Infinity Chinese Miracle Updates
MUSLIMBEK
Infinity Chinese Miracle-2 #CM2MT2 v2.37 - general improvements and fixes
- "Restore Backup" config mode updated
- "Restore Backup" allow to select files manually
- Flash file (Scatter) Open|Select|Clean buttons at "Flash" page
- Flash file (Scatter) parser updated
- Flash file (Scatter) selection issue fixes
- MemoryTool file selection issue fixes
- MemoryTool gui minor changes
- "Switch to HS USB" option removed
- Config storage engine updated
- Account Check gives balance and subscription date
- "PMT Info" config value stored
- "Flash" page minor gui changes
- Loaders remote verification revised
- Installer updated to manage previously installed boot-pack
- Required Dongle firmware version: 0153
  • InfinityBox_install_CM2MT2_v2.37.rar
Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.14 - A/B support and more
As ordinary, unique functions and methods released
Core
Changed: FlashCore protocol updated - R25.x
Changed: New DL-core support - v20 at Infinity notation
Changed: Diag protocol updated
Changed: 1S base loaders for SC7731e - AB devices, Android 10/11
Changed: 1S loaders line included for SC9832e - AB devices, Android 10/11
Changed: 1S loaders line included for SC9863 - AB devices, Android 10/11
Info: It's recommended to use 1S loaders for Identify operation on older UniSoc lines - SC7731e, SC9832e, SC9863 with Android 9 - 10
Changed: FlashLoader authentification [RSA and AES] - brand-specific operation
- Allow service over FlashMode models, which require remote authentification
- New model lines activated (server-side): Tecno, Infinix
- Supproted Brand lines: Itel, Infinix, Tecno, Generic
Flasher
Changed: Protocol updated
Changed: FlashCore update
Changed: A/B flashing activated (Infinity Packages, factory PAC)
Changed: PAC r2.x line support updated
Changed: Infinity Packages flashing revised
Service
Changed: FormatFS updated
Changed: NVMManager updated - NV Read, Write, Update
Changed: RepairSecurity updated: SN repair
Changed: RepairSecurity updated: ServerSupport models list increased, more Android 10/11 supported
Firmware reader
Changed: Android 10, 11 specific changes
Changed: UltraRead protocol updated
Changed: Loader compatibility selection optimized
Changed: A/B devices support activated!
- Allow read complete, working, safe and factory-like firmware images for most modern Android 10/11 devices!
- No any FOTA, security and other issues with read FW, no any unique data damage
- Automatic active slot identification and selection, with no chances to read useless firmware and also save 2x HDD space for old AB
Model DB
Changed: New generic loaders included for SC7731e - 1S line, v20
Changed: New generic loaders included for SC9832e - 1S line, v20
Changed: New generic loaders included for SC9863 0 1S line, v20
Changed: New generic loaders included for T618 - 1S line, v20
Changed: New loaders included for Realme
Changed: New loaders included for Itel
Changed: New loaders included for Tecno
Changed: New loaders included for ZTE
Other
Changed: LoaderDB updater now supports modern PACs - A/B, modern R2.x
Changed: Many other different changes and fixes
  • InfinityBox_CM2SP2_v2.14.7z
InfinityBox_install_CM2MT2_boot-pack_v2.35
InfinityBox_install_CM2SP2_boot-pack_v1.14
InfinityBox_CM2MTK_boot-pack-for_v1.58
  • InfinityBox_install_CM2SP2_boot-pack_v1.14.rar
  • InfinityBox_install_CM2MT2_boot-pack_v2.35.rar
  • InfinityBox_CM2MTK_boot-pack-for_v1.58.7z
Official site - here
Credit consumption - here
Official Support - here
Need dongle
Infinity Chinese Miracle-2 MTK/MediaTek v2.17 - Standalone auth ON
As ordinary unique solutions by World famous Infinity Team !
Core
Changed : Protocol updated ( Raphael/Legacy )
NewFeature: Standalone SLA/Auth [Raphael]
Changed : Internal EMI engine updated : RAPAHEL : UFS support rebuild
Flasher
Changed: Core updated for RAPHAEL line
Changed: UltraFlash feature updated, new security workarounds supported
Service
Changed: Identify
!* Read new Android 10 specific fields, vendor-specific fields
Changed: Smart Reset
!* Optimized support for different customized and generic cases
Changed: HW Report ( RAPHAEL - only )
!* UFS line devices now supported with following features:
- CID info ( FlashIC base info, name, vendor ) - default info, even if boot can nott be completed by some HW or SW reasons
- LifeInfo ( SLC, MLC, EOL status and use counters ) - allow understand how bad it feels
- RPMB info ( is it key programmed or clean and can be re-used )
- Partitioning details and other
- HWreport log saving enabled ( for further analyze )
!* Feature also allow automatic select and store for further use BOOTROM connection settings for RAPHAEL devices ( DRAM init )
!* HWreport not require complete boot in case of semi-dead devices. Useful for HWdebug
!* HWreport result may vary in diffirent models and agents even on the same SoC !
Firmware Reader
Changed : Some modern brand-specific changes ( Xiaomi, Oppo, Vivo, Realme )
Changed : New types supported
Other
BugFix : Many different minor changes and fixes
Changed : Generic protocol rebuild
Info
- Standalone SLA/Auth allow you ignore device security setting and allow boot it without having any DA/Auth/Remote auth support
- You can boot ( with supported SoC ) device with any generic da and perform any need operations
- Support MT6765 - All security versions, no auth need, no special da need, no remote service need
Support Xiaomi, Oppo, Vivo, Realme, Huawei and whatever else existing
- Support MT6785 - All security versions, no auth need, no special da need, no remote service need
NOTE: special boot-helper tool should be installed - included in CM2MT2 package
By from of reseller - gsmservice.center
Infinity Chinese Miracle-2 MTK/MediaTek v2.18 - Standalone MTK auth ON - new models and features
CM2MT2 v2.17 with info about MT67xx auth and test reports are HERE
Core
Changed: Protocol updated ( Raphael/Legacy )
Changed: Loader v2044 supported and tested ( v2028 was unstable with MT6765 )
NewChip: MediaTek AC8227 (Car HeadUnits SoC) supported
NewChip: MediaTek AC8257 (Car HeadUnits SoC) supported
Flasher
Service
Changed: META core updated
- LifeStatus identify revised, in some cases it may shown wrong info. Strongly recommend use latest version for HWcheck !
!* Feature also allow automatic select and store for further use BOOTROM connection settings for RAPHAEL devices (DRAM init)
!* HWreport not require complete boot in case of semi-dead devices, it is useful for HWdebug
Firmware Reader
Changed: Some modern brand-specific changes (Oppo, Realme)
Changed: New types supported
Changed: Internal Database updated
Model DB
Changed: New agents included for Tecno, Infinix ( with different SoC lines )
Changed: New DA base v2044 included
Other
Changed: GUI settings now stored and load select style, settings and other at next run
Changed: Environment compatibility issue with 32 bit OS has been fixed
Changed: Many different changes and fixes
Activate from of reseller - gsmservice.center
Infinity Chinese Miracle-2 MTK/MediaTek v2.20 - Standalone MTK auth ON - NEW CPU
Core:
AUTH: MT6752 with any security configuration supported standalone !
AUTH: MT6753 with any security configuration supported standalone !
AUTH: MT6768 with any security configuration supported standalone !
AUTH: MT6757 support improved/fixed
Service:
Changed: Identify procedure revised
- Support modern Android 10 devices
- Support for Android 11 devices activated
Changed: SmartReset procedure
Firmware Reader:
Changed: Android 10 specific changes for modern devices
Changed: Android 11 initial support
ModelDB:
Changed: Some specific and brand list update
Other:
By from official reseller -gsmservice.center
Infinity Chinese Miracle-2 MTK/MediaTek v2.21
Core
AUTH: MT6779 with any security configuration supported standalone !
AUTH: MT6799 with any security configuration supported standalone !
AUTH: MT8127 with any security configuration supported standalone !
AUTH: MT8167 with any security configuration supported standalone !
AUTH: MT8172 with any security configuration supported standalone !
AUTH: MT8173 with any security configuration supported standalone !
Changed: BootHelper updated
- Automatic Self-Learning function improved
Changed: EMI manager updated, most modern devices support has been included
Flasher
Firmware Reader
ModelDB
Other
Changed: Different changes and fixes
Installer
- Installer become more compact and now contain two parts: required and optional
- Optional Installer CM2MT2-boot-pack contain optional (legacy) boot files
gsmservice.center - official reseller
Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.12 - New repair level activated
Core
Changed: FlashCore protocol updated (R25)
Changed: New DL-core support (v10 at Infinity notation)
NewSOC: SC9820e [RS/0S] with NAND supported
Flasher
Changed: FlashCore rebuild
- Reworked FlashErase
- Reworked support of fully erased or semi-damaged modern devices Android 8/9/10/11 (SC9820e, SC7731e, SC9832e, SC9863, SC9850), it is possible to repair these devices from any state (in case of working HW)
- Reworked NVRecovery procedure
- Android version change ( Downgrade/Upgrade ) now work more correct
Firmware reader
Changed: KaiOs specific changes
Changed: Initial Android 11 support
Changed: Fixed "Encryption Unsucessfull" errors on some devices after flash
SPUnlock
Changed: Android 11 SPunlock and Repair confirmed and working
Changed: UniSoc Tiger T310 initial SPUnlock/Repair support
Changed: Changed unlock procedure for some devices
Changed: Allow check status/continue unlock on zero balance
Almost all existing on market devices for SP-Unlock and Repair are supported, Android 10 / 11 "security" as well
Model DB
Changed: New generic loaders included for 9820E with NAND
Other
Infinity Chinese Miracle-2 MTK/MediaTek v2.25
Core
Changed: Protocol updated (Raphael/Legacy)
NewSoC : MT6873 support activated
NewSoC : MT6885 support activated (under test)
Changed: BootHelper : core updated
Changed: FireFly : EMI updated
Changed: MT817x line support improved
Changed: Boot : HWinfo parsing improved
Changed : UniversalBoot : EMI Engine
! Selection rules updated
! By default during Flashing used FW as source
! EMI collecting speed optimized, now more faster on auth-enabled devices
! BootHelper <> FireFly interaction optimized
NewSoC : MT6873 supported features
! Standalone SLA : supported
! FireFly : EMI : supported
! META operations : supported
! Firmware Read : supported
! Firmware Write : supported
! Reset Settings : supported
! Reset FRP : supported
! Misc Operations : supported
Flasher
Changed: UltraFlash engine updated
! Tuned up for multi-failed regions ( like Huawei )
Changed: Default FlashSettings updated
Firmware Reader
Changed: Huawei support activated!
! Allow read CORRECT firmware but not a useless/harmful dump etc.
! Sparsing for Huawei-specific partitions activated - extremely reduce FW size
Changed: Activated sparsing (reduce firmware size and increase flashing speed) for:
! - F2FS
! - HuaweiFS
Changed: MT6873 specific changes ( new formats and types )
- Allow read CORRECT firmware without damage FOTA/OTA, Security etc.
- Final result Firmware is like factory one
Changed: MT6885 specific changes ( new formats and types )
Service
Changed: META protocol updated
! Support MT68xx line
! Legacy bugfixes
Changed: HWReport improved (MT68xx line support)
Changed: "SmartReset" updated
Changed: "SmartReset Extra" updated
! Vendor-specific mode activated for SAMSUNG phones
! Device brands, supported in EXTRA mode: Vivo, Meizu, Xiaomi, Samsung
Other
Changed: Many different general changes and fixes applied
Infinity Chinese Miracle-2 MTK/MediaTek v2.26 - New Core, BootLoader Unlock and more
Core
Changed: Protocol updated (Raphael / Legacy)
Changed: MT6785 support fixed
Changed: MT6885 support fixed
Core: Protocol: FireFly activated
FireFly - Universal DownloadAgent that was created by Infinity Team to reach new service level and provide advanced features
Current Supported SoC (initial release):
MT6765
Support operations:
Identify: Device Info (Android), HWInfo with Full eMMC and EOL info
Format FS: Smart Reset, Extra and all other modes are supported
MemoryTool: Allow execute ALL supported MemoryTool functions
! Read, Write (Binary, Sparse, Signed, Unsigned), Make FileSystems, Wipe, extra features
! Unlike MTK mode FireFly IS NOT rely on DA/Device security policy so there is no limits for different operations (No any Write / Erase issues)
BootLoader Unlock: Allow Unlock device Bootloader - WITHOUT touching UserData
! Bootloader unlock also allow unlock Brand-Specific cases (Xiaomi supported at the moment)
Changed : UniversalBoot : BootHelper
! Software always try to init BootRom mode if it's required for selected target
! Software allow force BootRom mode for generic models (plain one) if it's required
! In current release 4 different ways activated which cover most of cases but may not work with some cases, more to come
Flasher
Firmware Reader
Changed: Huawei line changes and fixes
Service
! Vendor-specific mode improved for Samsung devices (A4x and others)
! Device brands supported in EXTRA mode: Vivo, Meizu, Xiaomi, Samsung
Changed: Identify operation now save preloader backup
Changed: Identify opertaion now show OTP info for Alcatel-like and similar devices
NewFeature : BootLoader Unlock Activated ( No data Loss )
Changed: Full MemoryInfo (include CSD, WP status, EOL info etc.) now shown in FireFly mode by default
Memorytool
Changed: Preloader Init has been rebuild - Raphael, Legacy, FireFly
Changed: Automatic selection rules updated
Changed: Extra operations updated
Changed: FileSystem build revised
Changed: FireFly as core protocol supported in MemoryTool
Other
Changed: Protocol/SoC Generation switch can be done over "Platform" in System Menu
! According to Platform/Protocol selection some features may enabled or disabled - make right Platform selection before operation!
Infinity Chinese Miracle-2 MTK/MediaTek v2.27 - MT6853, MT6853, Samsung, FireFly and more
Core
Changed: Protocol updated ( Raphael )
NewSOC : MT6833 support activated ( any security state )
NewSOC : MT6853 support activated ( any security state )
Changed: MT68xx line support optimized ( FireFly:EMI, EMI Engine, UltraFlash )
Auth
AUTH: MT6833 with any security configuration supported standalone!
AUTH: MT6853 with any security configuration supported standalone!
Core: Protocol: FireFly updated
New SoC activated:
MT6768
MT6771
Current Supported SoC:
MT6765 ( any security configuration )
MT6768 ( any security configuration )
MT6771 ( any security configuration )
Support operations:
Changed : BootLoader unlock : ability to re-lock bootloader ( software will ask if device already unlocked for re-lock it back )
Flasher
Changed: Samsung flashing support activated ( MTK models , only CM2 firmware! )
Changed: MT68xx line specific changes
Firmware Reader
Changed: SAMSUNG devices line support activated!
! Allow read COMPLETE, SAFE, USABLE firmware. No any security damage, no any additional reflashing after required
Changed: Android 9-10-11 DevInfo optimized
Changed: Firmware naming optimized
Changed: Vendor Specific : OPPO devices support optimized for read firmware
Changed: Vendor Specific : VIVO devices support optimized for read firmware
Service
Changed: "SmartReset" now activated for LEGACY line devices
! Device range : From MT6572 and up to 6737
! Tested SoC/Devices : MT6572, MT6592, MT6595, MT6735, MT6737, MT6752, MT6753, MT8127, MT8172, MT6580
! Tested Android version : 4.4, 5.x, 6.x, 7.x, 8.x, 9.x, 10.x
! Info : Due to wide range of LEGACY devices some of them may work not correct so, please, leave us reports about issues!
Changed: Identify operation now read more device info ( Android 10/11 )
Infinity UpdateCM2MT2_v2.28
Infinity Chinese Miracle-2 MTK/MediaTek v2.28 - MT6877, MT6893, Repair Security and more
Core
Changed: Protocol updated for Raphael / Legacy platforms
NewSOC : MT6877 supported - any security state - SLA, DAA, Plain
NewSOC : MT6893 supported - any security state - SLA, DAA, Plain
Changed: FireFly / Infinity DA (Download Agents) updated
Changed: NVRAM manager has been rebuild from scratch
For now it covers all Old and Modern devices for Identify and Repair operations in FlashMode!
FireFly - Universal DA (Download Agent) that was created by Infinity Team to reach new service level and gives features
FireFly: NewSOC : MT6739
FireFly: NewSOC : MT6761
FireFly: NewSOC : MT6763
FireFly: New operations supported:
Repair Security for Generic, Vivo and all other non-signed cases
Read / Write NVRAM
Restore Backup
Current list of supported SoC:
MT6739
MT6761
MT6763
MT6765
MT6768
MT6771
Supported operations:
Identify: Device Info ( Android ), HWInfo with Full eMMC and EOL info
Format FS: Smart Reset, Extra and all other mode are supported
Read / Write NVRAM
Restore Backup
Flasher
Changed: UltraFlash engine updated and also any limitations has been removed
Changed: Flash engine updated
Firmware Reader
Changed: MT6877 support
Changed: MT6893 support
Changed: Fake "Samsung" devices processing fixed
Service
Changed: "Identify" operation now show more security info
Changed: "Identify" operation now show modem info/version
Changed: New NVRAM engine/tools
! Read device security now works with Legacy (Old/New) and Raphael (Old/New) lines
! Rebuild check/verify procedures for modern devices
! Repair Security now works in flash mode for Raphael line too ( support most UNSIGNED types - Generic, Huawei, Vivo, Nokia etc. )
! Repair security NOT work with vendor-signed devices ( you will get info about device not supported during operation )
! Signed/Generic mode detection improved
Changed: Restore Backup operation has been updated
Changed: NVRAM read and write operations has been updated
Memorytool
Changed: FireFly mode support updated
Other
Feature: Feedback - BugReporting/DebugData collection module enabled. Feedback can be enabled/disabled during installation.
! Feedback feature made for fast, automatic reporting to team about new/unsupported devices in different Gsmseservice is best operations without any additional need of actions from user side.
! That will allow bring server-side updates faster and make updates for new and unsupported phones, if need, every day!
Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.14 - A/B support and more!
Core
Changed: FlashCore protocol updated (R25.x)
Changed: New DL-core support (v20 at Infinity notation)
Changed: 1S base loaders for SC7731e (AB devices, Android 10/11)
Changed: 1S loaders line included for SC9832e (AB devices, Android 10/11)
Changed: 1S loaders line included for SC9863 (AB devices, Android 10/11)
Info : 1S loaders reccommend to use for Identify operation on older UniSoc lines (SC7731e, SC9832e, SC9863 with Android 9 - 10)
Changed: FlashLoader authentification [RSA and AES] (brand-specific)
Flasher
Service
Changed: NVMManager updated (NV Read, Write, Update)
Firmware reader
- No any FOTA, security and other issues with read FW, no any unique data damaging
- Automatic active slot identification and selection, with no chances to read useless firmware (and save 2x hdd space for old AB)
Model DB
Changed: New generic loaders included for SC7731e (1S line, v20)
Changed: New generic loaders included for SC9832e (1S line, v20)
Changed: New generic loaders included for SC9863 (1S line, v20)
Changed: New generic loaders included for T618 (1S line, v20)
Other
Changed: LoaderDB updater now supports modern PACs (A/B, modern R2.x)
Core
Auth
New SoC activated:
MT6768
MT6771
Support operations:
Flasher
Firmware Reader
Service
Core
Read / Write NVRAM
Restore Backup
MT6739
MT6761
MT6763
MT6765
MT6768
MT6771
Read / Write NVRAM
Restore Backup
Flasher
Firmware Reader
Service
Memorytool
Other
Core
Flasher
Service
Firmware reader
Model DB
Other
Infinity Chinese Miracle-2 CM2MT2 v2.29 - MT6781, A/B Reader and more
As ordinary unique functions and methods released
Core
NewSOC : MT6781 supported - any security state - SLA, DAA, Plain
Agent : DA v2136 skipped, unstable
FireFly
FireFly: NewSOC: MT6735 [Legacy]
FireFly: NewSOC: MT6737 [Legacy]
Legacy : MT6737, MT6735
Raphael : MT6739, MT6761, MT6763, MT6765, MT6768, MT6771
!! EOL info and other HW stuff also shown for LEGACY
!! In most cases on LEGACY devices UserData encryption can be not set.
!! FireFly allow boot/read even devices with dead DRAM. No need to desolder eMMC for data recovery!
Flasher
Firmware Reader
! Android 10/11/12 with A/B slots processing is now supported
! Read FW is completely like factory one!
! Read FW is NOT damage anything on device! ( FOTA, A/B switch and other )
! Read FW is NOT read "broken" slots = no any further issues!
! Read FW identify active/alive slots = always WORKING firmware, extremely reduse FW size ( for ABv1 )
Changed: Database rebuild. Branded : Support most of modern LG, Oppo, Samsung, Vivo, Infinix, Tecno and other brands.
! All this is completely safe and factory-like firmwares!
Changed: Database rebuild. Unbranded : Many "noname" and small brands supported now as well.
Changed: MT6781 support
Service
Changed: "SmartReset" updated for Android 10/11 devices.
Changed: "Identify" operation now show more device info
Changed: SPUnlock updated. Unsupported types reporting activated if user enable that option
Other
[+] About 200 different general changes and fixes applied to algorithms and methods
[+] Software Update checker feature enabled
#CM2
Infinity Chinese Miracle-2 CM2MT2 v2.30 - More models & Features
Core
FireFly
FireFly: NewSOC: MT6580 [Legacy]
Legacy : MT6580, MT6735, MT6737
!! On LEGACY devices in most cases UserData encryption can be not set
!! FireFly allow boot/read devices even with dead DRAM - no need to desolder eMMC for data recovery!
Flasher
Firmware Reader
MemoryTool
Changed: UltraFlash activated by default, no more any write restrictions
Changed: Read/Write/Erase operations revised
Service
Changed: "SmartReset" updated for Legacy and old Raphael lines
Changed: "SmartReset Data Safe" option activated
Remove all APP and Security settings, retain userdata for Vivo, Oppo.
It works for limited number of models at the moment, it depend on android version/build, use at own risk!
Brand/model selection is not required, autodetection works
Other
#cm2
Infinity Chinese Miracle-2 CM2MT2 v2.31 - New features activated!
Core
Changed: Activated FireFly over DA
! Support latest UFS-based SoC : MT6781, MT6785, MT6779, MT6833, MT6853, MT6873, MT6877, MT6891, MT6893
! Support eMMC-based SoC : MT6739, MT6757, MT6761, MT6763, MT6765, MT6768, MT6771, MT6779, MT6797, MT8167
! Supported operation : Generic MTK + Bootloader Unlock is available now for all latest SoC
FireFly
FireFly: NewSOC: MT6753 [Legacy]
FireFly: Bootloader Unlock activated for LEGACY phones
! Support for now: MT6580, MT6737 ( tested and confirmed as working )
Legacy : MT6580, MT6735, MT6737, MT6753
!! On LEGACY devices in most cases UserData encryption can be not set.
!! FireFly allow boot/read even for devices with dead DRAM - no need desolder eMMC for data recovery!
Flasher
Firmware Reader
Changed: Vivo, Oppo, Realme - firmware naming optimized - model, type, internal versioning etc.
MemoryTool
Changed: MemoryTool rebuild
Changed: Activated "Make Backup" option
Changed: Activated "Restore Backup" option
Service
Changed: "SmartReset" rebuild
!Remove flyme account improved ( meizu )
!Reset FRP may fail on some devices, fixed
!Improved work in FireFly mode
!Improved compatibility with old Android(4 - 7) versions
Changed: Security info reading improved
Changed: Reset PrivacyLock activated under FireFly mode
Changed: Backup ext_csd data during Identify under FireFly mode
Changed: Bootloader Unlock rebuild (FireFly / Generic)
Changed: Bootloader Unlock activated for more SoC : MT6757, MT6781, MT6785, MT6779, MT6797, MT6833, MT6853, MT6873, MT6877, MT6891, MT6893, MT8167
Changed: Bootloader Unlock activated for more SoC : MT6580, MT6737
Other
Changed: Many internal changes and bugfixes
#cm2
Infinity Chinese Miracle-2 CM2MT2 v2.32 - RPMB, more Repair & Service features!
Core
Changed: FireFly loaders has been updated
Changed: FireFly DA loaders has been updated
Changed: RPMB operations activated ( Read, Write, Erase )
! Supported SoC : MT6739, MT6761, MT6763, MT6765, MT6768, MT6771, MT6779,
MT6781, MT6785, MT6799, MT6833, MT6853, MT6873, MT6877, MT6885, MT6893
! Fast ( 1 | 2 minute for 16MB on eMMC and UFS on Read | Write & Erase)
! Easy and Safe ( automatic backup at service cases, data verification )
MemoryTool
Changed: Activated RPMB operations menu
!Allow Read RPMB memory
!Allow Write RPMB memory
!Allow Wipe RPMB memory
Service
!Smart Reset Extra updated : support Huawei Account reset ( EMUI 9-10 )
!SmartReset in DataSafe mode check and warn about "fixed" devices, where data loss possible
Changed: Identify operation improved
Changed: Repair Security
!Repair security now support VIVO devices
!Repair case select automatic, not need select / choose / do anything extra.
NewFeature : ServiceReport : Allow read device-specific data and send to R&D team directly ( Menu -> Extra -> Make ServiceReport )
This option helps to collect hardware database and improve device detection process.
Other
Changed: GUI changes : MemoryTool menu, Dialogs
Changed: Many importnatn internal changes, bugfixes and improvements
#cm2, #infinity
