UMTv2/UMTPro updates
NewsMaker
Staff member
Official site - here
Credit consumption - here
Official Support - here
Need dongle
UMTv2 / UMTPro - QcFire v6.5
Added
Asus
- ZenFone Live L1 (ZA550KL_X00RD)
LYF
- F320B
- SM-A015F
- SM-A015F/DS
- SM-A015G
- SM-A015G/DS
- SM-A015M
- SM-A015M/DS
- SM-A015T1
- SM-M015F
- SM-M015F/DS
- SM-M015G
- SM-M015G/DS
- SM-S111DL
Vivo
- Z1x (PD1921F) (Vivo Heuristic)
Updated Nokia NB0 Flasher
- Added option to Format/FRP witout flashing anything.
- Just load NB0 firmware, unselect all parts, and tick Format/FRP
- Useful if loader not found in Internal Database, and you have NB0 firmware.
- Use Pakcage Loader is now selected by default for better compatibilty.
- Reset FRP on Finish is now selected by default.
Updated OFP Extracter
- Added Support for newer OFP format
- Fixed extraction issue for some OFP files ie. CPH1611
Updated Vivo Heuristic Method
- Added option Always use Erase Method even if Alt. Write Method is allowed.
- Should be useful for Vivo V19 or other devices with Wait a second issue after format.
NewsMaker
Staff member
UMTv2/UMTPro UltimateMTK v4.5 - MTK Bootloader Unlock, New SOCs and more..
Added:
MTK One Click
- No need to select any model.
- No need to select any DA/preloader.
- Simply tick required options and execute.
Updated DAA/SBA/SLA Bypass Method:
- MT6261
- MT6572
- MT6580
- MT6582
- MT6735
- MT6737
- MT6739
- MT6753
- MT6755
- MT6757
- MT6761
- MT6763
- MT6765
- MT6768
- MT6771
- MT6779
- MT6785
- MT6795
- MT6797
- MT6799
- MT6873
- MT8127
- MT8163
- MT8173
- MT8695
- MT6885
- MT6595
- MT8167
Added DAA/SBA/SLA Bypass:
- MT6592
- MT6833 (Dimensity 700 5G)
- MT6853 (Dimensity 720 5G)
- MT8590
Added Bootloader Unlock/Relock
- MT6765
- MT6768
- MT6771
- MT6779
- MT6883
- These are tested ones, many others already supported.
Updated New Security Bypass method
- This method is more faster than previous one.
- You need to use new driver for this version.
- Please use intall driver if you face driver issue.
- Incase of driver installation failure, uninstall libusb and UsbK drivers.
Updated Super Partition Parsing to show phone information properly.
Fixed bug which caused error if you selected Custom DA from other folders.
Fixed bug with OFP file extraction.
NewsMaker
Staff member
UMTv2/UMTPro UltimateMTK v4.6 - Vivo Security Repair,RPMB Read/Write etc..
Added RPMB Read/Write
Added Vivo IMEI/MEID/Serial Repair
Added Permanent Bootloader Unlock (Redmi6/6A)
Updated Bootloader Unlock/Relock Functions
- Should be faster and more reliable now
Updated SLA/DAA Auth Bypass
- Now no need of UsbDk, libusb0 is good enough
- Please remove UsbDk and Install filter driver from software
Updated MTK One Click functions
- Format FS should now use another method automatically if normal method failed
- Reset FRP improved to work more better
- Added second method for Vivo Factory Reset
Updated Flash Function
- Flashing should work more stable now
- Fixed issue with cust partition flashing on Xiaomi Devices
Fixed Crash Preloader Bug in last version
MTK One Click supports most phones regardless of Brand and Model
#nckdongle
NewsMaker
Staff member
UMTv2 / UMTPro QcFire v7.5 - Redmi Note 8 Bl Unlock, Nord N10 5G and more.
Added:
OnePlus
- OnePlus Nord N10 5G
Xiaomi
- Mi 8SE (Test Loader, may need auth)
- Mi 10T / 10T Pro (Needs Auth)
Added Bl Unlock Patch for Redmi Note8
Updated Bl Unlock in Fastboot
- Software will auto try Flashing Unlock method if Oem Unlock fails
Restored Fix 9008 Port on user requests
- Use this option only if you know what you are doing
- Mostly it is used after changing eMMC etc.
Added Read Info on Flash
- It is to keep note of firmware on device before you flashed
Fixed "not a valid integer value" Error
Improved Booting Function
#umtupdate
NewsMaker
Staff member
UMTv2/UMTPro UltimateMTK v5.0 - Backup / Restore Security,Custom Preloader
Added Custom Preloader selection
- Some Realme and Oppo seems to have different memory region for preloader mapping
- If software could not dump preloader, you can use this option for custom preloader
- Software will ignore preloader from device when custom preloader is selected
Added Backup Security (Partition Manager)
- No need to manually select required partition to backup
- Use this option to simply read critical partitions
- You can use this backup to restore device security in some cases, like whole chip format
Added Restore Security (Partition Manager)
- You can restore critical data in case you accidentally formatted whole flash
- Usefull to restore critical partitions to original state
Added Format NVRAM/NVDATA (MTK One Click)
- Use this option for all SOCs supported by MTK One Click
- It is recommended to use Backup Securtiy before, as all calibration data will be lost
Updated Write Function
- Some SOCs like 6765, 6768 had write error sometimes
- Now this is fixed and should work fine
Updated Flashing Routine
- Improved Scatter file handling
- Improved customization of default files loaded
- Rewritten code to eliminate illegal index issue
- Tested on Oppo F17 Pro, Oppo F15 and Redmi Note 10 5G
Improved Read Preloader
- Adjusted timeout to eliminate any port issue in preloader read
- If it still could not read from a phone, it may be due to new security
- In such case, please use custom preloader
#umt
Added Following SOCs in Platform Selection
- MT6833
- MT6853
NewsMaker
Staff member
UMTv2/UMTPro Samsung v0.4 - FRP Reset over MTP Port and more...
- Enable ADB over MTP/Modem Port - NEW!
Note : Some features are device/brand specific, may not work on all devices.
Whats New:
Added Enable ADB Option
- Click on emergency call and enter *#0*#
- Click on Bypass and it will auto enable ADB and remove FRP.
- You may need to do Factory Reset from Settings later.
- Your device may not be supported if *#0*# does not work in Emergency Call.
Updated Comport Routine
- Improved read write function
- Now communication should be more reliable and stable
Some minor bug fixes
#umtpro , #umtproupdate
NewsMaker
Staff member
UMTv2/UMTPro QcFire v7.8 - Huawei, Realme, Honor and more...
- Huawei ID Reset - NEW!!!
Added:
Honor
- 50 Lite (NTN-L22)
Huawei
- Nova 9 (NAM-AL00)
- Nova 9 (NAM-LX9)
- Nova 9 Pro (RTE-AL00)
Realme
- X2 Pro (RMX1931)
- X3 (RMX2083)
- X3 SuperZoom (RMX2085)
Added Huawei ID Reset (Beta)
- Currently supported Nova 9.
- Can be tested on other models too.
- We recommend to read firmware backup before testing on other models.
Fixed Raw Dump Reading
- Now it will also read dump for all physical partitions.
- Added option to select which LUN you want to read.
Updated RichEdit control to fix Access violation error on some PCs
Added Update Info on startup to keep you informed on latest version release
#umtpro
NewsMaker
Staff member
UMTv2/UMTPro QcFire v8.0 - Oppo Reset and FRP, LG, Huawei and more...
Added:
Huawei
- Nova 8i (NEN-LX1)
Lenovo
- Z5 (L78011)
LG
- G8 ThinQ (LM-G820)
- V60 ThinQ 5G (LM-V600)
Oppo
- A32 (PDVM00) - eMMC
- A32 (PDVM00) - UFS
- A33 (CPH2137)
- A53 (CPH2127) - eMMC
- A53 (CPH2127) - UFS
- A53s (CPH2139)
- A73 (CPH2099)
- A95 (CPH2365)
- F17 (CPH2095)
- F19 (CPH2219)
- F19s (CPH2223)
- Find X2 Lite (CPH2005)
- Realme X50 Pro 5G (RMX2075)
- Reno 10x Zoom (CPH1919)
- Reno 5G (CPH1921)
VSmart
- Joy 3 (V430A)
Walton
- Primo RX8 Mini
Updated Huawei ID Reset
- Added Nova 8i (NEN-LX1)
- Added Auto backup, you can restore this backup incase of bootloop
Updated Vivo Fastboot Function
- Improved method to detect unsupported firmware
Updated Oppo OFP Extractor
- For Qualcomm Heuristic mode, now you can extract only XML and loader
- It will save time when only you need is XML and loader
Minor GUI Changes
- Vivo Fastboot functions move to Read and Tools Tab
- Vivo Special tab renamed to Qualcomm Heuristic to better suite its use
- Re-arranged Read and Tools tab for more clean look
Thanks to our users for revealing true power of our Heuristic Method
#umtupdates
NewsMaker
Staff member
29-07-22] UMTv2/UMTPro QcFire v8.1 - BlackShark 2 Pro, 3, OnePlus 9 Pro 5G and more.
Added:
ASUS
- Max Pro (ZB601KL)
- ZenFone 4 (ZE554KL)
Huawei
- Enjoy 9 (DUB-TL01)
- Nova 9 SE
Lenovo
- Legion Duel
- Tab M10 FHD (TB-X605FC)
LG
- G6 (LG-H870S)
- G6 (VS988)
- V20 (US996)
- V20 (VS995)
LYF
- LF2406S
Meizu
- Note 9
Nokia
- 6.1 (TA-1043)
- 6.1 (TA-1045)
- 6.1 (TA-1050)
- 6.1 (TA-1054)
- 6.1 (TA-1068)
- 7 Plus (TA-1041)
- 7 Plus (TA-1046)
- 7 Plus (TA-1062)
- 7.1 (TA-1085)
- 7.1 (TA-1095)
- 7.1 (TA-1096)
- 7.1 (TA-1097)
- 7.1 (TA-1100)
OnePlus
- 9 Pro 5G (LE2120)
Xiaomi
- BlackShark 2 Pro (DLT-H0)
- BlackShark 3 (KLE-H0)
- Redmi Note 10 Pro (sweet) (Auth required)
Improved Vivo Fastboot Function
- Updated Format FS to remove demo also
- Fixed timeout issue with some phones
Added Activate Slot (Fastboot)
- Fix stuck in fastboot issue even after successful flash
- Can be used for both QC and MTK device with 2 slots
Updated Internal Loader Database
Some Minor Fixes
#umt, #umtupdate
NewsMaker
Staff member
UMT UMTv2/UMTPro QcFire v8.3 - Xiaomi Sideload, Samsung Note20, S21 and more..
Added:
ASUS
- Zenfone 5 Lite (ZC600KL)
Condor
- Plume H1 (SP620)
Coolpad
- Victor (VCR-10)
Huawei
- Honor 8X Max (ARE-AL00)
- Honor 8X Max (ARE-L22HN)
- Honor 8X Max (ARE-AL10)
Infinix
- Hot 6 Pro (X608)
Lanix
- Ilium (LT500)
Lenovo
- Tab V7 (PB-6505M)
- Yoga Tab3 10 (YT3-X50L)
Meizu
- Note 8
OnePlus
- Nord CE 5G (EB2101)
Oppo
- R7 Lite (R7Kf)
Xiaomi
- Poco F2 Pro (lmi)
- Poco X3 Pro (vayu)
- Galaxy J4 Prime (SM-J415F)
- Galaxy Note20 5G (SM-N981U)
- Galaxy Note20 Ultra 5G (SM-N986U)
- Galaxy S21+ 5G (SM-G996U)
- Galaxy S21 5G (SM-G991U)
- Galaxy S21 Ultra 5G (SM-G998U)
SonimTech
- Sonim XP3 (XP3800)
VSmart
- Live (V620A)
- Star (V320A)
- Star 3 (V330A)
ZTE
- Nubia RedMaigc 6R (NX666J)
Added Sideload Mode function for Xiaomi
- FRP Reset
- Reset Mi Account
- Anti-Relock patch will be auto applied for Qualcomm Devices
- Supported Android 11 and higher
Improved Huawei ID Reset (Auto Method)
#umtpro
NewsMaker
Staff member
[13-11-22] UMTv2/UMTPro QcFire v8.4 - Xiaomi Sideload Flashing, Samsung and more...
We are pleased to announce
UMTv2 / UMT Pro
Innovative and Intelligent
QcFire v8.4
The Ultimate Qualcomm Tool
Supported Functions
- Read / Write Firmware
- Backup / Restore QCN
- IMEI Repair in FTM/Diag + Flash Mode
- Backup / Reset / Restore Security (EFS)
- Reset FRP (Google Factory Reset Protection)
- Format UserData
- Read Pattern Lock (Android < 6.0, Un-Encrypted Devices Only)
- Reset Locks (PIN, Password, Pattern w/o Data Loss, Un-Encrypted Devices Only)
- Enable Diag (Need OEM Unlock, May not work on BL Locked Devices)
- Reboot to EDL from Fastboot
- Reset Mi Account for Xiaomi Devices
- Disable Mi Account for Xiaomi Devices
- Factory Reset (sideload Mode) for Xiaomi Devices
- Disable / Restore Locks for Encrypted Userdata
- Motorola Boot Repair
- Xiaomi EDL Locked Device Service
- Bootloader Unlock in EDL Mode for some Xiaomi Devices
- One Click Root in EDL Mode for Generic Qualcomm Devices
- Forensic Functions (Read Contacts / Messages in EDL Mode)
- One Click Lock Reset for Vivo Phones (Encrypted Userdata)
- Factory Method for Format FS
- EDL Authentication using Xiaomi Auth App (Service Account Required)
- Xiaomi Wipe EFS in Sideload Mode
- Xiaomi IMEI Repair for RSA Protected Phones
- Xiaomi Boot Loader Unlock
- Unique Method for Vivo Reset Locks for Protected Devices
- Xiaomi EDL Auth Using UMT Server
- Xiaomi Flashing in Fastboot Mode
- Nokia Factory Firmware (nb0) Direct Flashing in EDL mode
- Oppo OFP Firmware Exctration Added
- Xiaomi Free Auth Service (bypass).
- Mi Account Reset without Relock
- Mi Account Patch on Flashing (EDL/Fastboot)
- Samsung MDM Unlock in EDL Mode
- Huawei ID Reset
- Vivo Functions in Fastboot Mode
- Universal Huawei ID Reset
- Xiaomi Sideload Reset FRP/Mi Account
- Xiaomi Sideload Firmware Update - NEW!!!
#umtpro
NewsMaker
Staff member
[17-12-22] UMTv2/UMTPro - UltimateMTK v0.1 - New Boom Module with Enhanced Functions
UMTv2 / UMTPro
UltimateMTK v0.1
The Ultimate Mediatek Tool
Whats New:
- This is new module, replacing old MTK module
- No more boot related issue or complications
- Easy to use clean and organized interface
- Completely customizable options to use own DA/PL etc.
- More useful functions are on the way
Supported CPU:
- MT2601
- MT6261
- MT6572
- MT6580
- MT6582
- MT6592
- MT6595
- MT6735
- MT6737
- MT6739
- MT6753
- MT6755
- MT6757
- MT6758
- MT6761
- MT6763
- MT6765
- MT6768
- MT6771
- MT6779
- MT6781
- MT6785
- MT6795
- MT6797
- MT6799
- MT6833
- MT6853
- MT6873
- MT6877
- MT6885
- MT6893
- MT8127
- MT8163
- MT8167
- MT8173
- MT8512
- MT8590
- MT8695
Read Info in BROM/Preloader Mode
Scatter Flashing Support
- Both BROM and Preloader Mode are supported
- Customizable Flashing Support
- Super Image Config Selection for Oppo/Realme Firmware
Oppo OFP Format Flashing Support
- Direct Flashing of OFP Firmware
META Reset Functions
- Factory Reset
- Format eMMC
- Format UFS
Bootloader Functions
- Unlock Bootloader
- Relock Bootloader
- Unlock Permanent (Redmi 6A/9A etc)
Format FS
- Format FS (Safe)
- Erase Userdata
- Reset FRP
RPMB Tool
- Read RPMB
- Write RPMB
- Format RPMB
Security Functions:
Backup Security
- Backup critical partition in zip format
Backup NVRAM
- Backup only NVRAM in zip format
Backup NVDATA
- Backup only NVDATA in zip format
Format NVRAM
- Format NVRAM partition
Format NVDATA
- Format NVDATA partition
Restore Backup
- Restore all type of backup in zip format
Reset Oppo ID
Reset Huawei ID
Reset Mi Account
Mi Relock Fix
- Use this function if phone get locked after connecting to internet
- Bootloader should be unlocked first
- Repair IMEI/MEID/Serial
- Support Vivo phones with erased RPMB also
- If you need to connect device in Preloader mode,
you must select PRELOADER in connection settings, otherwise software will try to
Crash Preloader (may not work on new security devices)
THIS IS INITIAL RELEASE OF THIS NEW MODULE. SOMETHING MAY NOT WORK AS EXPECTED. PLEASE REPORT ISSUES WITH DETAILS SO WE CAN MAKE IT BETTER ON NEXT RELEASE.
WARNING :
ESN / MEID / IMEI REPAIR IS INTENDED TO REPAIR ESN / MEID / IMEI TO ORIGINAL ONE WRITTEN ON PHONE BACK LABEL / BOX. WE DO NOT ENDORSE OR ENCOURAGE ESN / MEID / IMEI CHANGING. ITS ILLEGAL. USER IS SOLE RESPONSIBLE FOR ANY ILLEGAL ACTIVITY DONE WITH USE OF FEATURES PROVIDED IN OUR SOFTWARE, NOT LIMITED TO ESN / MEID / IMEI.
ANY USER USING OUR SOFTWARE FOR ILLEGAL PURPOSE WILL BE SOLE RESPONSIBLE FOR HIS ACTS.
WE CONDEMN USE OF OUR SOFTWARE FOR ANY ILLEGAL PURPOSE.
#umtpro
NewsMaker
Staff member
UMTv2 / UMTPro UltimateMTK v0.2
Wishing all of you a very
HAPPY NEW YEAR 2023
Whats New:
Added Xiaomi and Oppo IMEI Repair
- Both IMEI is supported
- Please unlock bootloader first
- Incase bootloop after BL unlock, just wipe data from recovery
- Tested SoCs:
- MT6765
- MT6761
- MT6771
- MT6779
- Should work on others also except 5G chipsets
Changed Connection Settings for users familiar with old module
- Unticking Disable Auth will also disable options not supported without exploit
- You must use Disable Auth for secured phones
- Crash Preloader will not work on newer device and you must use Testpoint for them
- Preloader mode will not work for secured devices unless you have secure DA
Added Select Preloader Prompt
- If dump preloader failed, it will prompt you to select preloader
- For phones connected with testpoint, preloader need to be selected by user
Improved DA selection and handling
- Now software will try to pickup first supported DA from DA folder
- It has no effect if user has selected custom DA
Updated Mi Relock Fix
- Now devices with dual slot are supported
- Not all firmware are supported, if it does not work, try downgrade
Resized GUI to fit low resolution screens
Added Context Menu in Logs
Changed Installation Folder
- Now you can use old module in parallel with new module
- Once all functions are moved to new module, old module will be eradicated
#umtpro
NewsMaker
Staff member
UMTv2/UMTPro QcFire v8.5 - Xiaomi Temp Unlock, Oppo New Firmware Support
UMTv2 / UMT Pro
QcFire v8.5
Supported Functions
- Format UserData
- Huawei ID Reset
- Xiaomi Temporary BL Unlock - NEW!!!
- Xiaomi Enable Diag (NO ROOT) - NEW!!!Added:
ASUS
- ROG Phone 5s (ZS676KS)
- ROG Phone 6 (AI2201_C)
Huawei
- Honor 50 Lite
- nova (CAN-L11)
Smartisan
- M1L
- U1
- U2 Pro
Added Xiaomi Temporary Bootloader Unlock (Sideload)
- Only Android 11/12 before October Security Patch Supported
- Mi 10 5G (umi)
- Mi 9 (cepheus)
- PocoFone F4 GT (ingres)
- Redmi 10C (fog)
- Redmi 10C NFC (rain)
- Redmi K20 (davinci)
- Redmi K20 Pro (raphael)
- Redmi K30 4G (phoenix)
- Redmi K30 Pro (lmi)
- Redmi K30 Pro Zoom (lmi)
- Redmi K30 Zoom (lmi)
- Redmi K30S (apollo)
- Redmi K40 (alioth)
- Redmi K40 Pro (haydn)
- Redmi K40 Pro+ (haydn)
- Redmi K40s (munch)
- Redmi K50 Gaming (ingres)
- Redmi Note 10 (mojito)
- Redmi Note 10 (sunny)
- Redmi Note 10 Pro Max (sweetin)
- Redmi Note 11 NFC (spesn)
- Redmi Note 11 Pro 5G (veux)
- Redmi Note 8 (ginkgo)
- Redmi Note 9 (merlin)
- Redmi Note 9 4G (lime)
- Xiaomi 11T Pro (vili)
- Xiaomi 12 Pro (zeux)
Addded Xiaomi Enable Diag (NO ROOT)
- You will get option to use it on Xiaomi Special -> Enable Diag
- Select Yes for new method or No for old
- Follow the instructions given by software
Added Oppo/Realme New Firmware Flashing Support
- Software will auto recognize Multi Super Format and select files automatically.
Improved EXT4 Images Flashing Function
- Now should be faster than before
Special thanks to all our users who helped us with their test reports.
Please use UMT Card Manager to Update Card Counter / Firmware / Activate Add-on, available via Support Access.
It Has Begun...
Keep Following Us...
Some Nice Updates Are On The Way...
SPECIAL THANKS TO OUR VALUABLE USERS FOR THEIR LOVE AND SUPPORT FOR MORE THAN 7 YEARS
WARNING :
STATUTORY WARNING - READ CAREFULLY
Using International Edition of our software is prohibited by Indian Law.
We strictly advice you to use Indian Edition if you are in India.
If you use International Edition in India, it may cause legal action against you by local law enforcement agencies.
We will not be liable for any loss or damaged caused.
#umtpro
NewsMaker
Staff member
[01-02-23] UMTv2/UMTPro QcFire v8.6 - Samsung S10, LG V50 ThinkQ, BlackShark 2 & more
UMTv2 / UMT Pro
QcFire v8.6
Supported Functions
- Format UserData
- Huawei ID Reset
#umtpro
NewsMaker
Staff member
[23-02-23] UMTv2/UMTPro UltiamteMTK2 v0.3 - Redmi 10A Patch Cert and more...
Supported Functions
- Format UserData
- Huawei ID Reset
#umtpro
NewsMaker
Staff member
[04/03/2023] UMT v2/UMT Pro Unisoc V0.3 update Released.
Unisoc v0.3
The Ultimate Unisoc Tool
Supported Functions
- Format UserData
- Huawei ID Reset
NewsMaker
Staff member
Added:
Realme
C11 2021 - SimUnlock [beta], other functions already supported.
C25Y - SimUnlock [beta], other functions already supported.
C21Y - SimUnlock [beta], other functions already supported.
SM-A035F - Read Info, Factory Reset, Backup & Restore NVRam, FRP Reset, Write Firmware
-- Added in exe Testpoint images and updated connection logs.
-- Testpoint images links located in Utils tab
ZTE
ZTE Blade P600 - Support for Android 11 Simunlockr.
ZTE Blade P651 2021- Support for Android 11 Simunlock.
ZTE Blade A7S 2020 - Support for Android 11 Simunlock.
ZTE Blade V2020 - Support for Android 11 Simunlock.
ZTE Blade A31 - Support for Android 11 Simunlock.
- Fixed "wrong response" error on unlocking such phones with android 11
ZTE A31 lite - Support for Android 11 Simunlock.
ZTE A3 (2020). - Support for Android 11 Simunlock.
- To service this phones need to select model from list.
- Selecting generic model will not work.
- On selecting Simunlock or IMEI Repair for these phones need to read exe hints.
Itel
A25 - Read info, Factory Reset, Backup/Restore NVRam, FRP Reset, Write Firmware, Diag Functions.
A51 - Read info, Factory Reset, Backup/Restore NVRam, FRP Reset, Write Firmware, Diag Functions.
A56 - Read info, Factory Reset, Backup/Restore NVRam, FRP Reset, Write Firmware, Diag Functions.
AC60 - Read info, Factory Reset, Backup/Restore NVRam, FRP Reset, Write Firmware, Diag Functions.
Alpha - Read info, Factory Reset, Backup/Restore NVRam, FRP Reset, Write Firmware, Diag Functions.
P36 - Read info, Factory Reset, Backup/Restore NVRam, FRP Reset, Write Firmware, Diag Functions.
P41 - Read info, Factory Reset, Backup/Restore NVRam, FRP Reset, Write Firmware, Diag Functions.
Micromax
IN 2b - Read info, Factory Reset, Backup/Restore NVRam, FRP Reset Write Firmware, Diag Functions.
- Added Possibility to use Custom UID to perform Simunlock.
- Improved Reset FRP on phones with Android 11.
- Improved Restore nvram, Backup firmware, Backup nvram on phones with Android 11.
- Added generic ZTE SC9832E loader what support Read firmware.
- Added generic ZTE SC9832E loader what Support simlock.
- Fixed bug with remove FRP, what give error on some cpu.
- Improved backup firmware function, if loader support this function, exe will allow read firmware and display partitions.
- Read firmware will remain in same format and can be wrote back with old exe function like before.
- Improved nvram backup to support new phones with Android 11
- Reading SN on Boot Info.
- Reading firmware on Phones which uses certificate to sign firmware.
Order here- www.Gsmservice.center
#umtpro
NewsMaker
Staff member
[12/03/2023] UMT v2/UMT Pro Unisoc V0.4 QuickFix update Released
SPRD - Unisoc supported Processors:
SC6530
SC6531
SC6531E
SC7701
SC7702
SC7703
SC7731G
SC7720EA
SC7731C
SC7731E
SC9863A
SC9820E
SC9832E
SC9830A
SC9850KA
For these CPUs this operations only supported:
SC6530
SC6531
Operations: Read full, write full, format efs, backup nvram, restore nvram, read privacy code, write pac firmware.
SC6531e
Operations: Boot info, write pac firmware, read privacy code, factory reset phone (diag mode)
Features:
Boot Info
Read Privacy code
Read Firmware
Write Firmware
Backup NVRAM
Restore NVRAM
Backup Security
Restore Security
Write Original Pac Firmware
FRP Remove
Factory Reset
Make Custom Loader - (Which Makes this tool Universal and Supports Mostly ALL Phones).
Details about Read Write firmware:
Read phone info: In flash mode and Diagnostic mode.
Write factory PAC file: Supported all phones except phones which asks for server auth.
Read firmware: Supported for now SC7731E,SC9863A, SC9820E, SC9832E cpu, (more will be added soon).
Write firmware which is read from phone for supported cpu.
Custom Loader info:
User can make own custom loader using phone firmware and service unsupported yet phones.
Using this method supports most phones in current market (does not supported phones what ask for server auth)
Very Important:
- To read firmware user must select phone from list or use compatible custom loader.
-- Reading firmware using unsupported model, can give unpredictable result.
Quick Fix
1. Fixed booting & updated and fixed reading backup / flash factory backup.
2. Added simlock remove on selecting custom loader.
#umtupdate
NewsMaker
Staff member
UMTv2 / UMT Pro UltimateMTK2 v0.4 The Ultimate MediaTek Tool
Added Xiaomi Patch Cert Method 1
- Use this function if you face NV Data Corrupted Issue
- Tested on:
- Redmi 9
- Redmi 9 Prime
- Poco M2
- In case of issue, make sure phone has MIUI v12.x
Added Oppo DL Error Fix:
- CPH1725
- CPH1859
- CPH1909
- CPH1911
- CPH1923
- CPH1989
- CPH2001
- CPH2015
- CPH2035
- CPH2083
- CPH2121
- CPH2185
- CPH2239
- CPH2269
- CPH2285
- RMX1821
- RMX1941
- RMX2040
- RMX2117
- RMX2189
- RMX3201
Added Internal Preloader for Listed Models
- No need to use preloader if you select a model
- Useful if preloader dump not work, for example if using TestPoint for BROM mode
- Motorola G10 (TA-1346)
- Motorola G20 (TA-1372)
- Motorola G31 (XT2173-3)
- Oppo A5s (CPH1909)
- Oppo A83 (CPH1827)
- Oppo A91 (CPH2021)
- Oppo F11 Pro (CPH2209)
- Oppo F17 Pro (CPH2119)
- Oppo F7 (CPH1819)
- Oppo F9 Pro (CPH1823)
- Oppo Reno Z (CPH1979)
- Realme 7 (RMX2151)
- Realme C15 (RMX2180)
- Realme Narzo 20 (RMX2193)
- Vivo S1 (PD1913F)
- Vivo Y11 (PD1930F)
- Vivo Y12S (PD2036HF)
- Vivo Y15 (PD1901FB)
- Vivo Y17 (PD1901)
- Vivo Y1s (PD2104)
- Vivo Y30 (PD1987BF)
- Vivo Y33S (PD2166)
- Vivo Y55 5G (PD2166F)
- Vivo Y81S (PD1732)
- Vivo Y91c (PD1818HF)
- Xiaomi Poco C3
- Xiaomi Poco M2
- Xiaomi Redmi 10A
- Xiaomi Redmi 10X
- Xiaomi Redmi 10X 4G
- Xiaomi Redmi 10X Pro
- Xiaomi Redmi 9C
- Xiaomi Redmi Note 10 5G
- More models will be added in next update
Added Special Internal DA:
- 6781
- 6785
- 6797
- 6833
- 6853
- 6873
- 6877
- 6885
- 6893
Added Patch DM-Verity
- You can find it in Bootloader Unlock functions
- Usefull if you flashed device and DM-Verity is again enforced
Fixed RPMB Read/Write/Erase Function
Improved Scatter Flashing
Some cosmetic changes and improvements
