/Off
- Bloatware/Telemetry/Spy Apps On/Off
- Network/Operator addons On/Off
- And many more features depends on your fantasy
Bootloader must be unlocked for this operation!
As a first step - unlock Bootloader.
Try to Power set On after that. If Bootloadr unlocked well - you can continue with [AppTool]
How to use CM2 [AppTool]
1.
Click to [Connect]
2.
Go to [AppTool]
3.
4. Make App On [v] or Off [ ]
5.
Click to [Apply]
Gsmservice Support
Staff member
Premium
#CM2MT2 v2.58 has more features that helps to find/jump to disabled Apps.
Make right mouse click to see menu with command.
Gsmservice Support
Staff member
Premium
How to use #CM2MT2 and #CM2SP3 [MMC EOL Reset]
[MMC EOL Reset] function may extend lifetime and repair faulty EMMC chip.
You can try this option if device comes to permanent bootlop and lifetime report says EMMC is out of order.
There is no guarantee that it helps but in case of completely dead EMMC you lost nothing anyway.
REMEMBER: all data will be lost after this operation!
YouTube Video with theory
One Click [EMMC EOL Reset] is in [MemTool] Right Mouse Click menu
or as a separate button
