Infinity Chinese Miracle Updates
Infinity #CM2MT2 v2.69
AppTool, MDM, Mi Acc fixes for number of models
- Boot process fixed for number of models
- Error messages fixes for Flash Write
- Firmware version output removed from Flash Write, info is available during firmware [Load]
Dongle firmware version required: 0162
CM2 1 or 2 year Support сотиб олиш - www.Gsmservice.uz
#cm2update
Infinity #CM2MT2 v2.70
- Boot process for number of [raphael] and latest [luci] generation models updated
- bootloader unlock process revised
- [Identify] process updated with bootloader lock state info
- FRP reset process revised
- GUI and help engine updated
Infinity #CM2MT2 v2.71
- Fix [No command] function to reset devices that freez at bootlogo with "no command" message
- [AppTool] bug fixed
Infinity #CM2MT2 v2.72 - Auth for latest devices for FREE
- Boot Authentication for [luci] generation tecno/infinix/itel devices
- [AppTool] updated
- Device-ID repair issue in boot mode for some device types fixed
Dongle firmware version required: 0163
#cm2update
Infinity #CM2MT2 v2.74
- Preloader parser updated
- OS version detection via DAv6 method updated
- MDM process fixed for number of devices
- [AppTool] for number of devices updated
- Print SoC drivers version
- Slots management updated for latest devices
- Reset/Format updated for latest devices
#cm2update
Infinity #CM2SP3 v2.33
MANY NEW MODELS SUPPORTED
MANY NEW LOADER FILES AVAILABLE
MANY NEW FUNCTIONS RELEASED
Also additional improvements:
- Locks/Accounts reset methods updated, more lock types supported
- OTA On/Off
- Reset methods updated as per latest devices
- Filesystem parser updated
- [AppTool] support more factory pre-install App types
- [MemTool] filesystem detection methods rebuilded
- [MemTool] read method rebuilded
- [MemTool] display info about file content on read
- gpt detection methods updated according issue with some devices (f.e. itel)
- firmware anti-crack feature detection for loaded file or connected device
- [bootlog] process rebuilded as per latest devices
- PAC flashing process revised for number of devices
- [restore backup] methods revised
- PAC extractor updated
Dongle firmware version required: 0164
CM2 1 or 2 year Support сотиб олиш 👉 www.Gsmservice.uz
#cm2update
Infinity CM2MT2 v2.76
- Connection protocol improved to avoid lost connection with low-quality cables
- Flash Read sparse/pack method updated
CM2MT2 v2.77:
MANY NEW DA FILES AVAILABLE
- Locks/Accounts/OTA reset methods updated, more lock types supported
- Reset/Format methods updated
- [MemTool] loading method revised
- [MemTool] functions rebuilded
- Modem info parser revised
- [Orange State] method revised
- LK analyzer for [Identify]
- boot/processing time measurement improved
- reset/wipe and frp methods updated for number of devices
- Bootloader unlock process improved for number of devices (xiaomi)
- [AppTool] support more factory pre-install App types (xiaomi)
- oppo/realme methods updated
- frp analyzer rebuilded for latest devices
- rpmb engine rebuilded according to latest devices
- firmware detection methods updated for latest devices
#cm2update
Infinity CM2 Full updates history - here
- OTA On/Off
#cm2update
Infinity #CM2MT2 v2.78a
v2.78a: fixed issue with PSN reading that comes with initial v2.78 release
v2.78a: return back default "my eyes" value that was changed for inintial v2.78 release
- nvram backup file naming changed, human readable device name included in file name
- Bootloader unlock process updated for number of models
- Wipe process updated for number of models
- [MemTool] functions revised and menu structure has been revised
- scatter files [txt|xml] selection method changed with combo|region configuration selector
- detect preloader info on [Connect]
- libusb load on demand only right at boot porocess but not at software startup
- [reboot to fastboot] feature for number of devices
- simlock reset methods updated
- [RawTool] updated with presets values selection
- [Kleister Tool] available to merge several files, read by [RawTool], to one solid image
- [Service report] procedure updated for number of devices
#cm2update
Infinity CM2SP3 v2.34
More features:
- ADB On/Off for number of infinix/tecno/itel models
- firmware detector for itel and similar models revised
- [FORMAT Flash] for number of devices fixed
- [Fix No command] feature
#cm2update
Infinity #CM2MT2 v2.79
- [luci] protocol revised, connection become faster for number of devices
- [legacy] protocol updated for number of devices
- meta mode for tecno/infinix/itel rebuilded
- autodetection methods for huawei updated
- bootloader unlock for number of xiaomi devices updated
- flashing for several rare cases for [ff] and [v6] protocols updated
- modem part writer updated for number of devices
- infinix-id, tecno-id reset procedures updated for latest devices
- PSN2 read/write for number of models
- firmware flash process revised
#cm2update
Infinity CM2MT2 v2.80 released
- FRP and wipe via META mode for latest (2024/2025) infinix/tecno/itel devices
- USB debugging, ADB enable for latest (2024/2025) infinix/tecno/itel devices
- "Prototype demo phone" reset for latest (2024/2025) infinix/tecno/itel devices
- [MemTool] updated with "Delete zeroes files" option
- auth process for number of SoC in BROM mode revised
- hardware compatibility checker in [Service/Aux] section
- autobackup read/write revised
#cm2update
Infinity #CM2MT2 v2.82
- [FF] protocol updated for number of SoC, f.e. MT6739, MT6781, MT6765, MT6873, MT6763
- Filesystem read/detect issue fixed for number of devices
- Reset/Format process for oppo/realme updated
- LK handling updated for oplus/oppo/realme devices
- META/SVC operations updated
- [Scan Filesystem] option for [MemTool]
- [AppTool] become much faster for latest V6 devices, ~1-2 min against 7-8 min
- 2.82a: minor issue for erofs parser fixed
- minor bugs fixed
Dongle firmware version required: 0165
#cm2update
Many new models supported:
Nerlmiay X101, X103, Z7705, X30-Pro, X8, X5, B2020, GeniusKids-G7, Ikon-25, K11, K50-Pro, P10, Pro-11, Q8
itel S24, S667LN, RS4, S666LN
oppo CPH2683, A60-5G, CPH2491, CPH1923, CPH2493
oneplus Nord-3-5G
vivo V23e, PD2245F
Skyworth Smart-4G-Speedy-4.0-Plus
samsung SM-A065F, SM-A245F
Lava Iris40
Vorcom QuartzLITE
AtozEE P70W
Cubot KingKong-Star-2, KingKong-X-Pro
Oblue Tank-3-Pro
Blackview BV9300-Pro-NEU, 8491x
TCL goldfinchtmo, Aquaman-10-Smart-WIFI,
Ulefone Armor-12s, Armor-Mini-20-Pro, Power-Armor-19
Doogee T30-Max
Oukitel OT5
Sparx Note-20
- More vivo devices supported via preloader mode w/o TP
- tecno models list updated
- infinix models list updated
- tecno CL7K DA updated
- default/base loaders set updated
- OS info detection engine updated for latest devices
- flash chip database updated
- META mode "read info" procedure updated for number of devices
- partiton table layout print method updated
- scat file loader updated for latest xml/txt formats
- get info for both device preloaders on [Identify]
- print device preloader info before flash
- Database updated with more than 100 new DA for different models
- Backup file selection method simplified
#cm2update
Infinity #CM2MT2 v2.84
New models supported:
LG Q510n
Digitnext Ultra
Waltom Primo-NH4
Micromax Q440
NXOS OG2
Fero A5000
Vivo models (v5) updated with SoC MT6763, MT6771, MT6765, MT6761, MT6768, MT6885, MT6873, MT6785, MT6853, MT6893, MT6833, MT6877, MT6781
- Connection methods updated for latest infinix/tecno/itel devices
- Motorola and Lenovo MDM operations updated for latest models
- Device database updated with the next models: Honor AMN-L03, AMN-L09, AMN-L21, DUA-AL00, KSA-AL00
- [OS Startup Logs] feature updated
- DA files for number of xioami models updated
- DA files for number of oppo models updated
#cm2update
Infinity #CM2MT2 v2.85
New models:
BQ 1025L, 4500, 5000, 5000g, 5011, 5012L, 5020, 5022, 5030, 5033, 5035, 5046L, 5050, 5054, 5058, 5060, 5065, 5070, 5071, 5202, 5204, 5209L, 5211, 5300g, 5302g, 5502, 5503, 5505, 5507L, 5508L, 5510, 5512L, 5514g, 5514L, 5515, 5515L, 5516L, 5517L, 5519L, 5520, 5520L, 5521L, 5525, 5530, 5540L, 5591, 5594, 5702, 5707g, 5732L, 5740g, 6000L, 6010g, 6016L, 6022g, 6030g, 6045L, 6050, 6061L, 6424L, 6430L
Vgo-tel Note-23, Note-24, New-5, New-7, New-10, New-11, New-12, New-20, New-22, New-24, New-25, New-26, Smart-Hi-Fi, Venture-11, Venture-v8, Venture-v9, Venture-v10, Venture-v12, V-Tab-2
TCL 6102D, T431q
Oppo CPH2639
Moto G22, XT2231, G05, XT2523-2, G15-lamu-g
Oukitel WP12-Pro
Teclast T70
- MDM database updated according to latest devices
- xiaomi DA database updated
- realmi DA database updated
- preloader analyzer updated
- [RawTool] erase method updated
- usb port faults control rebuilded
- lk analyzer adjusted for latest devices
- flasher updated for latest devices
- log storage rebuilded, divided as per connected devices
- instant log report to support via [Issue] button
There are a lot of internal changes and improvements.
if you will get any issue report it here HERE
#cm2update
Infinity #CM2MT2 v2.88
#CM2MT2 v2.87 & v2.88 New models:
Hisense F16
Oppo R7+
Abao 37M, E10c, G20, K102, KX20, W108, X80L
Acer E39, S55, S56, S57
Advan 5058-i5c-plus, 5501-i6a, E1c-3G, TCK5050B-i5E, i5K, i7, i10, i55K
AGM H3, H5, H5-Pro, M7
Airtel Airpad-7-S, V600
Alco CT9223W97, RCT6513W87
Allure M3
Allview A5-Quad, A5-Ready, A6-Duo, A10-Max, A20-Lite, A20-Max
Along Q3, M8-Go
Altice S13, S14, S23, S24, T10, S70, S64, S61, S60, S42, S34, S33, S32-NFC, S32, STARNAUTE4, STARTRAIL7
Ama A703
Celkon Cliq
7i U2
Doogee BL5000, BL5500-Lite, BL7000, BL12000-Pro, DG800
Bravis S504, A506, A511, S500
Brondi 530-4G, 620, 620-4G
Mobiwire S14, S60, S42, S34, S33, S32-NFC, S32,STARNAUTE4, STARTRAIL7
Cubot C20, C30, Cheetah, Cheetah-2, Dinosaur
RCA RCT6513W87
Coolpad 1822, 1825, 8737
Freeyond M5-5G
Fly FS402, FS507, FS520, IQ588, IQ4516, IQ4514
Venturer CT9223W97
Famoco FX200-2, FX200-6, FX100-6, PX320, PX510, FX808-1
Hotwav Cosmos, Symbol-X, Pearl-K1
Vivo V2208, Y18, V2333T
Konka R1, 711, R5, R9
Tecno KL4, Pop-9, KL4h, Spark-Go-1s
Mobicel Berry, Candy, Cherry, Cosmo, Dandy, Echo, Frio, Venus
Modio M121, M793
NGM E407
#CM2MT2 v2.88 firmware strategy detection issue fixed for number of models
- Boot/DA files autoselection method revised for v5/v6 DA to simplify boot process for new/unknown devices
- [Create SCAT file only] store preloader with scat
- Erase via [FF] protocol issue fixed
- Firmware info reader methods updated as per latest devices
- Custom Preloader/EMI file selection issue fixed
- Additional preloader file copy is not created any more on preloader file selection
- [MemTool] operations updated for latest devices
- [RawTool] updated with more hints
- Partition table reload issue fixed for number of legacy devices in case of damaged PMT
- DA parser rebuilded
- DA pack for Moto updated with XT2523-2
- DA pack for Oppo/Realme updated
- Test-Point database updated
- Offline|Online mode selection set to Auto by default
- Default color scheme selection changed to B/W
- User interface simplification
#cm2update
